95 v6 problems
Old September 9th, 2008, 12:10 PM   #1
KevinJ99GT's Avatar
1999 Mustang GT
8.30 1/8th mile
KevinJ99GT will become famous soon enough
95 v6 problems
Ive gave up on this car...i had a blown head gasket and it sputtered, i replaced the engine and it still sputters and have had 4 mechanics look at it. I dont even think they knew what the hell they were doing. Any ideas
- full bolt on's, hitech stage 2's, zex 100 shot
Old September 9th, 2008, 12:22 PM   #2
BostonPerformance's Avatar
99 Cherokee sport/87 5.0
not tested
BostonPerformance is a jewel in the roughBostonPerformance is a jewel in the roughBostonPerformance is a jewel in the rough
spark? fuel?
[CENTER]"Not the victory but the action; Not the goal but the game; In the deed the glory," -Hartley Burr Alexander
Old September 9th, 2008, 12:27 PM   #3
KevinJ99GT's Avatar
1999 Mustang GT
8.30 1/8th mile
im putting seafoam through it today...already had spark plugs and wires done
Old September 9th, 2008, 12:28 PM   #4
KevinJ99GT's Avatar
1999 Mustang GT
8.30 1/8th mile
i dont even hardly drive it only when i want to give the gt a break and drive it to school if its raining
Old September 9th, 2008, 12:36 PM   #5
not tested
if your spark is good then I'd look into air or fuel problems.
check the MAF.
no leaks anywhere in the fuel lines? check your fuel pump also.
Old September 9th, 2008, 01:40 PM   #6
94v6blkndred's Avatar
02 Turboed Saleen Clone
faster than my v6
94v6blkndred will become famous soon enough
Send a message via Skype™ to 94v6blkndred
have you checked the exhaust? maybe its having back pressure issues....you can unbolt the exhaust from the headers and run it and see if it still does it...
http://www.dewayneamiller.com/uploads/94v6blkndred_sig.jpg
94v6.CAI,Exhaust,3:73s-needs rear end rebuild
02GT/Saleen.built motor,62mm turbo 412hp/446tq @10psi,stock TB and intake
Old September 9th, 2008, 02:12 PM   #7
stephen has a spectacular aura aboutstephen has a spectacular aura about
I think the above two suggestions to check fuel and exhaust back pressure are good ideas.
You should check fuel pressure with a gauge and check engine vacuum.
Fuel pressure is supposed be be 40-50 psi if I remember right.
You might also have the injectors flow checked off the engine.
Exhaust restriction should make engine vacuum go down after it's started.
You said you replaced plugs and wires. You might also check the coil.
These are things a good mechanic should have already done.
Old September 10th, 2008, 12:45 AM   #8
moond0ggie's Avatar
1998 Mustang V6 5 spd.
moond0ggie is on a distinguished road
water in the gas........?
http://www.moddedmustangs.com/forums/signaturepics/sigpic13601_6.gif
Threads Similar to: 95 v6 problems
Problems zigbigadoru 96-98 7 April 8th, 2008 07:57 AM
2 problems Genevieve! 99-04 6 April 1st, 2008 03:36 PM
More problems akatagyourit 2.3 Mustangs 3 October 16th, 2007 10:21 AM
More problems GreenFaleen V6 Mustangs 17 April 8th, 2007 12:22 PM
Still more problems Lax89 5.0 Mustangs 6 November 24th, 2006 04:25 AM
