Discussing tranny swap in the V6 Mustangs Forum. Originally Posted by speed4goal But when I do the tranny swap, I'm going to ...
Old December 5th, 2006, 08:46 PM   #21
SP00LIN V6
2000 Mustang V6
437rwhp 402rwtq V6
But when I do the tranny swap, I'm going to get a 8.8 rear end with 3.73.
I want to get forged internals, and bore it out to 4.2. and ssm stage 3 power pak. But that will be this summer.
tranny swap + 8.8 rear + stroking it (better then getting the internals seperatly then boring it) + power pak
lol man i hope you have money
idk about the tranny sway and how much that'll cost but stroking, power pak and 8.8 rear is $6k
im guessin a tranny swap is about $1k...$2k for the 6 speed
$8,000 to have 300hp and run high 12s low 13s
with that much money i could have a safe low 11 v6
The Sickest 6
The reason V8 owners on here hate me
Old December 5th, 2006, 10:12 PM   #22
ssajdowitz's Avatar
The tranny swap was about $3k for the 6-speed.
You can get a 90mm lightning maf on ebay for around $100.
To the Optimist, the glass is half full.
To the Pessimist, the glass is half empty.
To the Engineer, the glass is twice as big as it needs to be.
Old December 5th, 2006, 11:32 PM   #23
SP00LIN V6
2000 Mustang V6
437rwhp 402rwtq V6
lol k with that being sed $9,000 for a 300hp v6....not including the cost of the car...
if i had $9k i'd have my car like i want it in a month
The Sickest 6
Old December 6th, 2006, 09:47 AM   #24
I'm not to worried about cost. This car is going to take me awhile to build. I just want to do it right, So it can handle the boost and nos I plan to put on it. If i'mma going to mod this car, I may as well do it big!
Old December 6th, 2006, 12:39 PM   #25
SP00LIN V6
2000 Mustang V6
437rwhp 402rwtq V6
its nitrous
i bet if i sed im getttin zex 1/4 of the ppl hear wouldnt understand that
The Sickest 6
Old December 6th, 2006, 01:14 PM   #26
lol thats true
Old December 6th, 2006, 10:07 PM   #27
ssajdowitz's Avatar
I had the car like I wanted it once. Then, I blew the engine. Then, I blew the rear end. Then, I totaled it. Then, I blew the tranny.
Once you modify one thing, the rest of the car isn't engineered to handle the change. A chain of broken parts begin. Then, you get to the point where everything has been replaced and built up.
Just make sure you've accounted for every possible problem.
Old December 7th, 2006, 12:22 AM   #28
SP00LIN V6
2000 Mustang V6
437rwhp 402rwtq V6
no one wants to believe it but its true +1
The Sickest 6
Old December 7th, 2006, 12:32 AM   #29
+2 I've seen some people at the track put a new motor in then blow there tranny after a few weeks. At the track a few weeks back a lightning blew its transmission apart. They had to put the oil dry out for the fluid, and pick up a few parts. It took them like 45 mins to get the track ready to race again
Old December 7th, 2006, 09:39 PM   #30
chevy_killer's Avatar
2000 v6 Mustang
also if your going to boar out your motor it would be a good idea to take your pistons to the shop where your doing it and get each piston custom fit to each cylinder...youll make a bit more hp
The LS1 was finally subjected to a paternity test, and it's daddy was to '03 Cobra
Old December 8th, 2006, 07:04 PM   #31
ssajdowitz's Avatar
I used to work at a small engine shop. That is the ONLY way we would rebuild an engine. Every piston is different.
Old December 8th, 2006, 10:04 PM   #32
2000 v6 Mustang
ya when i was talking to a guy that im buying all my parts from said that every piston could be slightly off
Threads Similar to: tranny swap
Tranny swap popmyclutch V6 Mustangs 8 October 8th, 2007 02:00 AM
how to do a tranny swap? 95blueGT 94-95 0 June 17th, 2007 05:44 PM
tranny swap 95blueGT 94-95 6 June 9th, 2007 01:52 AM
T5 To C4 Tranny Swap 88mustangowner 5.0 Mustangs 2 November 9th, 2006 11:19 AM
Help (T5 Tranny Swap) JBake V6 Mustangs 16 November 2nd, 2006 10:13 PM
