something's wrong with my car
Old October 18th, 2008, 06:26 PM   #1
06 Satin Silver V6
9.440 @ 71.27 1/8th mile
XxViSiOnxX is on a distinguished road
Send a message via AIM to XxViSiOnxX Send a message via MSN to XxViSiOnxX
So today i was trying to Fire up my 1972 Impala Custom that has been sitting in my Garage for 6 Months without moving it or starting it, Well naturally the Battery is Dead and i need to move the car soon so i take the Battery outta my Mustang (since it has enough cold crank) to try and fire up my Impala, It did, so ok i move my Impala to my Drive way and throw in my Torqueless Wonder (350Z) and SI (Honda) into the garage for now and throw the battery back into my Mustang, So now for the part, i fire up my Mustang and it Idles then Damn near conks out it litteraly drops to maybe 300-500rpm's then back up to normal idle, So i figure my Impala sucked some juice from my Battery so i take my Stang for about a 5 minute drive around the Block to get the Charge back up and so i Return shut it off Fire it back up and it did it again, shut it off and on again and sure enough it Continues anyone have any Idea's on wuts wrong? it didnt do this before i removed the Battery.....
MODS: In Garage
Old October 18th, 2008, 08:52 PM   #2
scubasteve041186's Avatar
2004 mustang 40th annv.
scubasteve041186 is on a distinguished road
Send a message via MSN to scubasteve041186
just take the battery out and put it back in. maybe a shitty connection. or... your computer is just relearning your driving habits. should go away in a couple days.
Old October 19th, 2008, 04:54 AM   #3
speedfreak's Avatar
2004 3.9L V6
15.1
speedfreak is on a distinguished road
Are there any check engine lights coming on or anything to suggest something may be wrong.
Race what ya Brought
Old October 19th, 2008, 10:28 AM   #4
stephen has a spectacular aura aboutstephen has a spectacular aura about
When you disconnect the battery you reset the computer to default settings. It may take a little while to readjust the settings.
Old October 19th, 2008, 11:33 AM   #5
N29468's Avatar
2004 Mustang
N29468 is a splendid one to beholdN29468 is a splendid one to beholdN29468 is a splendid one to beholdN29468 is a splendid one to beholdN29468 is a splendid one to beholdN29468 is a splendid one to behold
iTrader: 5 reviews
Send a message via MSN to N29468
If the vehicle is going to sit for longer than a month, you should disconnect the negative post or install a cut off switch. This will prevent the vehicle from drawing any current. Of course when you reconnect, you will have to reset the clock, radio presets, radio code if applicable, the vehicle will run like crap till the computer "relearns" your driving habits.
Old October 19th, 2008, 11:51 AM   #6
MM's Resident Ricer
GreenFaleen's Avatar
2006 Scion tC
13.001@113
you have a bad ground with that low of an idle just take out and put back in the battery
NCMM #9
Old October 20th, 2008, 01:25 AM   #7
06 Satin Silver V6
no warning lights or check engine, also had a buddy come down with his x-cal and he wasnt able to pull any codes so not sure whats going on
well whats weird is i didnt have to reset anything on the radio, all my preset channels were there etc....and my battery was disconnected for about 15 minutes.
i did that and drove it around for 30 minutes and still did the same thing once i parked it and shut it off and fired it back up, so my outcome was to take it to the dealer since its still under warranty lets see wut they find.
MODS: In Garage
Old October 20th, 2008, 02:17 AM   #8
speedfreak's Avatar
2004 3.9L V6
15.1
disconnect the entire battery and let it sit for about thirty minutes. Put the terminals back on and if the radio does not reset its channels then something in the computer is not re-seting.
Old October 20th, 2008, 02:21 AM   #9
N29468's Avatar
2004 Mustang
iTrader: 5 reviews
+1
Or you can try this they talk about hard resets..
Acceleration issue
HARDCORE CREW
Mods: Mac Lt's, O/R H pipe, 40's catback, CAI
Originally Posted by 89StangGT View Post
Your not an American if you havn't tongue stabbed a chicks butthole once or twice.
MM DSG Crew Member#4
Threads Similar to: something's wrong with my car
something is really wrong with my car. 07stanggt 2005 - 2010 28 June 16th, 2008 10:28 PM
What Is Wrong With My Car? 94pacecarSVT 94-95 10 November 10th, 2007 02:14 AM
Something's amiss eckertd Drag 6 September 4th, 2007 09:24 AM
something's wrong 9stang1 5.0 Mustangs 3 April 29th, 2007 10:39 PM
