Windstar intake now car wont start/run
Old October 22nd, 2008, 10:16 PM   #1
99v6stang's Avatar
99v6stang is on a distinguished road
OKey i just put on my windstar intake and got it to fit under the stock hood but now the car wont start unles i give it gas but then it knocks or makes a popping sound. Im kinda thinking it has to be a problem with the remote iac seeing as it wont start without gas but i cant see anyhting that looks wrong
My car ---- (m112 in progress)
Old October 22nd, 2008, 11:35 PM   #2
Stang Tech's Avatar
2003 Mustang GT Vortech
Stang Tech is on a distinguished road
Send a message via AIM to Stang Tech
did you install the remote iac in the right direction i know some people installed it wrong and had problems.
Ford Certified Tech Land Rover Certified Tech
Ase Certified Tech Honda/ Acura Certified Tech
AllData Automotive Information Specialist
03 Mustang GT
Vortech V3 Intercooled
407/415 to the wheels
BOOOOSSSTTTTTT
Old October 23rd, 2008, 09:00 AM   #3
00 V6 & 09 GT
13.37@104.4mph--BONE stock GT
you want the remote IAC lines as SHORT as possible
also remember to fill the OLD IAC port up on the top.
if not you'll have a huge leak that the MAF isnt reading.
[SIGPIC][/SIGPIC]
Acmillr loves me
Old October 23rd, 2008, 10:40 AM   #4
MM's Database Error
WLJohnson05's Avatar
2004 Mustang V6
322.8 rwhp
WLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud of
iTrader: 9 reviews
been there done that...+1
i would check and make sure u got all ur lines straight tho as far as vacuum goes
SCT Mass Air Flow Sensor $200
Old October 23rd, 2008, 12:49 PM   #5
stephen has a spectacular aura aboutstephen has a spectacular aura about
This is a writeup for what you are trying to do.
http://www.v6power.net/vb/showthread.php?t=34692
Old October 23rd, 2008, 12:52 PM   #6
MM's Database Error
2004 Mustang V6
322.8 rwhp
iTrader: 9 reviews
Windstar Manifold HOW TO - V6Power Messageboard
he already has it on there and hooked up, he is having a problem now, which is prolly something he has missed, thas usually how it works.
Old October 23rd, 2008, 01:02 PM   #7
99v6stang's Avatar
I did cover up the hole on top, and the lines werent as short as possible, but not crazy long or anything. I tried hooking it up both ways and disconnected it and nothing changed at all. For now i just upped the idle on the trottle body and capped off everything for the iac and this is working fine so far. A little harder to start up in the morning but since then it is working fine. What are the side affects or dissadvantages/advantages of this?
Old October 23rd, 2008, 01:07 PM   #8
MM's Database Error
2004 Mustang V6
322.8 rwhp
iTrader: 9 reviews
no use in rigging something to work...get it fixed right.
do u have pics of the setup? from several different angles
Old October 23rd, 2008, 01:38 PM   #9
99v6stang's Avatar
No use in rigging something to work?
--- I have no other car and have college classes as well as work everyday, i think rigging something to work is a very good idea.
I will try to get pictures later tonight, but basically i had a tube running from the stock iac port on my mac air intake to the smaller side of the iac using a 3/8 fuel line fitting connected to a metal plates, and another tube running from the lowered center fitting on the windstar using the same method. The iac was ziptied by where the plug in was so i wouldnt have to extend the wires. Does the iac need to be grounded perhaps?
Old October 23rd, 2008, 01:44 PM   #10
MM's Database Error
2004 Mustang V6
322.8 rwhp
iTrader: 9 reviews
i mean doing something now so that it works in the short term should be ok, but what i've learned from experience is that just rigging something usually ends up coming back around and making it harder for you to do right in the first place.
ur iac doesnt need to be grounded. just plugged in. so u made something like this?
and have the iac hooked up something like this...
Old October 23rd, 2008, 07:34 PM   #11
99v6stang's Avatar
yes, exactly, i just routed my intake piping forward more infront of the coolant hose so my tube going to the cai is a little longer.
Old October 23rd, 2008, 08:41 PM   #12
MM's Database Error
2004 Mustang V6
322.8 rwhp
iTrader: 9 reviews
u said its popping, did u take the plug wires all off when u did this? i would check them to make sure u didnt cross one
Old October 23rd, 2008, 11:24 PM   #13
OK. After carefully studying the picture in the link I found, I see what you are doing with the remote IAC. This setup requires a MAF in the intake air tube. I thought with the standard manifold you had a standard MAF. So are you using a different MAF now and are you sure it's good ?
I would recommend that any place you splice wires that you solder and tape them rather than use crimp connectors. I believe it gives a better connection. Use a 30 watt or so iron and electronic solder.
Old October 24th, 2008, 03:10 PM   #14
99v6stang's Avatar
Im using a stock maf, just not the one that came with this car, and no its not popping anymore. I have been running the car the last three days without the iac and its running great.
Old October 24th, 2008, 09:18 PM   #15
By adjusting the idle stop screw you are letting some air past the throttle plate at idle. This simulates the effect of the IAC. However, there will be a problem in cold weather, since you will have no fast idle function, so the car may stall when the engine is cold.
It shouldn't be that hard to figure out how to make the remote IAC work. However, it will make no difference when the engine is at normal operating temperature. So I don't think you are doing any harm running it that way temporarily.
Old October 25th, 2008, 07:55 AM   #16
This is a very clean installation which uses the stock IAC. I guess the remote IAC is for hood clearance issues.
1988 Ford Mustang Coupe Engine View Photo
Old October 26th, 2008, 10:08 PM   #17
keeprollin02's Avatar
2000 Mustang V6
keeprollin02 is on a distinguished road
iTrader: 6 reviews
Send a message via AIM to keeprollin02
Im having nothing but issues with the VAP kit...I cant figure out how to clear the piece that is threaded all the way down..forget what its called. Ended up shearing it off at the flange and now having to connect it via hose and clamps. Still having clearance issues because its hitting the freaking throttle body arm the way the VAP kit extends the arm out. So Ive got nothing but a mess...really pissing me off.
Threads Similar to: Windstar intake now car wont start/run
car wont run gyellow 5.0 Mustangs 6 May 30th, 2008 08:46 PM
just rebuilt car and now it wont run.... 99v6stang V6 Mustangs 112 May 6th, 2008 10:52 AM
car wont start Black Five 0h 5.0 Mustangs 8 January 4th, 2008 03:12 PM
car wont start 2007calispecial Modular Mustangs 4 May 18th, 2007 09:05 AM
car wont start help 89hatchback 5.0 Mustangs 6 February 19th, 2007 06:50 PM
