#41 |
haha my bad anyways yeah bad camber.. -3.8 and -1.9 i think is what my tires were at even with the c/c plates. pretty brutal
#42 |
2004 mustang v6
n/a
how did yo fix this problem??with the bump steer kit??
#43 |
well i'm gona see if i can screw the end links in further. or i'm going to go to the top of the strut and have to do this
Spring install on |
#45 |
thanks, spent hours looking on how to fix my camber and came up with this. but i really think the grinding will be a long process. i know when i drilled holes for my tower brace it was a pain in the ass... get good drill bits..
anyways thank the guy with the write up as well. i'm glad he posted about it. |
#46 |
¡ʇsnq ɹo uʍop ǝpısdn
be careful when using a dremel... I think i burned mine up today with regulated periodic use. 5 minutes of cutting/grinding 30 minutes of breaks... lasted 4 intervals then died.
#47 |
MM's Official Lucifer
That write-up seems like it would work, however with changing the position of your tie-rod ends your car may pull to either side. I imagine if you tighten each side eqaully it wouldn't be a problem, but when I installed the bumpsteer kit they warn to install the new ends on in the exact position that the stocks were.
#48 |
yeah i was planning to mark that off (original spot) and go in a couple threads on each side.
Threads Similar to: lowering springs problem!!help!!
| Drag springs or lowering springs??? | AggieStang | General Tech | 10 | February 18th, 2012 12:45 PM |
| New Lowering springs | sneakygt91 | Classic Mustangs | 1 | May 16th, 2008 08:03 PM |
| Lowering Springs | energiesource | 99-04 | 13 | April 30th, 2007 12:04 AM |
| Lowering Springs | DCstangGT | 99-04 | 44 | October 6th, 2006 06:03 AM |
