Engine Removal
How do you remove a V6 from the 1999 Base Mustang?
why would you want too?
![]() WTS Stock rear performance speakers. 6"x8", works fine. Got new alpines :-) PM for Details/with offer. |
Might be buying one that might need to be rebuilt.
![]() iTrader: 2 reviews
If its your only car then I wouldnt recommend on doing this..
2002 mustang v6- Auto, K&N CAI, Flowmaster dual exhaust, Black bullits dd 1996 mustang gt- 5spd, black, cobra hood, stock November Birthday Club Founder Old username: 97gt www.discounttiredirect.com |
No I've got 3 other cars.
Does the engine come from the top or bottom? of the car
1988 Mustang LX Turbo
you can do both
i always found it easier to do it from the bottom (Cradle) 4 bolts on the K Member, remove the strut bolts, a few conections an hoses then drop it down
1988 LX Coupe 2.5L, GT35R, 44mm WG, 32psi, C16. |
What do you need for top?
[8MINUS2]
Engine hoist it comes right out...
Bottom seems like a lot of extra work for nothing.
un bolt the tranny mount
then the tranny disconnect the fuel line disconnect your wiring harness or all your sensors take off your radiator hoses then the 2 heater hoses in the back remove exhuast or headers at least un-do vacuum lines unbolt your starter unbolt your grounds unbolt your motor mounts--(1 22mm bolt on each) or 21mm then with a hoist lift her up slowly
#12 | |
It's not clear if you are leaving the trans in place. It is supposed to be possible to remove all the engine to trans bolts and the 4 torque convertor nuts, then remove all the wires, hoses, motor mount nuts etc and lift it out with the trans still bolted up. The engine would have to come forward slightly (maybe 1") to clear the torque convertor studs. The radiator doesn't need to be removed.
99 Cherokee sport/87 5.0
not tested
easier to take engine + tranny at once.
[CENTER]"Not the victory but the action; Not the goal but the game; In the deed the glory," -Hartley Burr Alexander |
1996 3.8L v6
umm if your asking this question i really dont think u should be removing it, if you know what your doing you can get it out and the new one in in a day if u work the whole entire day, we did mine in a week but we only worked on it like 2 hrs a day
If you plan to R&R the engine and rebuild an engine, I would recommend that you buy the Ford shop manual from Helm publications. It has detailed step by step instructions and the correct technical information.
good thing you got 3 cars. when i took my first engine out i worked on it day and night all over one weekend. just start takin stuff apart make sure you label everything. get a haynes or chiltons manual and do some research. Best way to learn is to do it yourself.
BS in a manual tranny its 10 times easier to remove and install with the motor installed
took me 10min to unbolt and remove the tranny by MYSELF with a buddy to lift it on the ground it takes another 10min to bolt it up and i never said anything about removing the radiator? ![]() in an auto its different but in a manual tranny your nuts if your going to waste time fishing it out engine and tranny together i garuntee it takes twice as long between finding the right angle moving the hoist with the engine alone it can be a little hard to move it let alone another 80-120lbs then angle it out with out hitting anything plus when its out and on the hoist its going to take longer unbolting the tranny then working the last few bolts while holding ESPECIALLY if this motor is going to sit on an engine stand if you unbolt the tranny and use u-joints and manuver the tranny and motor up and down unbolting the bellhousing is a breeze take a tranny out of a viper and then take a tranny out of our v6 mustangs. see how a v6 mustang is like eating cake vs most cars
#18 | |
and if you mean the motor thats pointless because its a motor swap anyway all wires, hoses(auto only) have to be removed no matter what when removing the tranny when you remove a motor the tranny it not staying in place with out destroying the tranny mount and it laying on the floor
#19 | |
If you support the transmission with a jack (preferably a trans jack) it can stay in the car. When I did mine I removed the transmission then the engine. However, the shop manual procedure does recommend leaving the transmission in the car supported by a jack.
I agree with your comment that it would be difficult to remove the engine and transmission together from the top. In that case I think it would be easier to lower it out from under the car together with the cross member. There certainly is more than one way to do this.
#20 | |
thats a different story leaving it on a jack
Threads Similar to: Engine Removal
| drm removal | gooberhead320 | The Clubhouse | 0 | August 7th, 2008 04:47 AM |
| Engine Removal Tips | pavementpownder | 99-04 | 5 | May 16th, 2008 11:39 PM |
| Engine removal steps - please help clarify | trumpet1 | Classic Mustangs | 2 | March 27th, 2008 11:29 AM |
| Began Engine Removal | OnePass2Many | 99-04 | 1 | December 20th, 2007 02:48 AM |
| Engine removal AC compresor evap/ dryer what to do? | OTreborO | General Tech | 2 | April 11th, 2006 02:50 PM |
