#21 |
2002 Ford Focus
slow as fuck
![]() iTrader: 4 reviews
the QA1 k-member isnt crappy, its just not recommended for autocross or the like. its just fine for a dd and drag tho
99 V6 Mustang-sold 02 Ford Focus-sold 98 Camaro Z/28-lid, catback |
#22 |
Unless you want to change the suspension angles, I'd just go with a used stock cross member. I presume the $500 includes labor to take it out of a car at the wrecking yard. That shouldn't be so hard if you find one with the engine already removed. In fact I think the wrecking yard would usually drop the engine out from the bottom complete with the cross member.
I presume you solved the engine problems? |
#23 |
This might be helpful. It shows in detail how to R&R the cross member.
The advantages of the tubular cross member are increased strength and reduced weight. AJE Racing Tubular K-Member |
#24 |
If I were going to do this, I would also install the tubular A-arms (lower control arms), since the balljoints and bushings on the originals are likely to be worn.
If you have disassembled suspensions before this would be a good DIY project, since you would save a lot of labor costs. |
#25 |
#26 |
One more bit of information. According to this site the crossmember is the same for 3.8L and 4.6L. You might check that with Ford.
New Ford Parts - Genuine OEM Replacement |
#27 |
well, that one installation page should be quite helpful. I think i will be going with th PA kmember and may look into the tubular a arms as well, but doesnt that require a coil over setup?
My car ---- (m112 in progress) |
#28 |
#29 |
From looking at some of these products on the internet yesterday, some of the tubular control arms have a spring seat and some don't. Those without the spring seat would need a coil over shock. There was one type that had a removable spring seat so it could be used either way.
#30 |
well i ordered just the kmember from pa racing, later on maybe ill get some tubular a arms but im out of money for now. I also ordered my jlt intake, ud pulley, and iat sensor for the m112
Threads Similar to: Tubular kmember ?'s .....
| Kmember removal/replacement | alabamastanger | 5.0 Mustangs | 2 | May 16th, 2008 12:16 PM |
| bent kmember | 99v6stang | V6 Mustangs | 6 | March 26th, 2008 04:18 PM |
| v6 kmember = v8 kmember????????? | 99v6stang | V6 Mustangs | 7 | March 7th, 2008 08:42 AM |
| tubular front kmember | Invictus | 99-04 | 3 | June 23rd, 2007 07:50 AM |
| after upr kmember install? | hrseply | General Tech | 2 | June 21st, 2006 02:24 PM |
