1994 Mustang v6
The classic "stuck on defrost" problem
Hey guys, haven't been online in a while but just recently had some trouble and figured this was the place to go. A few days ago my vents stopped working and every air setting simply stays on defrost/feet. The AC still works fine, just only in the defrost direction. I did a good amount of research and figured from what I've read it's probably the vacuum hoses, however none of the results online have explained how to go about repairing them (or whatever else it may be).
So far I've tried following the hose from the firewall, however Im really unclear which hose I need to be following and for how far, and what exactly Im looking for since Im still pretty new at this (any pictures would be great). Ive also taken out my dash cd player examined the back of the fan settings for the "yellow wire" though once again not sure what Im supposed to do from there. Basically Im stuck and could use some step by step expertise. Thanks in advance 1994 v6 btw |
Tricycle
Yup, you have a vacuum leak somewhere, my car does the same thing whenever I get on the gas.
The soul stealing Ginger
sounds like that switch panel that controls which vents open and close.
![]() Cosmetic: Vent-visors, Pioneer Bluetooth Radio Deck, 17" Cobra Alloy Rims, HID 4500k 55watt setup, Chrome Headlamps 15% Tint, Red sway bar Performance: CAI,Mac-Longtubes, H-pipe, Flow 40s, NO CATS Diablo Tuner, Rear Sway bar |
my 94 has the same problem, working on it when i do the motor swap
2003 Mach 1, 5 speed ![]() U.S. Army - 11B "And on the 8th day god created the infantry and all hell stood at attention" |
1994 Mustang v6
awesome, good luck with that. If you can, let me know how it goes, Im trying to figure out at this point what I need to do and how haha, unless I just end up taking it to midas
Aloha Kanaka
same problem happened on mine....check on the firewall at the top on the drivers side where there is the junction block of vaccum hoses..i think its the second one down...says AC by it..and follow that hose..mine was broken right in the middle above my intake manifold
![]() 94v6.CAI,Exhaust,3:73s-needs rear end rebuild 02GT/Saleen.built motor,62mm turbo 412hp/446tq @10psi,stock TB and intake |
#7 | |
1994 Mustang v6
Aloha Kanaka
i believe it says on the tri-connector piece on the drivers side firewall
Threads Similar to: The classic "stuck on defrost" problem
| Engint "tick" problem | 96cobraclone | 96-98 | 0 | October 4th, 2008 06:13 PM |
| Okay, so girlfriend "problem" | f8youthmidman | The Clubhouse | 176 | July 21st, 2008 09:33 AM |
| Rob Zombie remaking horror classic "Halloween" | coreysr5 | The Clubhouse | 13 | August 20th, 2007 10:16 PM |
| What determines a "classic" ? | Mistarella | Classic Mustangs | 13 | February 14th, 2007 01:53 PM |
