2004 3.8 and love it!
Quarter mile, whats a quarter mile?
rear end conversion.......
Is it possible to convert the 7.5 28 spline to 31 spline without swapping the whole rear end? I finally have the cash to fix my axels and will be swapping them out with Mosers, news bearings, C clip elims and a Tlok.
I don't play well with others!
Just a big waste of time and money then.
Can anyone tell me the length of the 04 axels? I'm ordering a set of Mosers next week with some other things. Thanks........
you WILL NEED A 31spline diff,tlok, posi unit w/e you want to call it
to use 31spline axles there is no 31spline 7.5 diff so it wont work the strongest you can make a 7.5 is by throughing a detriot 28spline trutrac(7.5) and 28spline moser axles that should leave you good til 400-450rwhp+
No I am not trying to do a 31 spline 7.5 now that I know it can't be done. The reason I am getting new axles is because my rear driver side axle is scored where it rides within the bearing. I had the bearings changed when I first got the car last year and now it's out of warranty. I would do the 8.8 swap but there are none to be found in the DFW area (as I have called every single salvage yard within a 100 mile radius). Thanks for the info guys, now I just need to know the length of the axles and I will be good to go.
Hey Chris, the only one I could find is for a GM 7.5. Would that be the same as ours?
Eaton Detroit Truetrac Differentials - summitracing.com Which one would it be for us?
Never mind, I found it.....
Detroit Locker 912A316 - Eaton Detroit Truetrac Differentials - summitracing.com Stupid question though, would I still need a tlok with this?
No... that IS an aftermarket "tlok".
1993 2.3L Coupe [Motortopia] : Open-Track Project... 216k miles 2000 V6 (Black,5-speed) [Motortopia] : Heads/Cam (EXHAUST CLIP) 2001 Harley Davidson F-150 Acts 16:31 |
Thanks Blainestang....... now if I could just get the axle lengths I will be good to go
Threads Similar to: rear end conversion.......
| 8.8' Rear end vs. 9" rear end | jhooper | Classic Mustangs | 22 | April 25th, 2011 03:59 PM |
| Rear Brake Conversion | 90mustang | 5.0 Mustangs | 1 | August 18th, 2008 08:28 PM |
| rear disk brakes and rear end | extropy | Classic Mustangs | 3 | August 11th, 2008 06:41 PM |
| 8.8 rear end conversion | flattusmaximus78 | V6 Mustangs | 13 | October 4th, 2007 09:51 PM |
| 90 rear disc brake conversion | 7-up man | 5.0 Mustangs | 8 | July 1st, 2007 02:56 PM |
