The Basics For Beginners... a help-guide for newbies - Page 2
Old November 28th, 2006, 09:19 PM   #21
Sa-WaitNoMustang900Turbo is on a distinguished road
Originally Posted by CyberPrey
While intercooling (the cooling of air AFTER the forced induction unit and BEFORE it goes into the motor) is optional on some Superchargers, it is almost a requirement with turbochargers due to the fact that a turbocharger unit gets much hotter and hot air is not as effective at building horsepower.
that is a misconception, ranking in heat produced by the compression it goes(coolest to hottest) centri s/c, t/c, twin screw s/c, and by far the hottest, roots s/c. centri s/c arent that much cooler than t/c though, any compression heats stuff up quite a bit. t/c are more often intercooled becaose of the ease in making an efficcient IC for them. Many s/c arent IC'ed because of the low boost normally being run by them, but all of the good ones for petrol engines usually are, it being IC'ed is just far less noticable many a time than the obvious FMA-AIC like on many turbo or centri s/c set ups
for example my SAAB has no IC(most models of the time do, just not the american) and it runs about 9-12.5 peak boost just fine, many older models did have WI though. IC became standard on all SAABs when the 4v head was introduced in the 85 model year(the head also yeilded 9:1 compression with the same level of boost though)
God... That Euro import guy is really starting to get on my nerves... my car can only beat his in a strait line(maybe)
Old November 29th, 2006, 01:38 AM   #22
muneris pro ego
Ninjawafers!'s Avatar
97 5.0 Exploder AWD
snow has nuthin on me
Ninjawafers! is a splendid one to beholdNinjawafers! is a splendid one to beholdNinjawafers! is a splendid one to beholdNinjawafers! is a splendid one to beholdNinjawafers! is a splendid one to beholdNinjawafers! is a splendid one to beholdNinjawafers! is a splendid one to behold
Send a message via AIM to Ninjawafers! Send a message via Yahoo to Ninjawafers!
thanks for all the corrections with my mistakes.... sometime i will compile it all with the corrections and make a new post with it... so if anyone notices anything else go ahead and add... there will be a corrected one soon!
Buy my M90 Kit and my Gears and T-Loc!
MM ZDC - Alaska Base Commander
MM+ Cleavage Club #24
MM Cares Crew / Military Crew
M2C2 President / USCG - OS2
Old July 4th, 2008, 09:52 AM   #23
md03cobra is on a distinguished road
I just pulled my stock 4.6L and put in a 5.1 stroker with the Whipple 3.4. I'm wondering if I should tune it with nitrous or not.
Old July 4th, 2008, 11:42 AM   #24
94v6blkndred's Avatar
02 Turboed Saleen Clone
faster than my v6
94v6blkndred will become famous soon enough
Send a message via Skype™ to 94v6blkndred
damn witchdoctor...you just brought this thread up from the dead....
http://www.dewayneamiller.com/uploads/94v6blkndred_sig.jpg
94v6.CAI,Exhaust,3:73s-needs rear end rebuild
02GT/Saleen.built motor,62mm turbo 412hp/446tq @10psi,stock TB and intake
Threads Similar to: The Basics For Beginners... a help-guide for newbies
Mod Motor Basics Schraders 99-04 15 March 30th, 2007 05:17 PM
turbo basics and what not 232stang V6 Mustangs 30 January 27th, 2007 02:41 AM
mustang suspension basics 99mustang232 General Tech 2 March 16th, 2006 09:58 PM
