'97 V6 - '01 GT gauge cluster compatibility?
Old September 7th, 2008, 06:53 PM   #1
6stang's Avatar
1997 Pacific Green 3.8
6stang is on a distinguished road
My '97 V6 Mustang temperature gauge stopped working a couple months ago. Will a gauge cluster out of a 2001 Mustang GT (with a digital odometer) work properly in my 1997 V6 Mustang (with a old style rolling odometer)?
Thanks, Nathan
Old September 7th, 2008, 09:30 PM   #2
Daniel's Avatar
1995 Mustang V6
Daniel is on a distinguished road
If you're talking about the main gauges in the dash, I don't think so for the fact that the gt mph's go to 150, while the v6 mph's only go to 120.
Hope this helps.
Old September 7th, 2008, 10:11 PM   #3
MM's Database Error
WLJohnson05's Avatar
2004 Mustang V6
322.8 rwhp
WLJohnson05 is a splendid one to beholdWLJohnson05 is a splendid one to beholdWLJohnson05 is a splendid one to beholdWLJohnson05 is a splendid one to beholdWLJohnson05 is a splendid one to beholdWLJohnson05 is a splendid one to beholdWLJohnson05 is a splendid one to beholdWLJohnson05 is a splendid one to behold
iTrader: 8 reviews
not to mention that the rpms will be off too...
ur really better off just getting one from your year and engine type
Kenwood Head Unit $155
SCT Mass Air Flow Sensor $200
Old September 7th, 2008, 11:25 PM   #4
1996 ford mustang
theyanks904 is on a distinguished road
no it wont work at all so save your self time and money and dont try ......
you will have to get one out of a 1994-1998 mustang
Old September 8th, 2008, 12:54 AM   #5
6stang's Avatar
Well that sucks
What after market gauges would work on my particular year and model? I need to have a working temp gaure again.
Old September 8th, 2008, 03:14 AM   #6
Stang Tech's Avatar
2003 Mustang GT Vortech
Stang Tech is on a distinguished road
Send a message via AIM to Stang Tech
if you want a working temp gauge go to autometer and get a aftermarket one and a wiring diagram and splice the right wire to the gauge or drill and tap and install the sensor that the gauge comes with.
Ford Certified Tech Land Rover Certified Tech
Ase Certified Tech Honda/ Acura Certified Tech
AllData Automotive Information Specialist
03 Mustang GT
Vortech V3 Intercooled
407/415 to the wheels
BOOOOSSSTTTTTT
Old September 9th, 2008, 04:56 AM   #7
Modded V6
Stang6899 is on a distinguished road
I have a gauge cluster out of a 95 v6 with the old style rolling mileage just like your car for sale. PM me if you're interested.
1999 e46 328i BMW - Daily Driver
2001 SVT Cobra - Project
1995 v6 vert - SOLD
1996 v6 vert - SOLD
1995 v6 vert #2 - SOLD
1995 GT - SOLD
1997 v6 coupe - Parting
Old September 9th, 2008, 07:52 AM   #8
JMack's Avatar
2000 V-6
JMack is an unknown quantity at this point
Stick with 94-98. The 99-04 GT's are gonna be off like they said. There is "supposedly" some cal box that you can plug in to make it work, but it's prolly not worth it. What doesn't work about it?
Is the indiactor broken, or not responding?
Have you checked the sensor?
Check the cluster wiring?
Is the return spring broken?
+1 to the autometer or whatever your poison is. It will be much more accurate, and reliable.
Old September 9th, 2008, 08:32 PM   #9
6stang's Avatar
I've looked into it
The needle always stays at resting position (Even on a 150+ mile non-stop road trip from Duxbury, MA to Lincoln, NH) My oil pressure gauge works fine (same harness) That's about all I know about it. I have swapped both temp sensors from the other (thrown rod) 3.8 I have. Hoping that if it got to hot the idiot light would come on but I'm not sure
I wanted to see if the Autometer or the Simco [http://www.americanmuscle.com/simco-...96-98-gt.html] (cheaper) cluster works in a '97 V6 or not. I don't really like the idea of mounting extra gauges for sonthing that already has a spot in the original cluster.
