Custom exhaust today!!
Old August 11th, 2008, 09:00 AM   #1
Archy88 is on a distinguished road
Send a message via AIM to Archy88 Send a message via MSN to Archy88
I'm finally making the move & getting my custom exhaust done today. I had originally wanted the delta series flowmaster, but they don't have them. So i'm going with the original 40's. Please tell me I made the right choice ;-). Well hopefully I can at least get some pictures up tonight!
http://img.photobucket.com/albums/v70/TazMan1688/Mustangforumwarrow.jpg
Old August 11th, 2008, 10:45 AM   #2
Hip Hop Artist
Youngin's Avatar
Byebye V6~
Welcome Home New Pony :P
Youngin is a glorious beacon of lightYoungin is a glorious beacon of lightYoungin is a glorious beacon of lightYoungin is a glorious beacon of lightYoungin is a glorious beacon of light
Send a message via AIM to Youngin
get R done.
ItaliStang Made.. Maybe Red But Makes One Hell Of A Sig
http://www.myspace.com/moddedmustangz
Modded Mustang's Song
Old August 11th, 2008, 11:23 AM   #3
Fashion Guru
gooberhead320's Avatar
gooberhead320 has a spectacular aura aboutgooberhead320 has a spectacular aura aboutgooberhead320 has a spectacular aura about
you made a good choice. its what i have. oh and get stainless steel
Originally Posted by 93hatch View Post
goobers car would whoop on ur fox so you sir fail
im so gay i wish my gf was as pretty as goober
I love 93hatch
Old August 11th, 2008, 06:45 PM   #4
The George Forman of Keepers
JASonic's Avatar
JASonic is a name known to allJASonic is a name known to allJASonic is a name known to allJASonic is a name known to allJASonic is a name known to allJASonic is a name known to all
iTrader: 20 reviews
Send a message via AIM to JASonic
A little thought on exhaust. This only applies to cars that have less than 80,000 miles or are younger than 8 years old. Ford admitted that there was a design flaw with the A/C unit "dripping" condensation onto the midpipe causing it to crack right after the manifold.
Just as a heads up, if you do a cats back set-up, it does not void that warranty. Mine was a cats back set up so they honored it and are still in the process of fixing it at no charge.
There is one issue though. Apparently, muffler shops all do things a little different. The one I went to welded everything from the mid pipe back. I guess on a stock exhaust there is a "flange" somewhere between the mid pipe and cats. For whatever reason, my exhaust shop removed the flange (which allows you to take the front part of the exhaust off leaving the back on the car intact) and now its just straight pipe that is welded.
The problem is that they had to remove the entire exhaust in one piece because my muffler shop put on my custom exhaust without the flange. It made things very difficult. To make it even harder, I have a vert so they had to work around the cross supports as well.
I guess the bottom line to this is if you think of it, ask the muffler shop to make sure the exhaust is easy to disconnect. That way if you get a cracked mid pipe or manifold, you (or the authorized ford dealer) will be able to easily remove that portion of the exhaust without having to remove the whole thing. This almost cost me my "free" fix to the drip and crack problem.
Old August 11th, 2008, 07:11 PM   #5
They are actually doing 2 1/4", with a custom H. Flowmaster 40. 3.5 Inch rolled tips w/ the 45 degree slash cut. Unfortunately I won't be the one picking it up from the shop. Going to be a LONG day @ work.
They are most of the way done, so I'm hoping that they made it easy to disconnect...thanks for the info sonic. I've still got another 30k miles & 2 years to go!
Old August 11th, 2008, 09:27 PM   #6
Safud: MM's Resident Hadji
Safi's Avatar
00 v6 & 99 Cobra
Safi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud of
Send a message via AIM to Safi Send a message via MSN to Safi Send a message via Yahoo to Safi
And to add to what JASonic said...Have the guy doing the exhaust just fab up a little blocker to keep the A/C compressor water from dropping on the exhaust.
Originally Posted by asiansensation78 View Post
Yeah Safi beat me on OG status lol
Threads Similar to: Custom exhaust today!!
hanging exhaust/custom exhaust patwrecked 5.0 Mustangs 5 June 3rd, 2008 12:24 AM
Custom vs Kit exhaust pilot37 V6 Mustangs 30 March 20th, 2008 01:12 PM
Custom exhaust DanishStallion 99-04 41 April 12th, 2007 01:55 PM
Custom Dual Exhaust? Orangester V6 Mustangs 2 January 23rd, 2007 10:50 PM
custom exhaust plan? help?! Orangester V6 Mustangs 4 January 12th, 2007 12:58 AM
