custom stud mounted rockers
Old December 6th, 2005, 10:12 AM   #1
99mustang232's Avatar
1999 Ford Mustang V6
99mustang232 is on a distinguished road
here is some info i found out about a custom stud mounted rocker for the 3.8/4.2 heads...
supersixmotorsports.com sells a custom comp cams pro magnum stud mounted 1.7 rocker...
"Stud Mount Adjustable Roller Rocker Arm Kit:
This kit is the ultimate roller rocker arm kit for the 3.8/4.2 and includes custom Comp- Cams Pro-Magnum stainless steel 1.7 ratio rocker arms, studs, locknuts, guide plates, anti-friction inserts, and shims. Designed and tested on our 10-sec V6 racer, this setup provides the ideal geometry for late model 3.8/4.2 7mm valvetrain and returns the pushrod to the center of the pushrod guide hole where it belongs. Hardened
pushrods required (not included)."
my question's and ssx answers;
what is the mfg part# for the comp cams pro magnum stud mount rockers? is their head machining required to use these?
Actually, there is no part number for these and you won't find them listed in the CompCams catalog. They are machined to our requirements on a custom order basis. We have them available for order. Its the best rocker arm setup out there and fixes the geometry issues that exist with any of the other 3.8 rocker arms out there based on the 351C rocker body. The kit includes the rocker arms, studs, guide plates, and shims. We can start you off with an approximate pushrod length but you must use a length checker to measure the proper length, then order the pushrods.
Tom Yentzer
Tom, once ordered how long should one plan on waiting, or do you have some in stock?
We can supply them in about a 2 week lead time. They are designed to be a direct replacement, hence the use of 8mm studs. We thought about using bigger studs, but that requires drilling and tapping rocker bolt holes which most people don't want to do, and 99% of the market uses normal springs, rpm limits, etc so the 8mm studs are not a problem for masses. We've run ours to 6700 rpm with 135 pounds on the seat with no problem.
What are the shims for? Well, the 3.8 rocker pedestals are recessed, the wrenching hex on the stud gets trapped between the rails on the pedestals, the shims are used to keep the wrenching hex from being trapped by the rails.
Tom Yentzer
Old June 1st, 2007, 01:10 AM   #2
muneris pro ego
Ninjawafers!'s Avatar
97 5.0 Exploder AWD
snow has nuthin on me
Ninjawafers! is a splendid one to beholdNinjawafers! is a splendid one to beholdNinjawafers! is a splendid one to beholdNinjawafers! is a splendid one to beholdNinjawafers! is a splendid one to beholdNinjawafers! is a splendid one to beholdNinjawafers! is a splendid one to behold
Send a message via AIM to Ninjawafers! Send a message via Yahoo to Ninjawafers!
wow... check out how old this thread is... coolies
Buy my M90 Kit and my Gears and T-Loc!
MM ZDC - Alaska Base Commander
MM+ Cleavage Club #24
MM Cares Crew / Military Crew
M2C2 President / USCG - OS2
Threads Similar to: custom stud mounted rockers
header stud mpboy General Tech 0 August 28th, 2007 01:48 AM
New wheels mounted jivepepper 99-04 18 April 24th, 2007 11:37 AM
grill mounted fogs artisan00 Visual 28 March 25th, 2007 06:53 PM
Side-Scoop Mounted Turbo Kits From JMS Products 99mustang232 General Tech 31 January 22nd, 2007 06:26 PM
Any pics of Mounted Auto Meter tachs? Areteracing 96-98 7 January 19th, 2007 09:18 AM