Old September 9th, 2008, 09:30 PM   #10
supermachone's Avatar
1984 Corvette
Kessel Run @ Less Than 12 Parsecs
supermachone is a name known to allsupermachone is a name known to allsupermachone is a name known to allsupermachone is a name known to allsupermachone is a name known to allsupermachone is a name known to all
you can get a used speedometer cluster for dirt cheap off ebay, all you gotta do to get it to work is switch out the ECU (big green computer board which is located on the back of ur cluster under a white protective plastic piece) from ur current speedometer to the one you buy (otherwise the PATS system wont recognize the cluster and ur car wont start)...however if the reason the gauge isnt working is because of a problem with ur ECU than it wont fix the gauge lol
u can do the same thing with a GT speedometer, no it wont read correctly but i did it with my v6, however its an auto so i dont have to worry about the rpms, and as far as the speedometer being correct, i just figured out what speed im really going until i can see if ford can recalibrate it correctly...works great so far
Old September 9th, 2008, 10:58 PM   #11
6stang's Avatar
Sounds good
Hey, let me know what you come up with on that re-calibration. I wish I could have a GT / Cobra cluster (work properly) in my V6 Mustang.
How hard is it to swap that board to a new gauge cluster? Are you sure I need to do that to one for my earlier model? I have the old type rolling odometer.
Would this one work? eBay Motors: Autometer Mustang V6 1999 - 2003 Cluster #7002 NEW (item 360086796531 end time Sep-14-08 17:50:29 PDT)
Old September 9th, 2008, 11:11 PM   #12
1984 Corvette
the swap is really easy, gettin the cluster out is kinda annoying
i forgot u said u had the rolling odometer though...it should still work, however ud have to use the rolling odometer that comes with the new cluster... fuck it, i guess ur gettin new mileage either that or u could probably take all that shit apart and put it in, that might be a pain though, mines digital so i didnt run across that problem, and i have no idea how the pre 94-98 speedometer clusters are set up...(as far as the 99-04 clusters working, i dont know if the digital odometer would function or not)
Old September 9th, 2008, 11:29 PM   #13
1984 Corvette
id probably just try and get one that is 94-98
here is one for 20 bucks
eBay Motors: 1996 FORD MUSTANG Instrument Gauge Cluster USED A/T (item 160279421779 end time Sep-10-08 19:23:45 PDT)
heres a GT one for $100
eBay Motors: 1994 1995 Ford Mustang GT Instrument Cluster 150MPH! (item 330268938795 end time Sep-13-08 19:06:50 PDT)
in this case, it looks like the ECU is pink/red, it should still swap the same, but i can't honestly say for sure, and like i said, ud probably have to use the rolling odometer thats in the new cluster, unless u can figure out how to change them to the right mileage, swap them, or say fuck it lol
Old September 10th, 2008, 09:12 PM   #14
6stang's Avatar
...but I want these ones!
What about these ones. eBay Motors: Autometer Mustang V6 1999 - 2003 Cluster #7002 NEW (item 150290845679 end time Sep-10-08 20:13:21 PDT) for a '99 - '04 model (digital odo) but It's for a V6 (120m/h speedometer). I like the Autometer ones.
Last edited by 6stang; September 10th, 2008 at 09:12 PM. Reason: forgot to add the link
Old September 11th, 2008, 02:10 PM   #15
1984 Corvette
im not sure on those, ud have to call autometer to see if its compatible, they will probably tell you no since it specifies which years its for
Threads Similar to: '97 V6 - '01 GT gauge cluster compatibility?
GAUGE CLUSTER BROKINARROW 5.0 Mustangs 8 October 5th, 2007 07:17 PM
Gauge Cluster Euroeater95 94-95 2 May 20th, 2007 09:55 AM
Gauge Cluster brad03svt Modular Mustangs 7 May 20th, 2007 04:01 AM
gauge cluster coreyfitz 94-95 2 April 14th, 2007 07:37 PM
swapping '95 V6 gauge cluster to a '94-'98 GT cluster? Alocatelli V6 Mustangs 3 April 4th, 2007 03:38 PM
