engine revs but no power
Old August 19th, 2008, 03:12 PM   #1
cbrown54's Avatar
2003 Mach 1
cbrown54 is on a distinguished road
my friend has a 01 v6 and when he tries to accelerate it revs up but it has no power to it, what is wrong?
Old August 19th, 2008, 03:19 PM   #2
MM's Database Error
WLJohnson05's Avatar
2004 Mustang V6
322.8 rwhp
WLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud of
iTrader: 9 reviews
its missin two cylinders
sorry i had to...
did he try cleanin the air filter and all the basic stuff to help first?
SCT Mass Air Flow Sensor $200
Old August 19th, 2008, 03:25 PM   #3
cbrown54's Avatar
2003 Mach 1
i dont think so ill try that then well see
Old August 19th, 2008, 08:08 PM   #4
04mustang232's Avatar
2004 Mustang V6
14.4@ 96
04mustang232 is just really nice04mustang232 is just really nice04mustang232 is just really nice04mustang232 is just really nice
Send a message via AIM to 04mustang232
tranny issue?
Originally Posted by JBIGBOOTSY View Post
I am currently taking a pro dump as we speak. It also feels like about 3" diameter.
Old August 19th, 2008, 08:53 PM   #5
Fashion Guru
gooberhead320's Avatar
gooberhead320 has a spectacular aura aboutgooberhead320 has a spectacular aura aboutgooberhead320 has a spectacular aura about
my expedition is kind of doing this, but the engine is missing. and it shakes the truck really bad
Originally Posted by 93hatch View Post
goobers car would whoop on ur fox so you sir fail
im so gay i wish my gf was as pretty as goober
I love 93hatch
Old August 20th, 2008, 12:51 AM   #6
Replica R's Avatar
Replica R is on a distinguished road
standard or auto tranny?
Friends Don't Let Friends Drive Rice!
Old August 20th, 2008, 05:02 AM   #7
muneris pro ego
Ninjawafers!'s Avatar
97 5.0 Exploder AWD
snow has nuthin on me
Ninjawafers! is a splendid one to beholdNinjawafers! is a splendid one to beholdNinjawafers! is a splendid one to beholdNinjawafers! is a splendid one to beholdNinjawafers! is a splendid one to beholdNinjawafers! is a splendid one to beholdNinjawafers! is a splendid one to behold
Send a message via AIM to Ninjawafers! Send a message via Yahoo to Ninjawafers!
is it in neutral?
sorry i had to
does it only do it at certain rpms or in certain gears?
Buy my M90 Kit and my Gears and T-Loc!
MM ZDC - Alaska Base Commander
MM+ Cleavage Club #24
MM Cares Crew / Military Crew
M2C2 President / USCG - OS2
Old August 20th, 2008, 12:14 PM   #8
2000 Mustang v6
n/A
SilverSixxer is on a distinguished road
mine does that once a while too, ill give it gas to go and it revs but it just sorta sits there, then all of a sudden it takes off
looking for a comp orange GT
Old August 20th, 2008, 01:59 PM   #9
2000 Mustang
TOOLinYourFace is on a distinguished road
Send a message via AIM to TOOLinYourFace
i have the same problem occasionally with mine... it tends to happen after i start it up.. i usually give it a few minutes to drop the idle and let the engine warm up. after that it runs fine
Old August 20th, 2008, 02:02 PM   #10
Ryno8705's Avatar
Ryno8705 is on a distinguished road
+1 on missing 2 cylinders. Haha.
If it's an auto then you have tranny issues. Time for a 5-speed conversion.
Check the fluid, if you're low that may fix some issues but won't fix the damnage that's already been done.
Old August 20th, 2008, 02:33 PM   #11
2009 ROTY
AzSonicSnake's Avatar
2003 SVT Cobra
11.07@127
AzSonicSnake has much to be proud ofAzSonicSnake has much to be proud ofAzSonicSnake has much to be proud ofAzSonicSnake has much to be proud ofAzSonicSnake has much to be proud ofAzSonicSnake has much to be proud ofAzSonicSnake has much to be proud ofAzSonicSnake has much to be proud ofAzSonicSnake has much to be proud of
Send a message via AIM to AzSonicSnake Send a message via MSN to AzSonicSnake
if its not tranny related, i would start with easy stuff like a fuel filter and what not. maybe its starving...
MM Cobra Club #25 My Autolog Profile
Old August 21st, 2008, 08:57 AM   #12
JMack's Avatar
2000 V-6
JMack is an unknown quantity at this point
It has to be a tranny issue, he didn't say that the motor stalls or boggs down.
If it's not the tranny it could be a brake issue... The e-brake cable could be seized in the rear...
More info on what's happening would be helpful.
Old August 21st, 2008, 11:04 AM   #13
MM's Database Error
2004 Mustang V6
322.8 rwhp
iTrader: 9 reviews
he would know if its the brakes seizing when he gets out from a decent trip and can smell burnt brakes
Old August 21st, 2008, 12:43 PM   #14
Ryno8705's Avatar
A simple test for tranny issues would be to hold the rpms at about 3000 rpms in drive. This would build up pressure in the trans. If a) the car doesn't move or b) the car jerks or lunges forward in a sporadic attempt to move forward, the problem is tranny, no boubt IMO. If it's not tranny, I would have no idea what is going on--I don't think anything could cause that if the engine is running smoothly.
Old August 21st, 2008, 01:29 PM   #15
JMack's Avatar
2000 V-6
he never said the car moves, and if this is the case, he would not know whether or not the rear brakes are seized, however I believe very strongly that this is a trans issue...
Old August 21st, 2008, 03:23 PM   #16
Ryno8705's Avatar
True, so to add to my list: c) if you stomp on the gas and one tire spins and you don't move forward, your other brake is seized. If you rev the engine in drive and it seems to be 'working' yet doesn't move the car at all, both could be seized.... Raise the rear end and try to spin both tires with you hand... Both wheels should spin easy, especially with an open diff.
Old August 21st, 2008, 03:38 PM   #17
GoldieMachs's Avatar
2004 Mustang Mach 1
GoldieMachs is on a distinguished road
Sounds like the tranny prob I had with one of my old daily drivers. When the car was cold you could hit the gas and nothing, then all of a sudden it would take off. Shortly after I had a really hard downshift (thunking) from 2nd down to 1st. I didn't need a whole new tranny but it was leaking. I had the solenoid replaced and maybe some hoses, also had the trans flushed & filled. It has been fine since then, so far so good since last Jan anyway. Check the trans fluid.
Angela
2004 O.W. Mach 1
and assorted Fords
Old August 21st, 2008, 04:02 PM   #18
2000 V6
ByPopularDemand is on a distinguished road
Send a message via AIM to ByPopularDemand Send a message via MSN to ByPopularDemand
I say tranny issue
2000 V6 vert
Mac LT headers, Mac O/R H-pipe, Mac CAI, ASP 25% underdrive pulley(r.i.p), SCT tune, 8.8 rear and 4.10 gears.
Old August 22nd, 2008, 07:49 AM   #19
JMack's Avatar
2000 V-6
Threads Similar to: engine revs but no power
revs staying high WildWill 94-95 5 May 28th, 2008 10:32 AM
Engine Has No Power! ricerraper33 V6 Mustangs 34 April 9th, 2008 03:37 PM
engine has no power ricerraper33 V6 Mustangs 1 April 5th, 2008 06:29 PM
tire revs per mile emgjsdk1 Audio/Video 5 March 4th, 2008 12:44 AM
Revs Quick, Idle Down To Slow... teal89 5.0 Mustangs 10 March 2nd, 2008 09:52 AM
