2001 Mustang 3.8
tranny fluid
I heard from some people that it maybe a bad thing if you change your transmission fluid i was wondering what all of your input maybe on this. Is it a good or bad idea to change your tranny fluid, and also how often should you change it?
SCT Xcal 3 tuned,4.10 gears, T-lock, J-mod, CAI, dual flow masters. |
2004 Mustang V6
![]() iTrader: 1 reviews
supposed to every 30k by fords specs.
change it just about every year, and it will be fine.
though, ive known people that haven't ever changed theirs
if you've waited longer ten 80kmiles i wouldnt change it
1999 Ford Mustang V6
14.79 @ 92.15
i changed mine at 90k miles, but not since
you may have been lucky
it also depends on the tranny to if you have any sludge or build up in the tranny thats covering or blocking a leak changing the fluid will remove that sludge at start up and thats when you'll have issues.
2001 Mustang 3.8
im at about 46,000 miles do you think i should change mine? and also how do you do it i have never changed tranny fluid before is there a screw like when changing the oil?
its a bigger pain in the ass.. i usually pay someone to flush mine
2001 Mustang 3.8
so its porb going to cost me about $40-$50 to have it done at a shop?
99 Cherokee sport/87 5.0
not tested
it's $100 everywhere around here. you can do it yourself- it's just not as easy as changing the oil.
[CENTER]"Not the victory but the action; Not the goal but the game; In the deed the glory," -Hartley Burr Alexander |
I do it at Ford.....~130$$ just for that.....They say that about every 50 000Km it should be flushed.........
The difference between Fiction and Reality??? Fiction has to make sense. -Tom Clancy |
I would recommend changing the fluid at 30K mile intervals.
You need to remove the transmission pan and you should also remove the drain plug in the torque converter. That way you get most of the fluid out. It takes about 10 qts to refill so your talking about ~$50 for Ford fluid. I recommend buying the fluid from Ford. I've found it works noticeably better than aftermarket fluid. Some people say there can be a problem with changing the fluid if it hasn't been done regularly, that it could dislodge sludge and cause problems. I don't know what the basis of that is, but I would recommend changing the fluid regularly from the beginning to avoid that problem. |
#13 | |
2004 Mustang V6
I'm not sure what the capacity is for a totally dry system, but after a drain and fill including the torque converter, I found it took somewhere between 10 and 12. I would buy a case of it (12 qts). Even draining everything as best you can there is still some old fluid left. Transmission shops have equipment to do a more complete flush.
not tested
shop told me 13qts when they did mine.
you can drain the pan, then put the pan back on, and disconnect the hose that runs tranny fluid FROM the tranny TO the radiator and crank up the car, but AS SOON as that hose stops spitting fluid you should cut the engine. as far as i know that's the best way to do it yourself.
Threads Similar to: tranny fluid
| tranny fluid | armymike63b | 99-04 | 3 | August 17th, 2008 07:01 PM |
| what tranny fluid? | Bandit | 2005 - 2010 V6 | 4 | April 28th, 2008 04:45 PM |
| tranny fluid | GTsetGO | 99-04 | 2 | March 23rd, 2008 06:02 PM |
| What Fluid do you use in your T5 Tranny? | noyz25 | 5.0 Mustangs | 6 | August 6th, 2007 05:25 AM |
| tranny fluid | terribleonexx88 | 5.0 Mustangs | 20 | November 24th, 2006 06:41 PM |
