LinkBack (2) | Thread Tools |
#1
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 4 reviews
valvoline maxlife atf
According to the back of the bottle on the valvoline maxlife atf it is "suitable where mercon v is called for" anyone know more about this considering the bottle claims it is dexron/mercon on the front. Didnt seem to make much sense to me although ive been using it for about 2 months with no problems.
It is because mercon v retrofits to all dexron III/ Mercon applications. It basically means it covers both applications. So it is MERCON/DEXRON and MERCON V.
Certified Master Technician Also FORD certified -Auto Trans, Electrical and Electronics,Manual Trans and Differential,Diesel Engine Performance and Repair, Gasoline Engine Performance and Repair,Suspension, Climate Control and Brakes Specialist. |
So its fine in the 4r70w im guessing?
Yes it fine, the 4r70w calls for mercon V.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/v6-mustangs/88874-valvoline-maxlife-atf.html
| Everything about valvoline maxlife - Yahoo! Glue | This thread | Refback | March 14th, 2009 03:29 AM | |
| Everything about valvoline max life - Yahoo! Glue | This thread | Refback | February 14th, 2009 09:54 PM | |
Threads Similar to: valvoline maxlife atf
| What's correct amount of ATF | rru95GT | 94-95 | 2 | July 14th, 2008 05:07 PM |
| Gear Oil or ATF? | 00gtCoolGuy | 99-04 | 4 | November 22nd, 2007 09:09 PM |
| ATF + Oil Change Via Disptick | provinggrounds | V6 Mustangs | 11 | June 13th, 2007 12:20 PM |
| Should I add friction modifier with Valvoline gear oil | 96BluePony1261 | Modular Mustangs | 5 | March 1st, 2007 06:55 AM |
| ATF Fluid in T5 Transmission? From Tech Article | 83 5.0 | 5.0 Mustangs | 12 | August 29th, 2006 11:26 AM |
