CEL Code P1443
LinkBack (7) Thread Tools
Old August 6th, 2008, 08:53 PM   7 links from elsewhere to this Post. Click to view. #1
MustangMo's Avatar
1993 1.8 Acura Integra Ls
Slow
MustangMo is on a distinguished road
Send a message via AIM to MustangMo Send a message via Yahoo to MustangMo Send a message via Skype™ to MustangMo
CEL Code P1443
I got em to check my cel code at advanced auto today n this is the code P1443 Auxiliary emissions controls. What is it?
{Burn Rubber Not Your Soul}
Old August 6th, 2008, 08:54 PM   #2
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
buy a new gas cap
Old August 6th, 2008, 09:03 PM   #3
Modified88Dreamer's Avatar
1988 Mustang GT
N/A
Modified88Dreamer will become famous soon enough
Code P1443 means that the evaporative emissions charcoal canister purge sensor did not detect any flow when the canister should have been purging into the engine intake system. The purging, controlled by the computer,takes place when certain conditions are met, such as engine speed and temperature.What the computer operates to effect this purging is a 12 volt solenoid valve, solenoid means it has a moving piston in it which covers/uncovers ports in the valve so that flow does/does not take place. The "gunk" coming out of the charcoal canister will sometimes cause this piston to stick, resulting in purging not taking place when it should, the sensor in the purge hose detects this and sets a fault/trouble code and also turns on the "Check Engine" light. The electrical windings in these valves seldom fail, but anything is possible. To locate and check this valve, first find the charcoal canister, it will be a round or rectangular black plastic "box" with several different size hoses attached to it. If in doubt that you've found it, look at the bottom, there will be a plastic foam filter there---make sure it is not plugged up---. Once you've located the canister, start following the hoses attached to it. One will go towards the engine, follow that one along until you find the control valve that it attaches to, that's the valve that's not operating. Several things you can do now, just buy a new one and hope it is not the wiring or computer that's at fault. If you want to check it and the wiring, first, with key off, disconnect the two wire connector from it. Use a 12 volt test lamp, turn the key to "run" and check for current at both wires in the connector, one sould have current. Next, connect the test lamp between the two wires in the connector, start the engine and let it warm up, then run the engine up to around 1500 RPM or so, the test light should come on, if it doesn't, then it is the wire that was "cold" when you checked for power at the connector. or the computer. If the light comes on, then it is the valve. Remove it from the vehicle and clean it with an aerosol can of carburetor cleaner,use the "straw" that comes with the can and spray the cleaner into both hose nipples on the valve, alternatly spraying and shaking the valve. When you no longer get brown "gunk" coming out of the valve, reinstall it in the vehicle, but leave, if possible, the hose from the cannister disconnected. Start the car and let it warm up, (if need be), now raise the RPMs to 1500 or so. valve should now open and a vacuum should be present at the open nipple. If so, the problem is cured. On some OBD II equipped vehicles, repairing some problems will cause the computer to turn off the check engine light if the fault is no longer detected, other vehicles require that the computer be interfaced with and the code purged with a scan tool.
"I know that son-of-a-bitch is cheatin! Cause, I'm cheatin and he beat me"!
Old August 6th, 2008, 10:00 PM   #4
The soul stealing Ginger
dgt_mustang's Avatar
2001 Mustang 3.8l
dgt_mustang is a jewel in the roughdgt_mustang is a jewel in the roughdgt_mustang is a jewel in the rough
Send a message via AIM to dgt_mustang Send a message via Skype™ to dgt_mustang
Get another job, get 2 more jobs, get your own place, work, live, fuck, eat, life, happy.
Old August 7th, 2008, 01:04 AM   #5
MustangMo's Avatar
Slow
ok thanks. So I should prob get it fixed asap right? N is it ok to drive it until i get it fixed?
Old August 7th, 2008, 01:21 AM   #6
MWWarlord's Avatar
1995 Mustang convertible
MWWarlord will become famous soon enough
Great post!
MWWarlord
check out my garage for pics and a complete list of mods.
http://www.tricktuners.com
Old August 7th, 2008, 01:27 AM   #7
1988 Mustang GT
N/A
Originally Posted by MustangMo View Post
ok thanks. is it ok to drive it until i get it fixed?
As long as you haven't noticed any driveability problems.
Old August 7th, 2008, 01:35 AM   #8
MustangMo's Avatar
Slow
ok thanks again
Old August 7th, 2008, 04:40 AM   #9
MIA
1995 3.8L
MIA is on a distinguished road
Send a message via AIM to MIA
wow.....great post 88...but i like HMUSN's better for readability on a skim...
but +1 on typing that up.
WTS Stock rear performance speakers. 6"x8", works fine. Got new alpines :-) PM for Details/with offer.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/v6-mustangs/83484-cel-code-p1443.html
Engine code P1443 Mustang Problem Diagnosis - Car Questions, Answers, and Discussion This thread Refback September 25th, 2011 03:38 PM
Engine code P1443 - Car Forums and Automotive Chat This thread Refback June 3rd, 2010 03:27 PM
Ford Code 1443 - Kosmix : Reference, Videos, Images, News, Shopping and more... This thread Refback May 4th, 2010 11:50 AM
Engine code P1443 - Car Forums and Automotive Chat This thread Refback April 28th, 2010 03:40 AM
Engine code P1443 [Archive] - Automotive Forums .com Car Chat This thread Refback November 9th, 2009 05:06 PM
Engine code P1443 - Automotive Forums .com Car Chat This thread Refback November 12th, 2008 05:50 PM
Engine code P1443 - Automotive Forums .com Car Chat This thread Refback October 23rd, 2008 07:58 PM
Threads Similar to: CEL Code P1443
Trouble Code P1443 Pressure Sensor? Tlord18 V6 Mustangs 6 July 17th, 2008 01:22 PM
Sluggish and Pinging P1443 Code ? kevnsue 96-98 6 October 31st, 2007 08:53 PM
Code P1443 After using seafoam!??! 97redgt Modular Mustangs 3 September 28th, 2007 02:22 PM
rough idling, code p1443 cyrax01 96-98 6 August 22nd, 2006 10:44 PM
Code P1443 ? Please help 97Cobra 96-98 2 April 16th, 2006 05:47 PM
