Discussing Engine knocking and code p1260 in the V6 Mustangs Forum. So my new car (94,xxx miles) has what sounds to be a pretty severe ...
Old October 6th, 2008, 09:50 AM   #1
99v6stang's Avatar
So my new car (94,xxx miles) has what sounds to be a pretty severe engine knock.
-It starts as soon as the car is started
-It sounds kinda like metal clanking metal, and at about 55mph from inside the car it sounds like a machine gun.
-It normally seems to go away when the clutch is pushed in, but some times it just gets fainter
-It does get faster/louder as the rpms increase
-Sometimes if i let of the gas it goes away, but not always
The only code it is throwing is p1260 (theft detected), but i just realized i used a strattec key and not the Ford key so im assuming that was what caused the code. The knocking was present before the code so i think they are unrelated anyways
My car ---- (m112 in progress)
Old October 6th, 2008, 10:42 AM   #2
99v6stang's Avatar
I pulled all the plugs, they were bosch platinum fusions, and they all looked fine, maybe just a little white on the drivers side.
Old October 6th, 2008, 11:02 AM   #3
SP00LIN V6
2000 Mustang V6
unknown @390
first of all those are the worst plugs you could probably use. when did the knocking sound occur?
how long has this car been running since you tore it down
437rwhp and 402rwtq through a V6 on a stock bottom end
Old October 6th, 2008, 11:34 AM   #4
99v6stang's Avatar
yea, they were the plugs that came in the car, i just picked the car up today. i pulled those plugs and have some old autolite platinums to use. I dont know how long the engine has been knocking, the previos owner told me nothing.
how long has this car been running since you tore it down? not really sure what your asking here, i picked up the car at about 6 am, drove it straight to my house, and then pulled the plugs and checked compression, that is all. Compression is....
Cylinder 3- 175 Cylinder 6- 140
Cylinder 2- 165 Cylinder 5- 165
Cylinder 1- 140 Cylinder 4- 165
as far as engine modifactions that i know of its just an ebay looking cai, shorty headers, plug wires appear to be aftermarket ( they are completely plain no words anywhere), red top optima battery. The tb is very dirty/oily behind the blade. Im thinking possibly a rod bearing or two?
Old October 6th, 2008, 12:04 PM   #5
99v6stang's Avatar
And not that this sounds at all like an exhaust leak, but i decided to check if the headers were tight, and they were but on the passanger side something shot sparks on the third bolt back, guess i should have disconnected the battery. I'm wondering if there is anything i can do for this engine, or if its shot.
Old October 6th, 2008, 02:12 PM   #6
This looks like a good used engine
eBay Motors: Ford 99-04 Mustang V6 3.8 Engine Complete Motor 37K MI! (item 280273016197 end time Oct-30-08 21:11:26 PDT)
Old October 6th, 2008, 02:13 PM   #7
So are you saying you put a used engine in your car and there is rod noise right away?
You should be able to get your money back for that engine.
Old October 6th, 2008, 03:21 PM   #8
SP00LIN V6
2000 Mustang V6
unknown @390
so your high is 175 and low is 140 thats more then 10% difference
do you know of any tune that might be on the car
i forgot you got another sixer, im assuming your talking about that one.
Old October 6th, 2008, 07:49 PM   #9
99v6stang's Avatar
Yea, this is my new car. Not a used engine i just dropped in, the stock one that came in this car. I already have a different engine to drop in but was hoping to get this one working to put in my old stang
Old October 6th, 2008, 07:54 PM   #10
99v6stang's Avatar
I dont know of any tune no, i know very little about this car, but just found out today it has bilstein shocks and struts, yay
Old October 7th, 2008, 10:17 AM   #11
As to the engine in the car, from what you say it has rod bearing problems. Most likely it will need a new crankshaft. The good news is that a new one from Ford is ~$250. So with a new crankshaft and bearings you could fix it.
It would be cheaper to go with the used engine I showed you and keep this one for parts.
Old October 7th, 2008, 11:55 AM   #12
99v6stang's Avatar
ya i just pulled the motor out last night and am droppi my old one in this car
Threads Similar to: Engine knocking and code p1260
engine knocking Monster90 99-04 6 September 29th, 2008 07:32 PM
dtc code P1260 vortech4.6l 96-98 24 June 23rd, 2008 10:44 PM
Need Advice (Engine Knocking) DeathScythe95 V6 Mustangs 37 November 14th, 2007 10:31 PM
Engine Knocking Cricket 99-04 5 November 13th, 2007 06:19 PM
Engine knocking 99v6stang V6 Mustangs 8 May 21st, 2007 02:46 PM
