Do i need a spring compressor?
Do i need to have a spring compressor to install my springs and cc plates?
![]() JAKE'S PIITB CREW MEMBER#4 |
MM's Resident Ricer
2006 Scion tC
13.001@113
yes, they re cheap to rent and doing it without one can be relly dangerous
Ok i was just wondering because on a how to they put the jack on the lower control arm and did it that way
MM's Resident Ricer
2006 Scion tC
13.001@113
yeah you can do it that way, but when that spring slips and flys across the room you wont be happy
ok spring compressor it is lol
haha yeah i dunno i haven't had any problems without one. i'll grab you the write ups if you don't want to use a spring compress. but its a pain getting the spring back in. but i didn't take the caliper off either
cause i'm pro like that.only thing you might have to worry about it making sure you put the c/c on right. which ones did you get? |
ps. i have hydrualic jacks. and that makes a difference i would think. when letting the arm down.
mm 4 bolt cc plates
k almost the same deal as my bbk ones. just make sure to tape off where the old set ( camber plates ) were; orienation wise.
Need? No.
I've done several swaps on Foxes and New Edges, and never had a problem just disconnecting the strut and letting the A-arm down. I'm not saying DON'T get one, but you don't NEED one.
1993 2.3L Coupe [Motortopia] : Open-Track Project... 216k miles 2000 V6 (Black,5-speed) [Motortopia] : Heads/Cam (EXHAUST CLIP) 2001 Harley Davidson F-150 Acts 16:31 |
definately dont need one. did my fronts and backs several times with just a jack and some jack stands.
¡ʇsnq ɹo uʍop ǝpısdn
bah fuck spring compressors, just get a chain or tow strap and don't have your face too close.
no, you don't need one. two guys with 2 prybars. turn the spindle loose and one guy uses a prybar to pry down the a-arm and you use your prybar to pry the new spring into place. 10 minutes at topps. it's kiddie shit
[SIGPIC][/SIGPIC] [SIZE="4"]"This just in....14.79 @ 92.15 is not fast"[/SIZE] |
Two jacks and common sense is all it takes. Let the jack down SLOW, and the spring will fall out like dead weight.
MM's Official Lucifer
Yeah... in my experience a spring compressor made it more difficult by getting in the way. Do as they have said just lower the A arm all the way and use prybars, helps when you have an extra pair of hands.
#16 | |
1999 Ford Mustang V6
14.79 @ 92.15
just put the car on jackstands under the frame rail up front. then preload the springs by jacking up the a-arm. then unbolt the retaining nut on the strut. then removed the 3 bolts/nuts holding the stock plate in place. now lower the jack, and you can compress the strut and pull it out of the fenderwell. now is a good time to replace the bumpstop and install spacers according to your application, reinstall the retaining nut after you bolt up the new plates and set your alignment... when you put load on the suspension, you can best tighten the retaining nut on the strut. spring swap was about 15 minutes per corner. CC plates where about 1/5 hour job for me (removing the retaining nut is a bit of a bitch if you dont have a thick flathead screwdriver that wont bend/break
Threads Similar to: Do i need a spring compressor?
| Emergency/Parking Brake Spring Compressor? | Garhfer | 99-04 | 9 | August 29th, 2011 12:10 AM |
| Spring compressor tool | Jojogunne | 5.0 Mustangs | 4 | September 7th, 2008 11:56 AM |
| Where Is The AC Compressor At? | bazookaj2007 | V6 Mustangs | 7 | September 4th, 2007 09:29 PM |
| a/c compressor | sivart | 5.0 Mustangs | 0 | June 4th, 2007 03:19 PM |
