Next Mods?.
Hey everyone, im new here, some great posts around that im learning from. Any way, here is my deal, im in Iraq right now but im planning my next moves with my '05 V6, So far ive put in a cold air intake, performance throttle body (70mm) some 9mm cables and thats about it. What would you reccomend be next? This is still my primary mode of transportation, so it needs to stay legal, and id like to do the work myself, its sort of a hobby. So what are some good ways to build up my power while keeping the mechanical work at User level. (im pretty compentant with my car, just dont want to lose it for weeks at a shop) Im open to all suggestions, and am looking forward to learning from you all. Thanks
Pat |
get some gears
Maybe a set of underdrive pullies, driveshaft, 160 thermostat, header back exhaust....
(2000 v6)bbk cai,motoblue udp,65mm throttlebody+spacer,diablo tuner, 4.10 gear,t-lok,160 thermostat, screamin demon, msd wires. bbk shorty headers, off road x,streetpro mufflers, Royal purple fluids, K&n oil filter. (89 5.0) msd dist,wires |
for a full bolt on set up (what i think you are looking for) you can expect some decent results.
for a good fullbolt on set up check out this guy's car. http://www.moddedmustangs.com/forums..._vehicle&CID=4 it can run with stock pre 05 GT's. The only thing he has that you might not be able to do is his exhaust, because of the lack of cats.
God... That Euro import guy is really starting to get on my nerves... my car can only beat his in a strait line(maybe)
k i wouldnt recommend gears if you wana do it yourself
second why the hell would he want a driveshaft? if i were you i'd look in to these options: -Underdrive pulleys -Full exhaust with long tube headers -SCT Xcal 2 flasher/tuner...or a chip or tuner of your choice. the xcal2 is just my recommendation Rims... Lowering springs and thats about it i'd say
#6 | |
and the driveshaft frees up power everything else i agree with. i don't think rims add HP. ( i know stickers do though )
#7 | ||
for gears dont u have to be pretty precise on how they go in?
You just have to be patient. You just take it apart over and over again until you get the right wear pattern between the ring and pinion gears. The marking compound will tell you what you need to change to get it to work.
On my 1st 8.8 rebuild, it took me 4 tries until I got it. On the 2nd, it only took me 2 tries. You really only learn it once you've done it. But, it's a huge step if you don't have any car repair experience.
To the Optimist, the glass is half full. To the Pessimist, the glass is half empty. To the Engineer, the glass is twice as big as it needs to be. |
u've opened up the intake, so open up the exhaust a little! headers and a cat-back exhaust system, or a gt take-off system
TO: Ricers- 1) there's no replacement for displacement 2) my lug nuts require more torque than your engine makes 3) a light car doesn't excuse a weak engine 4) a bottle of pepsi has more liters than your car eating rice builds muscle |
#10 | ||
The LS1 was finally subjected to a paternity test, and it's daddy was to '03 Cobra |
Threads Similar to: Next Mods?.
| 2.3T Mods | Ga_50_foxbody | 2.3 Mustangs | 55 | July 11th, 2007 02:56 PM |
| mods?? | mb03stang | 99-04 | 6 | July 6th, 2007 03:30 AM |
| mods | 06dkkiser | V6 Mustangs | 10 | June 26th, 2007 08:44 PM |
| mods | Mustang RacR94 | V6 Mustangs | 5 | March 30th, 2007 06:23 PM |
| 07 top 5 mods for under 400$ | TDog | 2005 - 2010 | 22 | February 9th, 2007 11:39 PM |
