1998 mustang 3.8l v6
tuner
i have an xcal 3 and i was wondering why i can't get my wheels to chirp when it shifts. i have very slowly moved the pressure up all the way and it still won't shift that hard and really doesn't much harder than stock. anyone know why?
![]() RACING because baseball,basketball, bowling,football, and golf only require one ball |
[8MINUS2]
Not enough power?
2000 Mustang V6
need to run at track
![]() iTrader: 2 reviews
are you manual or stock?
hahahah funny. i should put out about the same as Jasonics and he can chirp them?
stock auto
Are you sure you adjusted it properly? If you've got the pressure all the way up, the shifts should be hard as fuck. It has nothing to do with power.
edit: something isn't right, you should definitely notice it shifting a lot harder than stock. |
yea i had them to 25%. not -25% which i assume is really soft but 25% and it wasn't all that hard
#8 | |
[8MINUS2]
You have a pre 99 ... Jasonic = more power
i believe ja has a 98 SSS
[8MINUS2]
I believe, actually know your wrong...
![]() And you can but increasing line pressure via x cal too high is a bad idea....
you might be right. I was thinking of 3.8 coastie.
lol
2000 Mustang V6
what are you puttin out to the rw? maybe 7 more than wat it is stock ,
hmmmm, it def should at least chirp them with the tuner. I would set it back to stock using the tuner and redo everything.
i think im putting more than 7 more than stock i have more mods than what is in my sig. i will list them when i get home from school.
#16 | |
Moderator
2003 Grand Cherokee
![]() But in all seriousness, you should be getting some chip after the tune.
1995 Mustang convertible
+1 you should be able to get some chirp, but if you really want some chirp gears are the way to go.
MWWarlord 1995 Mustang convertible check out my garage for pics and a complete list of mods. http://www.tricktuners.com |
gears are to come in the future. my plans are to get an 8.8 rear end from a junkyard and put 4:10 in it. that is the plan. and with ud pulleys, cai, full exhaust (headers, midpipe, and cheap flows.) intake spacer, p7p upper and lower intake and tb. i should have more than 7 more rwhp. i would say i have about 180 rwhp.
[8MINUS2]
maybe your powerband has moved up and your bottom end is horrible now?
could that be it? and what could i do to fix it?
and what do you estimate my rwhp? and crank hp
Threads Similar to: tuner
| Tuner Help | ricerraper33 | V6 Mustangs | 23 | July 15th, 2008 11:39 PM |
| best tuner out there? | xalexg212x | 2005 - 2010 | 18 | July 13th, 2008 11:08 AM |
| need sct tuner/ dyno tuner in baton rouge? | BakerFX4 | 99-04 | 20 | April 1st, 2008 11:13 PM |
| SCT tuner not working - just got tuner & CAI | Odin | 2005 - 2010 | 7 | March 28th, 2008 10:05 AM |
| tuner | matfernan1 | 99-04 | 3 | November 29th, 2007 07:54 PM |
