Discussing Clutch Pedal in the V6 Mustangs Forum. My clutch pedal inside my car vibrates bad at low RPM's. Anyone know why ...
Old December 4th, 2006, 04:11 PM   #1
Clutch Pedal
My clutch pedal inside my car vibrates bad at low RPM's. Anyone know why it does this and how I can fix it.. I will check back after I am done with a class..
BTW anyone near the lexington, KY area? I go to EKU here..
95 ' v6 Mustang, 5 Speed.
Old December 4th, 2006, 07:16 PM   #2
I am guessing the pedal is loose, but I would'nt know lol.
Old December 4th, 2006, 07:30 PM   #3
I would question the original installation of this clucth/flywheel combo. If the master cylinder is old then that could be it. If the shake or bounce continues when you engage and disengage the clutch pedal, then it has to be the rotating assembly---something warped, either the clutch disc or the flywheel; or an improper installaton.
If everything checks out here and you still have the same problem, then you might want to check the crankshaft end play.
Old December 4th, 2006, 09:44 PM   #4
shamdoodie's Avatar
2000 V6
no clue as to why clutch vibrates, possibly loose or worn parts or so I would think... then again I am a car newbie so don't quote me.
I am in Lexington here, though not too many people on the boards I visit admit to it if they are as well,
Also, kinda funny/odd - the "unofficial featured ride" as I am typing this is the same color and 1 yr difference than mine... weird how that happened twice now in the few posts I have made here... anyway, i will shut up now
Old December 5th, 2006, 03:36 PM   #5
if ur tlking about the 95, then it is cable operated, not hydrolic so its not the cylinder. i have heard that flywheels that are warped doing that.
Old December 5th, 2006, 08:50 PM   #6
MM Phantom
Onemanzu's Avatar
Location: looking for free hand jobs in poland springs nebraska... silly gooses
... just get under your dash with a flash light and check it all... its bound to be their... make sure your car is off... so you can look at it with out the vibration...
Back for brotherly love. My thoughts are with you Bubba!! [9-23-08]
Originally Posted by omz
Threads Similar to: Clutch Pedal
clutch pedal problem HELP!!! mustangman36578 Drivetrain 9 August 7th, 2007 05:38 PM
Squeeky clutch pedal... 1FastFox 2005+ 5 June 4th, 2007 08:38 PM
clutch pedal xxrals22xx Drivetrain 12 March 4th, 2007 02:07 AM
clutch pedal assembly... 97TunedMustang V6 Mustangs 3 May 25th, 2006 09:57 PM
Clutch Pedal 2002Beast 99-04 9 April 28th, 2006 01:28 PM
