Whats The Difference
ok i am going to do a custon intake for my new motor when i build it to put a roots sc on top of split port heads and i was woundering what the difference between the eaton m 90 and the eaton m 112 is
muneris pro ego
m 112 is newer and better lol... the m90 came off of the early 90's supercoupes and the m112 came off of the 03-04 cobras... the m112 is a stronger and larger supercharger and you will see more gains with it.. you may haveta modify your hood a bit more with the m112 as well... there is another person on here with an m112 and its right on his hood scoop...
Buy my M90 Kit and my Gears and T-Loc! MM ZDC - Alaska Base Commander MM+ Cleavage Club #24 MM Cares Crew / Military Crew M2C2 President / USCG - OS2 ![]() |
ok for the next question now i know its off of a cobra and when i do m y motor build i was also plannin on getting a cobra r hood looks like the stock hood with the exepthion of the scoop and raises up another 2 inches so the question is if i cut and weld my lower intake manifold can i put the m112 on top of my motor
lol theres really no other place to put it....
but there used to be a guy with a cobra s/c, you could see the s/c from the hood scoop...but i think the cobra R hood or a cowl hood would look cooler
muneris pro ego
a cowl would definitely work.. depending on how large the cowl is.. and the cobra r should work as well because it is a type of cowl itself... just designed a lil different
Zoolander
04 Cobra #2260/3768 1/820
yea the cobra r is a cowl hood with heat extraction scoops. Should be big enough. I think it is, it just has to be taller than the top of the gt scoop for enough clearance
i want the hood with no air inlets on it it just rasises up another level
Threads Similar to: Whats The Difference
| Whats the difference? | usafimj | 2005 - 2010 | 3 | September 27th, 2007 12:38 AM |
| WHATS THE DIFFERENCE BETWEEN 99 and 00 | Kenzo | V6 Mustangs | 6 | August 27th, 2007 04:49 PM |
| Whats The Difference Between A GT And A LX? | rudedude101 | General Tech | 4 | October 29th, 2006 02:06 AM |
| whats the difference?? | 5litercobra | 5.0 Mustangs | 2 | August 27th, 2006 01:45 AM |
| Whats the difference? | topflitecop21 | 99-04 | 4 | August 5th, 2006 07:12 PM |
