Discussing Ignition switch or starter? in the V6 Mustangs Forum. Question, again.... Every once in a while (like once every 2 weeks or so) when ...
Old November 22nd, 2006, 12:48 PM   #1
Question, again....
Every once in a while (like once every 2 weeks or so) when I go to start my car, it will start to turn over, and then when its just about to start, it like stops. I dont really know how to explain it, it makes a noise, not like a grinding but kind of.... like i turn the key, it wants to start, and then just stops, but then I go to start it again and it starts right up.
Would that be my starter starting to go or maybe I need a new ignition switch or the contacts are dirty?
This is for a 2000 V6
Old November 22nd, 2006, 01:50 PM   #2
chevy_killer's Avatar
2000 v6 Mustang
it could also be the battery or the altinator....if their not holding a charge then youll have that problem...but it sounds to me like its the altinator.....but i dont know for sure....i would take it to a machanic and let him do a diasgnostics on it to check it out
The LS1 was finally subjected to a paternity test, and it's daddy was to '03 Cobra
Old November 22nd, 2006, 01:53 PM   #3
How often do starters and altinators go? I mean the car has 70K on it right now. Should I just replace these things now and get it out of the way? That way I dont have to deal with it down the road, I mean I know it sounds stupid to replace something that isnt broke yet, but nothing really has had to be replaced with this car, until I got my hands on it, and if its around that mileage where things are just going to start going on it I might as well nip it in the butt now..
Old November 22nd, 2006, 02:00 PM   #4
2000 v6 Mustang
ya it wouldnt hurt their not that expensive.....but also i forgot to mention this earlier it may be your fuel regulator.....and to check your battery look at it and see if its puffy on the sides if it is its bad or if you crank up your car and turn it off with your lights still on and they go dim its your battery but if it isnt then it may be the altinator...you can go to discount and get one and put it on in an hour
Old November 22nd, 2006, 02:06 PM   #5
Yeah I might as well do that while im at it. The battery is only a few months old so I hope that isnt it.
But thanks. I always go with the worst case scenario instead of the easiest stuff first. I need someone to keep me in line lol
Old November 22nd, 2006, 02:50 PM   #6
Air Embolism Assassin
Cricket's Avatar
8.876@80.013 1/8th
maybe your car is on it's period every 2 weeks?
Have we officially crossed the line now? I just got Douche chills. Thanks a lot JP.
I gave zippee douche chills
Blue Mustang Society
Modded Mustangs Breast Cancer Awareness Bike Thread
Old November 22nd, 2006, 02:51 PM   #7
LOL thats what Im starting to think...
Old November 22nd, 2006, 02:53 PM   #8
in florida we have discount auto parts and autozones that do free checks for battery , alt and starter if you have one go there its free!!
Never argue with an idiot, because when you do u bring yourself down to their level, and they beat you with experience!!
Old November 22nd, 2006, 03:07 PM   #9
Yeah, thats another thing I didnt even think about doing.... I know my battery is fine, or at least it should be and if its not then they have to replace it anyways. But yeah I guess I should do that
Old November 23rd, 2006, 06:08 AM   #10
hey look at ur battery does it have white stuff around the connecting thingy (i dont wats its called) if so just get some baking soda and a bit of coke or someting. put alot baking soda on the connections and then just dropa little coke on it. it should clean up a bit then just get a wire bruxh and clean it off that should work i think. i tried that out on my car cuz thats wat mine would do it just stopped doing after that but i dont know if its safe to drop a liquid on a battery.
Old November 23rd, 2006, 01:48 PM   #11
1995 BMW 325i
i just pour alot of coke on it. then lick it up... ok maybe not lick it up but you get the picture. its fine
http://img.photobucket.com/albums/v3...5/cpc1copy.jpg
Originally Posted by Cesar2cool
lol i use my car for speed
Old November 24th, 2006, 04:07 PM   #12
Or I could just buy a new one... Thanks though, but I will refrain from dumping stuff on my battery terminals lol...
Old November 24th, 2006, 04:35 PM   #13
Actually, in all seriousness, a can of Coke-Cola really will work quite well to clean up the battery terminals, and the battery.... Dump it on.. let it sit a bit, then hose it off with water... works fairly well
Old November 24th, 2006, 09:07 PM   #14
2000 v6 Mustang
i use baking soda and water works just as good less sticky
Old November 25th, 2006, 02:25 PM   #15
Well, this is true... But damn, it sure doesn't make the neighboors scratch their heads like it does when you pop your hood, crack a coke, take a drink, then dump it on your battery
Old December 2nd, 2006, 09:06 PM   #16
Another thing that I have noticed about this, is its only doing it on really cold mornings?
Old December 3rd, 2006, 02:41 AM   #17
My67_fastback's Avatar
doubt its the alternator. id say its the starter. or maybe there is a problem with you flexplate/flywheel, or with the contact between the starter and the flexplate/flywheel
TO: Ricers-
1) there's no replacement for displacement
2) my lug nuts require more torque than your engine makes
3) a light car doesn't excuse a weak engine
4) a bottle of pepsi has more liters than your car
eating rice builds muscle
Old December 15th, 2006, 02:36 PM   #18
which of these would the cold affect if any? Because its only doing it when its like freezing temps. It has been fairly warm lately, 40's but when it was dropping right down to the teens, low 20s at night and I was starting it early in the morning when it was in the high 20's low 30's it would start to start then cut out... Just seems a little odd its only doing it when its really cold out
I dont know, maybe its just in my head.. But it hasnt done it in a while now
Old December 15th, 2006, 03:14 PM   #19
Resident MM Ricer
GreenFaleen's Avatar
2006 Scion tC
13.9@103/8.9@81
Mine did that for a bit it was my battery we changed it now it starts mean
Scion Tc-strup racing header, CAI, Ground Kit, NOS 100shot, Custom suspension, Doc. I 50% STS
Thanks To My Sponsors:
Strup Performance
Old December 15th, 2006, 03:17 PM   #20
I dont know maybe Ill just get another new battery.... Still under warranty, so Ill just have them swap it out I guess
Threads Similar to: Ignition switch or starter?
'68 ignition switch assembly HELP !! paintlover70 Classic Mustangs 7 April 23rd, 2007 12:44 AM
ignition switch or what? 97TunedMustang Engine 2 November 24th, 2006 06:53 PM
Focus Ignition Switch OTreborO All Other Vehicles 3 November 9th, 2006 11:32 PM
Starter or Starter Relay cobralini 5.0 Mustangs 7 August 3rd, 2006 07:34 PM
Electrical part of ignition switch Mustang8719 5.0 Mustangs 3 June 21st, 2006 08:26 PM
