strut bushings
LinkBack (1) Thread Tools
Old September 18th, 2008, 10:45 PM   1 links from elsewhere to this Post. Click to view. #1
mustang_jim85's Avatar
2000 mustang V6
mustang_jim85 is on a distinguished road
Send a message via AIM to mustang_jim85
strut bushings
Hey. So I was wondering how hard it would be to change my strut bushings cuz I think they're bad. Whenever I go over a bump I hear this loud squeaking from the driverside rear. Does that sound like my strut bushings?
42% reduction crank and HO waterpump pulley
K&N FIPK Gen II
sct livewire
Old September 18th, 2008, 10:46 PM   #2
HMUSN's Avatar
iTrader: 9 reviews
you have shocks in the rear bro. not struts.
Old September 18th, 2008, 11:14 PM   #3
2000 mustang V6
Oh haha. I'm new to actually doing work on my own car so I'm still getting to know all this stuff. But Thanks for the heads up
The reason I was thinking that cuz I was searching for info on the problem and came across a thread that sounded exactly like what I was hearing and greenfaleen, I think, said it was the guys strut bushing.
Any idea what my problem might be?
K&N FIPK Gen II
sct livewire
Old September 18th, 2008, 11:39 PM   #4
97fordsixer's Avatar
97 single port w/bolt ons
n/a
97fordsixer will become famous soon enough
have a friend bounce the back bumper while you lay on tha ground and try to pinpoint.good luck
bolt ons for now..... split port swap very soon....
Old September 18th, 2008, 11:41 PM   #5
MM's Resident Ricer
GreenFaleen's Avatar
2006 Scion tC
13.001@113
yeah probably the bushings easy fix
NCMM #9
Old September 18th, 2008, 11:45 PM   #6
2000 mustang V6
So I can just go to autozone or whatever and buy some new bushings right? What do I need to get strut bushings or what? And basically how do I do it?
K&N FIPK Gen II
sct livewire
Old September 19th, 2008, 02:55 AM   #7
LikeYouStoleIt's Avatar
LikeYouStoleIt is on a distinguished road
Chiltons manuals are extremely renowned.
Old September 19th, 2008, 10:02 AM   #8
2000 mustang V6
Ok. Well io have a hayes manual, which sometimes isn't sop helpful, so I'll check it out and try to figure it out. Thanks everyone for helping a noob haha
K&N FIPK Gen II
sct livewire
Old September 19th, 2008, 10:53 AM   #9
MM's Resident Ricer
2006 Scion tC
13.001@113
yeah just go get a new bushing kit, normally comes with all of them and take out your rear shocks (youll need to rent a spring compressor) and pull them out and reseat the bushings
NCMM #9
Old September 19th, 2008, 01:28 PM   #10
2000 mustang V6
K will do. Thanks.
K&N FIPK Gen II
sct livewire
Old September 19th, 2008, 01:40 PM   #11
stephen has a spectacular aura aboutstephen has a spectacular aura about
Is the noise from the front or back of the car. As mentioned, try bouncing each corner of the car to see where it's coming from.
If it's the front there are strut top mounts with rubber bushings and you can replace those. I would think it could also be a ball joint or lower control arm bushing.
For the rear there is a shock not a strut and you could replace those. Here it could also be a control arm bushing.
Old September 19th, 2008, 02:51 PM   #12
AJRight 2008's Avatar
AJRight 2008 is on a distinguished road
Send a message via AIM to AJRight 2008
That is the weirdest thing i have the same sound coming from my passenger side shock. A friend of mine who works at a tireman near my house said i had a blown shock? idk if that helps....
Old September 19th, 2008, 05:06 PM   #13
2000 mustang V6
Hmmm well I was thinking about getting a v6 suspension kit from steeda. I might just go ahead and do that
K&N FIPK Gen II
sct livewire
Old September 20th, 2008, 03:39 AM   #14
scubasteve041186's Avatar
2004 mustang 40th annv.
scubasteve041186 is on a distinguished road
Send a message via MSN to scubasteve041186
you know what. i never used a spring compressor. and i even did the stuff by myself in under a couple hours for the rear and the front springs were even easier.
i changed my struts and shocks and the isolators on my springs.
* next time i take all this crap off i'm video taping it cause its a hell of alot easier then using the stupid spring compresser I had.
only bad thing i could say was i literally kicked in my front springs.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/v6-mustangs/89463-strut-bushings.html
strut bushings This thread Refback September 22nd, 2008 08:51 PM
Threads Similar to: strut bushings
CA Bushings 99cobradroptop 99-04 6 July 23rd, 2008 03:50 PM
Poly Bushings vtmustangs 2005 - 2010 10 March 6th, 2008 03:52 PM
Bushings On 88 Vert ridebmxfbm 5.0 Mustangs 1 November 19th, 2007 04:29 PM
bushings superbeef1000 99-04 4 August 12th, 2007 07:27 PM
Help with Bushings Flomaster_Knockoff General Tech 0 May 19th, 2007 02:37 PM
