water pumpage.....
i got outside this morning and noticed a puddle of coolant forming beneath my car....noticed it was dripping off the crank pulley area so figured its the water pump....is there anyway to tell if is just the gasket or? ill most likely be getting a new one anyone but i just wanna know....the weep hole on the top isnt leaky at all so i guess thats a good thing but the exact location of the leak i cant see cause of all the shit in the way haha
![]() 94v6.CAI,Exhaust,3:73s-needs rear end rebuild 02GT/Saleen.built motor,62mm turbo 412hp/446tq @10psi,stock TB and intake |
There are at least three possibilities in that area. 1. the water pump 2. the water pump gasket 3. the front cover gasket. This is assuming it is not leaking from above the pump e.g. a bypass hose. If none of the gaskets have been disturbed, I would suspect it is the water pump seal that is leaking.
see i was thinking a seal as well...but..if im gonna replace the seal might as well spend 30 and get a pump while its off...thanks for the help
Threads Similar to: water pumpage.....
| Water Wetter | blackhavok | 2005 - 2010 | 7 | February 20th, 2008 08:26 PM |
| Water | mpboy | 5.0 Mustangs | 8 | January 18th, 2008 01:38 PM |
| HOT WATER!!!!!!! | black95conv | 94-95 | 6 | July 26th, 2007 02:15 PM |
| Water Temperature | burnout5.0 | 94-95 | 5 | July 9th, 2007 06:07 PM |
| what water pump | 95wip | 5.0 Mustangs | 2 | June 25th, 2007 01:04 AM |
