Dyno'd the new setup today :)
LinkBack (2) Thread Tools
Old October 14th, 2008, 04:54 PM   2 links from elsewhere to this Post. Click to view. #1
2004 Mustang V6 Vert.
328/419 @ 4000 rpms
plove71387 is on a distinguished road
. . . 328rwhp / 419torque @ 4000 RPMS pegged the maf for some reason and its only the break in period Once engines broken in and then its time for a retune and up the boost till it hits 500+rwhp
Last time i saw the car it looked like this about 2 months ago or so,
No picture of the dyno sheet yet. but heres a picture of the engine bay.
Turbo
Mods:
TMA Street/Strip turbo kit
Turbo headers: 1 5/8" primaries dual 2.5" collector merged into a T4 inlet
Exhaust dump: 3" exhaust dump pipe split into dual 2.5" mufflers
Intercooler: 3" intercooler pipes with 31x12x4" intercooler
Turbo: Pt61 turbo T4 P trim .81 turbine a/r with .70 a/r compressor 4" air filter inlet 2.5" outlet, Tial 38mm waste gate ,Tial 50 mm Bov.
RPM-Mustangs 4.2 Forged Motor
Crankshaft Steel 4.2 Stroke 3.740" Block .20 Bore 3.830" Thermal cleaned, decked, bored/honed with torque plate, balance ARP Head Studs. Mainline honed, Ford Girdle. Rods Scat 4340 Forged 6.125" H-Beam with ARP 7/16" 8740 Cap Screw Balancer Zero'd Factory Balancer Flywheel New Zero balance flex plate Pistons Ross Forged Dished Pistons 8:7:1 compression Chrome Moly pins, Spiralox Piston Rings Total Seal Gapless Rod/Main Bearings Clevite77 standard Cam Reground 214* .567" Intake / 216* .567" Exhaust 112 LCA, 108 IC Lifters New Ford Hydraulic Roller Rocker Arms Harland Sharp 1.73 Billet Aluminum roller rockers Pushrods Comp Cams Hardened 5/16" Pushrods 7.195" Cylinder Heads RPM CNC Street 2 Heads with New Valve Guides and new seals. Springs rated at 130# seat, .580" Lift Capable, stock .86"/1.46" valves with valve job. Ported Upper intake ported lower intake with a matching ported throttle body (From CRT Performance) all new accessories for the motor. Resurfaced and assembled.
BC Automotive Transmission
transmission has solid sealing rings on the output shaft for the direct clutch, a custom modified direct clutch assembly that gets 8 friction plates in place without having to use the extra thin steels, a hardened gear set, a hardened sun gear and sun shell, a hardened intermediate stub shaft, a custom 6 plate forward clutch assembly that is modified for quicker clutch exhaust, a spiral lock kit to hold the intermediate one way clutch securely, an improved 4 plate intermediate clutch, proprietary modifications to the pump, proprietary custom modifications to the valve body to make the transmission shift per needs, a higher pressure EPC solenoid.
Rear End
Rebuild Ford Mustang GT 8.8 Rear with Motive 3.55 Gears, Moser 31 Spline Axle, and Moser 31 Spline axle differential.
Fuel System
Cobra fuel tank, Dual FPDM, Fore Precision Works dual pump billet top hat, Dual GT40 Super car fuel pumps, and 60# Fuel injectors.
Random Parts
Aluminum Drive Shaft, Drive shaft safety loop, Turbo X’s Boost Controller, Auto Meter Boost Gauge, Cervini’s 1995 Style Cobra R Hood, Roush Stage 3 Body Kit w. Wing, Complete Infinity Audio system, X Cal 3.
Link to photobucket if anyones intersted.
plove71387/The Rebuild - Photobucket - Video and Image Hosting
Old October 14th, 2008, 06:20 PM   #2
scubasteve041186's Avatar
2004 mustang 40th annv.
scubasteve041186 is on a distinguished road
Send a message via MSN to scubasteve041186
right on bud i'm impressed. kinda curious why they went with a 214/216 cam though.
Old October 14th, 2008, 06:37 PM   #3
Fox2102's Avatar
'03 Harley Sportster 1200
Fox2102 will become famous soon enough
Send a message via AIM to Fox2102 Send a message via MSN to Fox2102
That's definantly one of the nicer setups i've seen.
