MY next mod 8.8 rear and 4.10's
Old August 16th, 2008, 06:07 PM   #1
2000 V6
ByPopularDemand is on a distinguished road
Send a message via AIM to ByPopularDemand Send a message via MSN to ByPopularDemand
Ok so I was lookin on line and all the 7.5 in posi units I saw were in the 200 dollar range before tax and shipping. Then I came across a 8.8 rear out of a 98 GT for $250 It happened to be a complete rear also. Standouts I noticed were drilled and slotted rotors, and new brake pads, a traction bar, and of course because it is a limited slip as opposed to oped diff. also has springs and shocks, but ill prolly sell those since as far as I know theyare not aftermarket upgrades. The bad...the calipers, traction bar, and shocks(should I end up using them) are red, which wont go well with my whole black and blue theme. So far the best offer I have gotten is $150 for a set of new 4.10 gears. So once I get the 4.10(lots of them were up for sale locally before)I will just need 3/4 inch wheel spacers and then Ill be ready to get it geared and installed. Of course the first, and cheapest order of business will be painting the calipers and traction bar lol. So now a few questions: Are used gears safe? How hard is a rear end swap to do? what all is involved? What would I need?(I can get access to a buncha tools and a lift) How hard is it to istall gears since the rear is currently out of the car? And lastly would there be any hope of getting traction with the stock wheels and 205's on them?
2000 V6 vert
Mac LT headers, Mac O/R H-pipe, Mac CAI, ASP 25% underdrive pulley(r.i.p), SCT tune, 8.8 rear and 4.10 gears.
Old August 16th, 2008, 10:28 PM   #2
1994 Mustang Coupe
gQQgsJr is on a distinguished road
used gears arent safe. a rear end swap isnt too difficult especially since you can use a lift. its just basic unbolt the old and bolt up the new. you need to have someone experienced to change the gears. everybody else will say the same thing. as far as traction... im not sure
Old August 17th, 2008, 12:56 AM   #3
00 V6 & 09 GT
13.37@104.4mph--BONE stock GT
if your asking about doing gears most likely you should do it yourself
you'll need a dial indicator or a way of checking backlash
plus a torque wrench
[SIGPIC][/SIGPIC]
Acmillr loves me
Old August 19th, 2008, 01:27 PM   #4
2000 V6
Well on the bright side I found someone who knows how to do gears, And after I could probably use his shop to do the rear end swap. What are everyones thoughts on 4.56 gears?
2000 V6 vert
Old August 19th, 2008, 03:56 PM   #5
101fng's Avatar
2009 Mustang GT
101fng is a splendid one to behold101fng is a splendid one to behold101fng is a splendid one to behold101fng is a splendid one to behold101fng is a splendid one to behold101fng is a splendid one to behold101fng is a splendid one to behold101fng is a splendid one to behold
too damn tall imo
my rules:
1) at least pretend like you know thrasher and I are together
2) try to arrange a personal meeting with thrasher, and it will only be a matter of time before you meet 101fng
Old August 19th, 2008, 04:06 PM   #6
1994 Mustang Coupe
yeah 4.56 are way too much.
Old August 19th, 2008, 04:29 PM   #7
AJRight 2008's Avatar
AJRight 2008 is on a distinguished road
Send a message via AIM to AJRight 2008
Also i believe if im not mistaken, the rear end out of SN-95 are shorter then New edges i was looking to do the same thing to mine but a guy on a local forum im on use to work for SVT and said it would not work. I'll find it and post it up
Old August 19th, 2008, 04:34 PM   #8
This is what he said
With drums an FOX rear is 59.25 wheel mount to wheel mount. With FOX track discs, it is 59.5. An SN95 from 94 to 98 is 61 inch wheel mount to wheel mount. The 99 and later are 62 inch. All dimensions include the brake drums or rotors.
the v6 brake line is in a different spot than the 8.8
The 86-98 8.8 housings are the same dimensions, only the 94-98 axles are 3/4" longer than the Fox ones. The 99-04 housings are actually about 1.5" wider, and the axles are about 1.5" longer than the Fox ones, making the 99-04 complete rears about 3" wider in total than Fox rears, or about 1.5" wider than the 94-98 rears.
Old August 19th, 2008, 05:29 PM   #9
2000 V6
Yeah since I'm using the 98 rear, I'm gonna need 3/4 inch wheel spacers. And how does 500 for a rebuild and install of the gears? For that price he's also gonna just swap the rears.
2000 V6 vert
Old August 19th, 2008, 10:02 PM   #10
Assassin_Dan's Avatar
1998 Mustang V6
Assassin_Dan is on a distinguished road
Send a message via MSN to Assassin_Dan
I thought it was the other way around?!?!
CAI, Screamin' Demon Coil, Livewires, Steeda Tri-ax, Steeda Clutch Quadrant and Adjuster, UDP, 8.8 rear end with 3.73's, 1/2 inch VAP intake spacer, SCT X3.
Old August 19th, 2008, 11:19 PM   #11
Apparently not....
Old August 19th, 2008, 11:55 PM   #12
riddlee josh's Avatar
1998 mustang 3.8l v6
riddlee josh is on a distinguished road
will a 94 to 98 gt rear end fit in a 98 mustang v6?
RACING
because baseball,basketball,
bowling,football, and golf only
require one ball
Old August 20th, 2008, 12:13 AM   #13
1994 Mustang Coupe
^ yes
Old August 20th, 2008, 12:16 AM   #14
sweet i think that is gonna be my next mod
RACING
require one ball
Old August 21st, 2008, 03:56 PM   #15
2000 V6
Yeah since I'm using the 98 rear, I'm gonna need 3/4 inch wheel spacers. And how does 500 for a rebuild, rebuild kit, and install of the gears with the install kit? For that price he's also gonna just swap the rear ends for me.
So does that sound like a good price?
So far Im out $250 for the rear eng, $50 for the 4.10s(hope this doesnt fall through) and the install, swap and ebuild will be 500.
2000 V6 vert
Old August 21st, 2008, 11:04 PM   #16
Avaric3's Avatar
2002 Ford Focus
slow as fuck
Avaric3 will become famous soon enough
if youre goinna keep those stock tires 4.56 are way to tall youll just do a giant burnout everytime you launch. if you throw some drag radials on there than def go for the taller gear if you dont plan on forced induction in the future
99 V6 Mustang-sold
02 Ford Focus-sold
98 Camaro Z/28-lid, catback
Old August 23rd, 2008, 02:44 PM   #17
2000 V6
Went with the 4.10's so far im at a cost of 300 for the rear end and gears. Now need to find wheel spacers. then rebuild of the rear, the swap and the gearing, and all the parts needed will be 550.
2000 V6 vert
Threads Similar to: MY next mod 8.8 rear and 4.10's
4.10's or 4.30 1BADSTANG V6 Mustangs 8 June 11th, 2008 03:38 PM
4.10's and FI nutterbutter 99-04 11 January 25th, 2008 06:29 AM
4:10's in stock rear 95wip 5.0 Mustangs 8 July 1st, 2007 12:57 AM
4.10's slightly stoopid 96-98 2 May 21st, 2007 12:20 AM
4.10's burin_rubber V6 Mustangs 68 April 14th, 2007 11:19 PM
