“Eaton M-90 Supercharger”
In about a week or so my 1996 3.8L will be in the shop, im installing an “Eaton M-90 Supercharger”(parts from a 90-91 T-bird)
What Ľ mile & 0-60 times should I be expecting after its been installed? (my car already has Magnaflow duel exhaust & k&n air filter) |
hey im doin the same thing! cant wait for it
i heard it should put out around 200 hp and 300tq |
#3 | |
a procharger at 11 psi wont give you 200hp. it'll be close but the roots that you guys want generally give out less then the procharger...but its cheaper, you get what you pay for, its a good buy but you wont see 200hp added on that m-90 at 6psi which is my GUESS on how much you'll have after installing plz dont think im tryin to be an ass
#4 | |
not like...it will add an extra 200 ?
#5 | ||
but deffinitly not 300tq not in the wheels or adding
th stock t-bird puts out around 200hp and 300tq soo im guessing just adding the m-90 and intercooler would match that.
deff not an extra 200hp and w/e... that would be crazy i think the m-90 puts out around 10psi. do i need new injectors with the charger?? does anyone know how much the intercooler really adds? if its not significant then the plumbing would me so much easier without it. my car right now is under 140hp, so i think 200hp is about right and it has around 200tq right now as well so i believe that 300 is close as well. remember these are the single port, crappy 6's. especially my 94 |
m-90 adds at the most 40hp if done correctly and you have almost new everything.
Lee ATI,CAI, 1 5/8th" Headers, Dynomax dual exhaust(Turn Downs pre-axle), SCT Chip, Cut Springs (2"Front 1 1/2"Rear), FR 9mm wires, Ram Air, 78mm MAH, EGR delete, Rear Sway bar,Sub-Frame Connectors. |
u do need new fuel injectors
#9 | |
Re: “Eaton M-90 Supercharger”
2003 Mustang Mach1 1995 Thunderbird LX 4.6L; 1995 Mustang 4.2L; Eaton MPX Supercharger, 11.61 @ 118mph |
An ATI Procharger on a 96 at 11psi will definitly put it above and beyond the 200hp mark. It will also outdo the Eaton as far as ease of install, and power output.
but you cant compare the $5,000 for the procharger and the $500 for the m-90.
similar car, but my 98 gtp grand prix, intake exhaust and 11lbs of boost put down 231hp and 307 ft lbs,
I later added a cam, heads, stall, pcm ported intake mani and s/c and it put down 342hp and 421ft lbs. It can be done, just gotta go about it in the right way all of this on a non intercooled m90
Just a truck 5.4 3v: 264hp 317ft lbs rock stock piecing together the next project faster than your first sexual experience |
#13 | |
#14 | |
man i went and test drove a 96 GTP that thing knocked my socks off. i was really surprised.
#15 | |
#16 | |
oh then i guess it was a 97 or later then. it was a supercharged 3.8. i thought it was 96 but i guess not. it was nice though
#17 | |
muneris pro ego
i dont know if the m-90 has the potential to put out the same hp as the procharger.. the m-112 maybe but i dunno about the m-90
Buy my M90 Kit and my Gears and T-Loc! MM ZDC - Alaska Base Commander MM+ Cleavage Club #24 MM Cares Crew / Military Crew M2C2 President / USCG - OS2 ![]() |
i dont even kno if im keeping the engine for the long run but for some quick and cheep hp, the m-90 looks pretty good.
#20 | |
nuthing else does that for that price
Threads Similar to: “Eaton M-90 Supercharger”
| 03-04 Cobra Eaton Supercharger on your 2V | White99stang | 99-04 | 119 | October 28th, 2010 04:11 AM |
| Eaton M90 Supercharger | 2002stang | V6 Mustangs | 4 | October 10th, 2007 05:05 PM |
| Eaton m90 supercoupe supercharger..... | 99v6stang | V6 Mustangs | 3 | May 17th, 2007 12:20 AM |
| 03-04 cobra eaton supercharger | noob | 99-04 | 15 | April 6th, 2007 03:34 AM |
| Eaton Supercharger | donny82277 | General Tech | 1 | February 24th, 2007 02:13 PM |