Old October 14th, 2008, 08:13 PM   #4
Avaric3's Avatar
2002 Ford Focus
slow as fuck
Avaric3 will become famous soon enough
sick setup, hopefully ill get to see it at the 3.8 maca meet
99 V6 Mustang-sold
02 Ford Focus-sold
98 Camaro Z/28-lid, catback
Old October 14th, 2008, 08:18 PM   #5
328/419 @ 4000 rpms
After talking with the guy that spec'd out the motor thats what he reccomend to use for a DD.
As long as its still up and alive
Old October 14th, 2008, 08:19 PM   #6
Fashion Guru
gooberhead320's Avatar
gooberhead320 has a spectacular aura aboutgooberhead320 has a spectacular aura aboutgooberhead320 has a spectacular aura about
very nice
Originally Posted by 93hatch View Post
goobers car would whoop on ur fox so you sir fail
im so gay i wish my gf was as pretty as goober
I love 93hatch
Old October 14th, 2008, 08:21 PM   #7
MM's Database Error
WLJohnson05's Avatar
2004 Mustang V6
322.8 rwhp
WLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud of
iTrader: 9 reviews
nice man, mines hittin the dyno on thursday
SCT Mass Air Flow Sensor $200
Old October 14th, 2008, 11:15 PM   #8
2000 Mustang
AMR91 is on a distinguished road
Send a message via AIM to AMR91
damn..thats nice
Old October 14th, 2008, 11:45 PM   #9
2004 Mustang V6
04DSGV6 is on a distinguished road
nice setup/numbers. If you did this on break in I can't wait to see the new numbers. Oh btw you forgot to add bungee cords in your mod list
Originally Posted by 06RedfireGT View Post
The idea of smashing your face on it in an accident isn't so sexy.
Old October 15th, 2008, 09:30 AM   #10
Midnight Stang02's Avatar
2002 Mustang v6
Midnight Stang02 is on a distinguished road
Send a message via AIM to Midnight Stang02
im loving the setup
hopefully youll put up a vid soon
Old October 15th, 2008, 09:49 AM   #11
I Poop Entirely Way Too Much
Blown 03 GT
03_StangGuy is just really nice03_StangGuy is just really nice03_StangGuy is just really nice03_StangGuy is just really nice
nice numbers
Old October 15th, 2008, 01:04 PM   #12
thetrooper31 will become famous soon enough
Send a message via AIM to thetrooper31
+1
[SIZE=5][COLOR=Yellow][/COLOR][/SIZE][COLOR=green]
[/COLOR]
Old October 15th, 2008, 11:09 PM   #13
SleeperStang88's Avatar
2000 Mustang V6
need to run at track
SleeperStang88 is on a distinguished road
dam u have the exact setup that i wanted to get this winter, how is it?
Old October 15th, 2008, 11:51 PM   #14
mustangjeff1997's Avatar
96 Nissan D21
Low and stupid.
mustangjeff1997 is on a distinguished road
Very nice setup. Can't wait to see the future numbers. Good work man!
im gona go get me some mc nuggets and breakdance my way home
MY 4 WAS FLAT
LinkBack to this Thread: http://www.moddedmustangs.com/forums/v6-mustangs/93048-dynod-new-setup-today.html
steel body cobra kit cars | Bookmarks URL This thread Pingback October 22nd, 2008 01:16 PM
kit cars in bc canada | Bookmarks URL This thread Pingback October 22nd, 2008 06:07 AM
Threads Similar to: Dyno'd the new setup today :)
getting dyno'd saturday!!! gooberhead320 The Clubhouse 9 September 24th, 2008 10:14 PM
Finally Dyno'd my v6 D Rock V6 Mustangs 32 March 19th, 2008 05:05 PM
Those who have dyno'd. catchtheroadrunner The Clubhouse 4 January 23rd, 2008 08:38 PM
I'm getting Dyno'd on the 9th! Smoothgrandmama 99-04 14 January 4th, 2008 09:30 PM
Got Dyno'd Today tjames V6 Mustangs 61 December 12th, 2007 07:41 PM
