Seafoam Questions?
I want to seafoam my car soon. My first question is this the right product AutoZone.com | Shopping | Accessories | Product Detail - Sea Foam 16 oz. Engine Fuel and Diesel Treatment Next how much do you add to your gas tank and i also heard you can add it in different place 2? Yea i just need some common info about seafoam cus i dont wanna mess anything up Thanks!
2000 V6
![]() iTrader: 1 reviews
yes, that's the right one. you can add a third through you gas, third through your crank case and the last third through your pcv valve. you will want to change your oil 500 miles after you add it to your crank case.
Cigar Assassin
just do a quick search, these questions have all been answered before:
PCV location question (pics inside) / Seafoam sea foam ??????? Seafoam quick question seafoam |
How much gas do you need in your gas tank? Does it matter?
Cigar Assassin
i would do it on a full tank
One more question might be stupid but i dont no is the PCV valve another name for the brake booster line? Because i have been looking around and they say to put it through the brake booster if there different where is the pcv valve located?
Cus i seen it here
can someone please upload a pic of the PCV valve and also do i just turn on the engine and let it suck it up Becuase i seen Juggalo X put this in another thread. "nope my engine is off, i pulled the pvc line put a funnel with a tube on it into the intake where the pvc line was emptied the can in there now i let her sit like suggested then ill fire her up, of course i reassembled the pcv system. "
MM.s Used Car Whore
2011 F150 XLT 4x4 5.0
14.89
dont sea foam your car..
it can cause more harm than good.! made my chevy truck start knocking..!!! it cleans all carbon suit out, and you might get a leak or knock just use injector cleaner.. |
2000 V6
i read somewhere that it is better to use the pcv valve because it feeds all six cylinders. the brake booster only feeds three. the pcv valve is located on the driver side valve cover.
worked fine for me and everyone else that has used it.. Maybe you loaded it wrong
![]() JAKE'S PIITB CREW MEMBER#4 |
MM.s Used Car Whore
14.89
like i said dont do it..its not worth it..
buy lucas injector cleaner |
MM's Database Error
no its a good thing for the engine, but if u have a hidden problem then when all that carbon gets cleaned out and broken down ur problem can be exposed
So should i feed it in the pcv while the engine is on?
#15 | |
MM.s Used Car Whore
14.89
i used it twice in my stangs and it worked didnt feel a differnce. just smoked like shit.. than did it to my trucka an it started knocking... cause that carbon sut has been there for years you go an clean entire motor it can cause it to knock.. burn oil... or cause leaks. its happend alot... look it up on google |
#16 | |
MM.s Used Car Whore
14.89
+1 |
MM.s Used Car Whore
14.89
yeah thats only way it'll go in..and spread to all cylinders.. than turn mottor of let sit for 5... than start it up and drive it around and have fun in the smoke cloud
#18 | |
![]() WTS Stock rear performance speakers. 6"x8", works fine. Got new alpines :-) PM for Details/with offer. |
Im not worried i still have a warranty on the car so i rather find it now rather then later when i have to pay to fix it.
MM.s Used Car Whore
14.89
ok listen to your self.
Dam.. okay so if the problem isnt there yet, why seafoam and bam the problem jumps up and ur shit's fucked from a dumass aluminum bottle of cleaner.. just take car of your motor.. use miidgrade gas. dont use cheap ass gas.. clogs injectors or its watered down gas. use synthetic oil... easy... if you want to do something like sea foam.. go to a local mr tire and ask for a Fuel incecor cleasing.. they use valvoline.. injector cleaner in gas tank.. throttle body spray.. and than puts some can on hood prop.. and put a regulator on it and run car for 20 min with it.. an car runs brand new |
Threads Similar to: Seafoam Questions?
| seafoam | 00redgt | 99-04 | 8 | April 17th, 2008 11:52 PM |
| seafoam | PeejConk | V6 Mustangs | 2 | April 2nd, 2008 02:09 PM |
| where to seafoam | SPF0percent | V6 Mustangs | 33 | May 20th, 2007 05:13 AM |
| SeaFoam Questions | Bill | 5.0 Mustangs | 34 | November 6th, 2006 10:36 PM |
| seafoam | jaystang98 | 96-98 | 4 | August 17th, 2006 07:14 PM |
