Discussing Missing Problems in the V6 Mustangs Forum. I have a 2002 v6 mustang, the problem i am having is the mustang is ...
Old October 10th, 2008, 05:08 PM   #1
Missing Problems
I have a 2002 v6 mustang, the problem i am having is the mustang is missing
when i first start out and at higher speeds it seems to go away. Hope someone can help. Thanks. P.S. I have new spark plugs and new MSD 8.5
plugs wires.
Old October 10th, 2008, 05:39 PM   #2
RavensChild's Avatar
1998 Mustang Coupe
Amazing
missing? miss firing?
Car Tuned By Joe At TrickTuners.
Originally Posted by 96GTRagTop View Post
u have no idea the amount of porn i go through in one day
Originally Posted by TurboLX View Post
how the hell did you get the arrow to point down?
Originally Posted by GenevieveD View Post
its the letter V ..silly
I have made Zip ROFLMFAO, have you?
Old October 10th, 2008, 05:39 PM   #3
Resident MM Ricer
GreenFaleen's Avatar
2006 Scion tC
13.9@103/8.9@81
get the code read and see what cyl. it is, if it it 2 parallel cyl (1&4,2&5,3&6)
then it is the coil
Scion Tc-strup racing header, CAI, Ground Kit, NOS 100shot, Custom suspension, Doc. I 50% STS
Thanks To My Sponsors:
Strup Performance
Old October 10th, 2008, 07:20 PM   #4
Check the codes, nothing was showing.
Old October 10th, 2008, 07:38 PM   #5
dgt_mustang's Avatar
01 mustang
plugs fouling up?,
LEAVE REP POINTS WHERE NEEDED!!!
2001 mustang V6
CAI,Tuner,Cobra Rims
To come:
UDP, T-lok, 3.73, full exhaust setup W/flowmaster 40s, aluminum driveshaft.
Old October 10th, 2008, 08:01 PM   #6
04mustang232's Avatar
2004 Mustang V6
14.4@ 96
check your wires, i put brand new wires on and two days later it burned on the EGR pipe. Also, your coil might be going bad.
Somebody registerred me at blacksingles.net
Old October 10th, 2008, 08:12 PM   #7
Resident MM Ricer
2006 Scion tC
13.9@103/8.9@81
no code its not missing, change your air filter
Strup Performance
Old October 10th, 2008, 10:16 PM   #8
I have a new K&N CAI. Replace spark plugs 4months ago. Maybe i well replace the coil
with a new one, thinking about scremin demon one. I will take a look at the plugs wires
also.
Old October 10th, 2008, 10:20 PM   #9
Resident MM Ricer
2006 Scion tC
13.9@103/8.9@81
if your not throwing a code its not missing, whats it doing that makes you think its missing
Strup Performance
Old October 10th, 2008, 10:21 PM   #10
Mod Johnson
WLJohnson05's Avatar
2004 Mustang V6
also.
make sure u have the plug wires hooked up with the right plugs and coil. if u have crossed a wire it will cause the car to sound like its missing
Originally Posted by Onemanzu
put the shiny thing next to the dudad and get this thingymagigger and connect it to the hoptey dooo and your all good
And we're done.
Go vote for me for ROTM!
TURBO on 7.2psi
CHECK OUT MY WEBSITE
Old October 11th, 2008, 01:40 AM   #11
SP00LIN V6
2000 Mustang V6
unknown @390
did this happen AFTER you replaced the wires?
and what spark plugs
im almost sure you probably have the drivers side wires hooked up incorrectly
437rwhp and 402rwtq through a V6 on a stock bottom end
Old October 11th, 2008, 01:45 AM   #12
Mod Johnson
2004 Mustang V6
thas what i was thinkin too...been there done that
And we're done.
TURBO on 7.2psi
Old October 11th, 2008, 01:32 PM   #13
copper autolites sparkplugs I've been using.
Old October 11th, 2008, 01:43 PM   #14
Mod Johnson
2004 Mustang V6
did u check to make sure the wires werent crossed?
And we're done.
TURBO on 7.2psi
Old October 11th, 2008, 04:04 PM   #15
2004 Mustang V6
14.4@ 96
screaming demon requires different spark plug wires, so if your coil is going bad, id rather spend 60 on a new oem coil than 200 on screamin demon and new wires. Try seafoam too. Maybe your injector is clogged.
Old October 11th, 2008, 04:09 PM   #16
Mod Johnson
2004 Mustang V6
im willing to bet he crossed up a wire
And we're done.
TURBO on 7.2psi
Old October 11th, 2008, 06:33 PM   #17
Like i said early i am using the MSD 8.5 wires.
Old October 11th, 2008, 06:59 PM   #18
Mod Johnson
2004 Mustang V6
what we are asking is if u put on the wires in the right spots. its very easy to mix it up, especially on the driver side.
And we're done.
TURBO on 7.2psi
Old October 11th, 2008, 08:23 PM   #19
Took the old wires off one at a time. Then replace the MSD wires and started with the
longest wire to shortest wire. I hope that makes any sense.
Old October 11th, 2008, 08:52 PM   #20
Mod Johnson
2004 Mustang V6
i kinda understand. just might wanna check it. make sure u have the right wire running from the right plug to the right coil. if thats not ur problem, check ur plugs, make sure they are all clean.
And we're done.
TURBO on 7.2psi
