03 v8 motor in a 04 v6
I saw a engine from a 03 mustang v8 and could all the sensors and everything connect to my v6. The engine is under $ 2K with only 9K miles on it. How much would it cost to have this thing working in my v6, not counting the cost of the engine, just the installation?
it'll work
probably like a $1k job its harder then you think. a v8 with one wheel peel...
¡ʇsnq ɹo uʍop ǝpısdn
... mos def switch the rear end... the 7.5 will be under so much stress from the 4.6
just remember this..."you can do anything to a car with a little fabrication"
The LS1 was finally subjected to a paternity test, and it's daddy was to '03 Cobra |
#5 | |
you can stick a vtec in there. idk why you would but u can
LOL...
Why would someone put a Vtech in a mustang????
#7 | |
i considered that once... when i found out that my dads civic had vtec... i like the sound the vtec makes... its very humbling
so if i get this motor for 1,200$ itll cost another 1000 and ill have a v8 in there?
MM's Resident Ricer
2006 Scion tC
13.001@113
easily plus alittle bit more beefing up the rear end.
yupp, its not just dropping in a v8 dude like you think
you can but soon that rear will have to be improved, computer, electronics have to match inside so that you speedmeter and rpm gauge and the other gauges are all correct. your front end will be a little lower then it was before probably. exhaust will be needed unless you wana run open headers which at 1500rpms will be very loud alone i'd say in the end it'll cost near $3k+
MM's Resident Ricer
2006 Scion tC
13.001@113
If it helps any I just got quoted on dropping a 351 into my 6 (easy to do surprisingly Saleen did it on all the s351's from 95-00) and it will cost me 2875 to get it all done and correctly. That doesn't include the cost of parts.
ha! i was gonna get a s/c but i gues im gonna go with the v8. (always wanted a v8 mustang!)
what?! why? $1,200 for the engine
$1k to install who knows how much to correct everything inside, it can be $0 or couple hundred, 8.8 rear-$500-$1,200k...$500 if your LUCKY! you'll need a new face gauges cause you have new rev limits exhaust..you need headers, a mid pipe and cat back. that can be $400-$1,300, $400 for GT take off if you find it that cheap wiht the headers, that are actually just exhaust manifolds. not including installing so its garunteed about $2,600. with out the rear and sayin that the computer and electronics and bullshit is $0 or nothign to work on but it can easily be $3k which it most likely will be. or more if you want the 8.8 rear...which will be needed eventually unless you put t-lok and beef of the rear which is still $500+ so it'll be around $3k-$4k tell me how in the world can that be compared to putting these options power pak (beat a GT) or turbo (beat a GT) or supercharger (beat a GT) or nitrous (beat a GT) or full bolt ons (which can keep up with the GT's) or forged internals, 8.8 rear, and some other mods(might not beat a GT but MUCH stronger then a GT engine) all that is the same price or cheaper! like the power pak-$2350 for stage 3 which add 90hp nitous-$500 bolt ons- $2,500 s/c-anywhere from $2k-$4.7k you better off selling your car for a GT in no way does that swap make sense on doing
MM's Resident Ricer
2006 Scion tC
13.001@113
yeah I mean if you do wanna put an 8 in your car that bad go with a crate engine like a 302 or 351
probably cheaper to just buy a V8
both above me are right
if you really wana swap....why get justa stock GT engine? a 302 or 351 is better but its also gunna be cheaper to sell your and buy a GT
i cant sell it cause im making payments on it still. and one reason that i want a v8 is for that sound
#19 | |
#20 | ||
Threads Similar to: 03 v8 motor in a 04 v6
| need some help american motor to import motor | wadepetersen | V6 Mustangs | 29 | May 30th, 2007 10:26 AM |
| V8 motor | wannabeimportkiller | 5.0 Mustangs | 2 | May 29th, 2007 06:51 AM |
| How do you find the motor code on a 88 5.0L motor? | semihemi428 | 5.0 Mustangs | 1 | March 16th, 2007 05:56 PM |
| Best Motor Oil | Vendetta | V6 Mustangs | 22 | December 17th, 2006 05:43 PM |
