Discussing New PA racing tubular kmember just came in... in the V6 Mustangs Forum. Yea, i bet you expecting to see some pics, but i havent had a chance ...
Old September 18th, 2008, 02:49 AM   #1
99v6stang's Avatar
Yea, i bet you expecting to see some pics, but i havent had a chance to take any yet, sorry. I will say that it looks like a very nice quality piece. Now on to my question...
On the stock v6 motor mounts there is a little round bump on the bottom behind the main bolt, i dont have access to my car with the stock kmember right now so i cant see if there is supposed to be some sort of indent for this, or if it is just ment to help keep the motor in place once it is properly tightened down. I held the new kmember (designed for 99-04 gt) up to my mounts and everything lines up fine, just the little bump on each side keeps me from being able to push the kmember completly into place. Im assuming the bumps just help hold it in place but thought i would ask just to make sure. If so, then it appears that the v6 and gt kmembers are EXACTLY the same, so why does every v8 swap switch them out?
My car ---- (m112 in progress)
Old September 18th, 2008, 12:06 PM   #2
99v6stang's Avatar
c'mon nobody knows what that little bump is for?
Old September 18th, 2008, 01:18 PM   #3
This picture shows where the stock motor mounts attach to the cross
member.
Image of crossmember - Photobucket - Video and Image Hosting
I believe there is a "bump" on each motor mount that lines up with a hole in the cross member. I believe you could grind that "bump" off.
Old September 18th, 2008, 01:59 PM   #4
shadow5403's Avatar
2000 V6 Mustang
The V6 mustang and the GT mustang should NOT be the same. I believe the V6 K-member and an old 5.0 K-member SHOULD be the same. This changed back in 96 when Ford switched over to the 4.6L V8.
Old September 18th, 2008, 02:25 PM   #5
99v6stang's Avatar
well i always thought that the v6's and v8 kmembers were not the same as well but after reasearching on 3.8mustang.com there were numerous people stating that they were 100% exactly the same the only difference is the motormounts. I concluded that the 79-95 is the same but requires aftermarket motormounts, and the 99-04 is the exact same. Other than these two tiny bumps it seems as if it will fit fine.
and yea stephen those holes are not in the location the bumps would go, and the bumps are much much smaller than those holes. the bumps are to the side of the motor mount bolt, i will take pics tonight
Old September 18th, 2008, 04:27 PM   #6
I believe the "bumps" you are referring to are shown in this picture on the right motor mount toward the back of the engine just behind the stud in the mount.
Image of complete engine - Photobucket - Video and Image Hosting
On the stock cross member the mount stud goes in the tapered slot and the "bump" goes in the slot behind it. At least one brand of after market cross member has a similar set up.
Old September 19th, 2008, 03:19 PM   #7
99v6stang's Avatar
yea thats it, although its very hard to see in the picture. So there should be a provision for that? Think i can just grind it off and call it good?
Old September 19th, 2008, 03:26 PM   #8
I was looking at pictures of these tubular cross members on the internet yesterday and most of them seem to have a second slot for the "bump" thing on the motor mount.
Threads Similar to: New PA racing tubular kmember just came in...
Tubular kmember ?'s ..... 99v6stang V6 Mustangs 29 September 1st, 2008 08:53 PM
Kmember removal/replacement alabamastanger 5.0 Mustangs 2 May 16th, 2008 01:16 PM
bent kmember 99v6stang V6 Mustangs 6 March 26th, 2008 05:18 PM
v6 kmember = v8 kmember????????? 99v6stang V6 Mustangs 7 March 7th, 2008 09:42 AM
tubular front kmember Invictus 99-04 3 June 23rd, 2007 08:50 AM
