TRUETRAC
I am getting a 1999 - 2004 V6 Mustang. I have been reading that if you burn out in a V6 that only one tire will spin and burn out. So people are telling me to buy a detriot truetrac so both tires can spin. So i am just wondering if this is the right thing.
http://www.drivetrainspecialists.com...ruetrac-1.html |
#2 | |
get t-lok. everyone gets t-lok
everybody is telling me dont buy the t-lok because it breaks down easily, and i am going to be doing alot of burn outs, so they told me to go for taht one
#4 | |
ive never heard of anyone having problems with it. i dont think a moderator, atlanticblue99, would suggest something that he didnt think was of high quality
The t-lok is a cluth-type differential unit. It CAN go out... if you abuse the living crap out of it...... Which, would then require that you install new clutch disks into it....
The link you have goes to, I believe, a gear type differential unit which would be a bit stronger than the t-lok, but also you would suffer a bit worse of a ride when going around corners as the gear system "ratchets" in order to disengage one axle... it can sound noisy, and sometimes vibrate the car...... If you just want to do 2 tire burnouts, just put a Powertrax unit into your open differntial.... |
#6 | |
nvm
I guess I should also toss in that I don't know many instances of T-Loks going bad....
i think the only way it would go bad fast is if you go to the track and race it every weekend but youll have money to fix it tho...but i wouldnt worry about it get the t-lock it wont wear your tires out as fast....but it will wear your tires out faster than the stock diff.
The LS1 was finally subjected to a paternity test, and it's daddy was to '03 Cobra |
11.21@123 -150 shot
![]() iTrader: 1 reviews
I am considering a detroit truetrac. I have blown my trac lok out after one season on slicks. For a v6 unless you are FI, you would probably be okay with the trac lok.
Threads Similar to: TRUETRAC
| Detroit Truetrac | orangeRcode | General Tech | 3 | November 14th, 2006 10:58 AM |
