got a problem. need help
Old July 28th, 2008, 06:49 PM   #1
MisterFast3's Avatar
MisterFast3 is on a distinguished road
Send a message via AIM to MisterFast3
so the other day out of the blue my car just started running like shit. was leavin work and stepped on the gas to get out into traffic. when i took of from the next stop light i went to get on it and it just started boggin out. if you get on the gas really gently and slow it will go all the way to redline and sound just fine. but if you step on it right away, something is holding it back. idles like nothing is wrong but once you hammer it, it runs like shit. so yesterday i cleaned the air filter and changed the fuel filter. neither worked. me and my dad thought maybe it jumped the timing chain? wanted your guy's opinion. so yea. whatever you got for help i need it.
Thanks
Well Hello, they call me Mr. Insano.
Old July 28th, 2008, 07:29 PM   #2
BostonPerformance's Avatar
99 Cherokee sport/87 5.0
not tested
BostonPerformance is a jewel in the roughBostonPerformance is a jewel in the roughBostonPerformance is a jewel in the rough
when was your last tune up? I'd start basic first- plugs and oil
[CENTER]"Not the victory but the action; Not the goal but the game; In the deed the glory," -Hartley Burr Alexander
Old July 28th, 2008, 08:32 PM   #3
Moderator
wraitherx's Avatar
'99 SVT Cobra
wraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud of
iTrader: 11 reviews
does your car/or did your car make any weird sounds?
Old July 28th, 2008, 09:26 PM   #4
changed the plugs about 6 months ago. oil change about 2000 miles ago. and for wierd sounds nothing was unusual untill i took off. no noises at all.
Old July 28th, 2008, 10:43 PM   #5
94v6blkndred's Avatar
02 Turboed Saleen Clone
faster than my v6
94v6blkndred will become famous soon enough
Send a message via Skype™ to 94v6blkndred
replace your pcv valve...clean your IAC maybe... maybe get your injectors cleaned.?
http://www.dewayneamiller.com/uploads/94v6blkndred_sig.jpg
94v6.CAI,Exhaust,3:73s-needs rear end rebuild
02GT/Saleen.built motor,62mm turbo 412hp/446tq @10psi,stock TB and intake
Old July 29th, 2008, 02:24 AM   #6
scubasteve041186's Avatar
2004 mustang 40th annv.
scubasteve041186 is on a distinguished road
Send a message via MSN to scubasteve041186
pvc and check your MAF sensor. you might have gotten it dirty some how. maybe take a look at the plugs and wires and then check the fuel filter ( when did you change that last?) after that try seafoaming it maybe.
right now it sounds like the MAF or something with the fuel
( a vacum leak wouldn't do it would it? not sure.. )
Old July 29th, 2008, 07:17 AM   #7
prodrifterx's Avatar
prodrifterx is on a distinguished road
Send a message via AIM to prodrifterx
Thanks
had this issue on a 04 silverado...same issue and it was a clogged bank2 converter......different vehicels yet diag and most things are alike when working on vehicels...justa a thought.....
get ur self a back pressure tester....and take out pre 02 on either side and check exhaust pressure at 2500rpm steady.....more than 1.5psi at any point of rpm even idling and so forth you have a restriction.
Originally Posted by Fryrice View Post
You cant buy horsepower off a Autozone shelf. If you wanna play you gotta pay.
Old July 29th, 2008, 07:11 PM   #8
thanks for the help guys, me and my dad are gonna take a whack at it tomorrow again. so we'll check some of that stuff
Old July 29th, 2008, 11:04 PM   #9
Hourofpain's Avatar
2005 Torrid Red GTO m6
Hourofpain will become famous soon enough
do me a favor
listen to your exhaust at idle and see how it sounds
is it choppy like a misfire?
1996 Cobra
To be sold...
2005 M6 Twin Turbo GTO Torrid Red
Fully Forged LS2 Block Built to handle 1000RWHP. Fully ported Dart Heads. Edelbrock Jr Intake. Custom cut upper intake plenum. APS twin Turbo System with APS twin Fuel pumps.
Old July 29th, 2008, 11:09 PM   #10
2000 Mustang V6
El_Cangri will become famous soon enough
Send a message via AIM to El_Cangri Send a message via MSN to El_Cangri
check your maf, sparks and cables...
One time I stuck my dick in my own butt by accident.
Dont laugh it was dark in the room.
Old July 30th, 2008, 10:22 AM   #11
MM's Resident Ricer
GreenFaleen's Avatar
2006 Scion tC
13.001@113
sounds like your MAF to me
NCMM #9
Threads Similar to: got a problem. need help
O Jesus! Problem After Problem! mustangmanic 99-04 94 March 28th, 2008 04:36 PM
umm have a weird problem? idle problem? blue03mach1 99-04 16 March 4th, 2008 01:03 PM
s/c problem pr gt 2005 - 2010 17 December 28th, 2007 03:13 PM
have a problem bloo4.6 99-04 14 May 11th, 2007 09:30 AM
Big Problem Or Little Problem? wraitherx 5.0 Mustangs 17 November 21st, 2006 09:45 PM
