95 v6 problems
Old September 15th, 2008, 11:24 PM   #1
KevinJ99GT's Avatar
1999 Mustang GT
8.30 1/8th mile
KevinJ99GT will become famous soon enough
95 v6 problems
This car has had so many problems and i finally want to fix it. I use it as my dd when the weather is bad. I just put a brand new motor in it because i blew the head gasket on the old one. It has always had a miss ive changed the spark plugs and spark plug wires and it still wants to miss. I think i even changed the fuel pump im not sure its been a while. But it still has a little over heat problem the fan wouldnt kick on. So i unplugged a sensor( dont have a clue which one) it sticks up a little behind the alternator if i remember right and the fan will stay on all the time but when its plugged in it dont miss but overheats..what sensor is this and would this fix all my problems.
- full bolt on's, hitech stage 2's, zex 100 shot
Old September 16th, 2008, 12:48 PM   #2
KevinJ99GT's Avatar
1999 Mustang GT
8.30 1/8th mile
anyone?
Old September 16th, 2008, 01:21 PM   #3
snoel123 will become famous soon enough
If you are talking about a two wire sensor that screws into the intake manifold coolant runner, that is you're ect sensor. It is used to determine engine temperature. You're pcm uses it to determine fuel mixtures, and operate cooling fans. It is possible the sensor is faulty and the engine thinks it is cold which will cause the engine to act like "the choke is stuck on" . It also will not run the cooling fan as it thinks the engine is cold. If I remember right this year of mustang uses a seperate ect sensor for the pcm and another sending unit for the gauge. Post a pic of the sensor if at all possible and I can tell you what it is. Hope this helps you.
Certified Master Technician
Also FORD certified
-Auto Trans, Electrical and Electronics,Manual Trans and Differential,Diesel Engine Performance and Repair, Gasoline Engine Performance and Repair,Suspension, Climate Control and Brakes Specialist.
Threads Similar to: 95 v6 problems
Problems adrenaline=lifeline 99-04 3 August 25th, 2008 05:20 PM
a/c problems quick96cobra 4V / SVT 2 May 4th, 2008 05:00 PM
5.0 problems 5.0Madness 5.0 Mustangs 1 March 11th, 2008 08:39 PM
Still more problems Lax89 5.0 Mustangs 6 November 24th, 2006 05:25 AM
a few problems 232stang V6 Mustangs 0 November 22nd, 2006 04:01 PM
