Discussing u joint going out? in the V6 Mustangs Forum. Hey guys recently i was sitting in my car at school with the ac on ...
Old September 24th, 2008, 03:40 PM   #1
u joint going out?
Hey guys recently i was sitting in my car at school with the ac on and i hear like a vibration from the rear end i get out because it sounds like somthing is rattling in the trunk and its pretty loud outside the car it sounds like somthing tensing up? i dunno how to explain it .. so i looked under the car today and i grabed the driveshaft and i can move it is this normall being able to move the drive shaft like twist it just an inch or so but it moves any ideas maybe i could get a vid later?
full exhaust custom H pipe,cai, t-spacer, ud pulleys, 75 wet shot of nitrous, mach 1 rims, Xcal 2 custom tuned nitrous 87 93 octane VMP
9.1@80.07in the 1/8th mile
Old September 24th, 2008, 03:47 PM   #2
Editor
98stangv6's Avatar
1998 Mustang V6 SLOW
17.13@80.85
when your driving check for vibrations from your steering wheel, then that could be a u joint problem... I remember when my u joint broke off i had hardcore vibration on the steering wheel
Vote for me for ROTM
Old September 24th, 2008, 04:08 PM   #3
ya it does kinda vibrate so does my shifter is that a probleme?? how much does a new u joint cost with laber and everything?
Old September 24th, 2008, 04:12 PM   #4
Editor
98stangv6's Avatar
17.13@80.85
well when i replaced mine i had to replace my rear shocks. parts and labor was $200.. i think a u joint is $15-30 im not sure how much labor is.
Old September 24th, 2008, 04:18 PM   #5
Old September 24th, 2008, 05:21 PM   #6
theres a vid i hope someone can tell me what that weird noise is??
Old September 24th, 2008, 06:38 PM   #7
anyone?
Old September 24th, 2008, 06:51 PM   #8
Editor
98stangv6's Avatar
17.13@80.85
take it to a shop and ask them about it
Old September 24th, 2008, 08:17 PM   #9
Assassin_Dan's Avatar
1998 Mustang V6
well your u-joint isnt even spinning, so its in your diff, spider gear maybe
All work and no fiddle makes fiddle a fiidle fiddle
Old September 24th, 2008, 08:49 PM   #10
it would spin in neutral?
Old September 24th, 2008, 09:06 PM   #11
the differential isn't spinning either. maybe something before the driveshaft?
Old September 24th, 2008, 09:10 PM   #12
well in the vid u can see that there was some fluid leakage i dunno from what but it was a brownish color and it wasent there before it started making noise i have never had a leak in that car.
Old September 24th, 2008, 10:38 PM   #13
It's not from the driveshaft or differential since they are not moving.
Could be from the engine, torque converter, or something touching in the exhaust.
See if you can tell where the noise is coming from.
Old September 24th, 2008, 10:48 PM   #14
97fordsixer's Avatar
97 sixer
n/a
my guess from vid is exaust leak or material from cat bangin around between cat and muffler? any one else. def not u joint cuz it aint movin...
http://www.moddedmustangs.com/forums...pic11956_1.gif
she's pretty stock but the best car I've owned.
Old September 24th, 2008, 11:19 PM   #15
well its deff something in the rear end the noise is coming from the rear.
Old September 24th, 2008, 11:20 PM   #16
i thought it had somthing to do with the drive shaft because you can see some fluid leaking and its never done that before.
Old September 26th, 2008, 02:12 AM   #17
1998 Mustang V6
In your video nothings moving though, in order for sounding to be coming from the diff your wheels have to be turning. It has to be something else, like what was said above exhaust leak, a rattle or something has come loose. You really just have to pin point that noise.
Old September 27th, 2008, 11:37 AM   #18
ya i took it to the shop i always go to and of course when i get there it dosen make the noise so i should him the vid on the comp and he said it was not in the rear he said it might be my exhaust vibrating againts somthing or other.
Threads Similar to: u joint going out?
Ball Joint repair. sixxxshoooter V6 Mustangs 14 July 28th, 2008 12:15 PM
stock u joint strength? 91cobra5.0 5.0 Mustangs 0 July 18th, 2008 03:30 PM
lower ball joint theodoor24 Classic Mustangs 5 April 26th, 2008 08:19 PM
u joint mustangrebuilder Classic Mustangs 1 March 26th, 2007 09:55 AM
u joint quicksix 5.0 Mustangs 3 January 2nd, 2007 08:55 PM
