1997 Pacific Green 3.8
V6 to GT brake conversion
I can get a good deal on a set of 4 '01 Mustang GT brake calipers. My '97 V6 Mustang needs calipers and I wanted to upgrade the whole set for not too much money. Other than needing to change the pads and rotors will everything work and be compatible? I have a set of '03 Mach 1 wheels on my car. Suggestions on good slotted / X-drilled rotors / quality performance brake pads?
I thinks, not sure. vut the v6 and v8 have the same breaks. but i an not sure with your year model. but here are some good rotors, StangSuspension.com Rotors - StangSuspension.com they are what i have, and for brake pads.Hawk ceramic to keep the brake dust off your rims. High Performance Pads - StangSuspension.com
This is the set up i have, and i like it.
![]() MILITARY CREW USArmy/SGT |
i believe its the same, aside from the rear maybe
the 01 brakes would be an upgrade for you since they are dual pistons brakes.
normally v6/gt brakes are the same but since you have a 97 the 01 brakes would indeed be an upgrade.
99 Cherokee sport/87 5.0
not tested
damn, the clown beat me to it.
[CENTER]"Not the victory but the action; Not the goal but the game; In the deed the glory," -Hartley Burr Alexander |
as usual.
November 08 ROTM
just do it the right way the first time. 03/04 cobra/mach1 brakes FTW
and then i also have the 13'' rear BAER kit.
![]() ~Nitrous is like a Hot Girl with STD's, you know you wanna hit it, but your afraid of the consequences~ |
^^^ as long as he has 17 inch rims or bigger.....
The difference between Fiction and Reality??? Fiction has to make sense. -Tom Clancy |
not tested
not tested
+1 to that. if you're gonna do it, do it right.
yea, if your gonna do it right, just buy 2k worth of cobra brakes
. With your 3.8, you wont need anything that serious.
#12 | |
November 08 ROTM
![]() heres a pic of my set-up: ![]() ![]()
^sweet setup, why dont you paint the red on the caliper to match your car?
you have the best signature i have seen so far......
![]() Cosmetic: Vent-visors, Pioneer Bluetooth Radio Deck, 17" Cobra Alloy Rims, HID 4500k 55watt setup, Chrome Headlamps 15% Tint, Red sway bar Performance: CAI,Mac-Longtubes, H-pipe, Flow 40s, NO CATS Diablo Tuner, Rear Sway bar |
#14 | |
I wouldn't worry too much about the rears if you're trying to save money. The fronts do most of the work. Like I said, the Mach kit is ~$350... and while you may not "need" great brakes, it's one area where it's good to have more than you "need".
1993 2.3L Coupe [Motortopia] : Open-Track Project... 216k miles 2000 V6 (Black,5-speed) [Motortopia] : Heads/Cam (EXHAUST CLIP) 2001 Harley Davidson F-150 Acts 16:31 |
Hey thanks for all the info. Great help! I'll look into the Cobra and Mach 1 setups. If I'm gonna pay all the $$ for the slotted and X-drilled I might as well go for the Cobra / Mach 1 kit. Will that fit on my existing lines / brackets? I have Mach 1 wheels- I'd hope they'd fit a Mach 1 brake system...
Looking around...
Hey, buddyantunez1 (Nice brakes!), did you need to change the brackets / lines (or anything else for that matter) to make those work on your V6?
And, Blainestang, where did you find the complete brake kits you mentioned for only $350? Thanks, -Nathan |
Threads Similar to: V6 to GT brake conversion
| Disc Brake Conversion | wonders_of_a_V8 | Classic Mustangs | 6 | January 20th, 2009 10:16 AM |
| Rear Brake Conversion | 90mustang | 5.0 Mustangs | 1 | August 18th, 2008 09:28 PM |
| brake conversion | Baker | 5.0 Mustangs | 15 | May 26th, 2008 08:56 PM |
| Disc Brake Conversion | gotboost562 | 5.0 Mustangs | 8 | November 10th, 2007 06:38 PM |
| 6 brake light conversion | 99mustang232 | Visual | 0 | November 27th, 2005 03:46 AM |
