new gauge cluster install problems plz help theft light
Old December 12th, 2006, 09:13 PM   #1
bigpopaz99 is on a distinguished road
hey fellas im having a problem w/ my roush white gauge cluster when i try to put my new cluster in i get the theft light blink and it wont start plz help thanks
Old December 12th, 2006, 09:15 PM   #2
00 V6 & 09 GT
13.37@104.4mph--BONE stock GT
the theft light...is normal....
the starting..is your engine
give more details...does it crank up and not start...
do you turn the key and nothing at all
main solutions. battery, alternator, tune up
[SIGPIC][/SIGPIC]
Acmillr loves me
Old December 12th, 2006, 09:18 PM   #3
it cranks no start theft light blinks faster than normal the cluster is out of a diffrent car i tryed resetting the battery and cycled the key and reset the remote no go
Old December 12th, 2006, 09:24 PM   #4
00 V6 & 09 GT
my theft light blinks fast...
fuel tank empty..doubt it
battery discharged
battery terminal connections loose or corroded
fuel not reaching injectors-clog somewhere
low cylinder compression
water in fuel
defective ingnition coil(s)
dirty or clogged fuel injectors
wet or damaged ignition components
spark plugs-either no good, or worn, or spaced wrong
wires messed up in starting circut
timing chain failure defective MAF sensor
print that out or write it down and go from top to bottom. those are the main if not all solutions
also check oil
[SIGPIC][/SIGPIC]
Acmillr loves me
Old December 12th, 2006, 09:25 PM   #5
put the stock cluster back in no problem
Old December 12th, 2006, 09:26 PM   #6
00 V6 & 09 GT
so it starts?
[SIGPIC][/SIGPIC]
Acmillr loves me
Old December 12th, 2006, 09:29 PM   #7
ya it starts and runs perfect w/ the orginal cluster
Old December 12th, 2006, 09:30 PM   #8
00 V6 & 09 GT
hmm but you want the new one in right?
[SIGPIC][/SIGPIC]
Acmillr loves me
Old December 12th, 2006, 09:31 PM   #9
i wanna go w/ the roush gauges
Old December 12th, 2006, 09:33 PM   #10
the theft even blinks when its cranking
Old December 12th, 2006, 09:46 PM   #11
00 V6 & 09 GT
might be somethign wrong with the wiring on those gauges...did you buy them new?
[SIGPIC][/SIGPIC]
Acmillr loves me
Old December 12th, 2006, 09:49 PM   #12
i got em on ebay im thinkin its the mileage it doesnt match the ecu wounder if theirs a loop hole
Old December 12th, 2006, 09:57 PM   #13
MM's Resident Ricer
GreenFaleen's Avatar
2006 Scion tC
13.001@113
take to a ford dealer and get it installed. When you unplug and plug into the new gauge it is confusing itself and locking up because it thinks it is being hot wired. My cousin had the same problem putting saleen gauges in his gt.
NCMM #9
Old December 12th, 2006, 10:02 PM   #14
dang i wounder what the trick is
Old December 13th, 2006, 12:04 AM   #15
AtlanticBlue99's Avatar
1999 Ford Mustang V6
14.79 @ 92.15
you have a 99? there are 2 harnesses, one is for the odometer, the other is for the gauges. it will work if you remove your stock circuit board from inside the stock cluster and install the circuit board into the new cluster. it will be correctly callibrated too
ModdedAutos
1999 Mustang V6
Old December 13th, 2006, 02:09 AM   #16
yup 99 i could swap the board out but my lcd display is broken thats part of the reason for the new one . the new one has pretty close mileage as the old one any other ideas thanks
Old December 13th, 2006, 02:14 AM   #17
¡ʇsnq ɹo uʍop ǝpısdn
Onemanzu's Avatar
... well hook it up to a gerbile wheel and have it run a few hundred miles on it... that way they match up
Old December 13th, 2006, 02:19 AM   #18
well i guess its good that i have a friend that lives across the alley from the dealer ill have to go over their install it then have one of the dealer goons cross the alley and check it out
Old December 13th, 2006, 11:03 AM   #19
14.79 @ 92.15
you will need the stock circuit board unless you can use dealer software and get into the computer
ModdedAutos
1999 Mustang V6
Old December 13th, 2006, 12:58 PM   #20
i guess the dealer gotta reflash the theft system man their crayzee $87 bucks per hr
Threads Similar to: new gauge cluster install problems plz help theft light
gauge cluster light blazor V6 Mustangs 6 July 10th, 2007 10:01 PM
Theft Light comes on, but dont have an alarm on the car WTF Mooooose 96-98 6 May 13th, 2007 07:23 PM
swapping '95 V6 gauge cluster to a '94-'98 GT cluster? Alocatelli V6 Mustangs 3 April 4th, 2007 03:38 PM
theft light comes on 4point6GT 96-98 4 October 15th, 2006 12:17 AM
help-- flashing theft light General Tech 20 February 17th, 2006 12:21 AM
