sparkplug help and question?/
Old October 28th, 2008, 05:57 PM   #1
rejectstang's Avatar
2004 mustang v6
n/a
rejectstang is on a distinguished road
ok soo im wanting to change my spark plugs and wires...
how hard is it to change on the v6 ,i was looking at it and it looks like the intake manifold would be in my way.
also what band ov wires and spark plugs do u recommend me
thanks
TEAM X VELOCITY PHX,AZ.
www.myspace.com/preludeh22
Old October 28th, 2008, 06:39 PM   #2
MM's Database Error
WLJohnson05's Avatar
2004 Mustang V6
322.8 rwhp
WLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud of
iTrader: 9 reviews
i recommend ur stock wires, and no nothing is in the way to remove ur plugs
SCT Mass Air Flow Sensor $200
Old October 28th, 2008, 06:54 PM   #3
The George Forman of Keepers
JASonic's Avatar
JASonic is a name known to allJASonic is a name known to allJASonic is a name known to allJASonic is a name known to allJASonic is a name known to allJASonic is a name known to all
iTrader: 20 reviews
Send a message via AIM to JASonic
The pro's around here will say its easy. Since Im not a pro, I will say it was a serious pain in the ass. They were hard to get at and the hole was impossible to see. I suppose if you had the correct rachet extension it would make the job quite easy. I didnt so it was a bitch trying to get to them. Especially the ones close to the fire wall. I even had trouble getting the wire onto the plug right. I did get it done but it took me alot of "knuckle skin" and a few choice cus words.
BTW- I was sold on getting an upgraded wire. The day I went to Autozone, they were sold out of MSD. I went ahead and bought the autozone brand and they have performed just fine. I cant remember which ones, but there are certain plugs that do not work well in our cars. Make sure you do the research.
Old October 28th, 2008, 06:59 PM   #4
MM's Resident Ricer
GreenFaleen's Avatar
2006 Scion tC
13.001@113
stock wires, motorcraft or autolite copper plugs, get a 12in extension and a good spark plug socket and it is easy
NCMM #9
Old October 28th, 2008, 07:02 PM   #5
MM's Database Error
2004 Mustang V6
322.8 rwhp
iTrader: 9 reviews
the only one that was hard really is the last one near the firewall on the driver side
Old October 28th, 2008, 07:21 PM   #6
stephen has a spectacular aura aboutstephen has a spectacular aura about
First you need to remove the air tube on the passenger's side. Then a 5/8" socket, a 4 or 6" extension, and a ratchet are all you need.
For the one on the drivers side near the firewall, #6, put the spark plug socket on it then install the ratchet. The engine should be cold otherwise you may get burns off the manifolds. Put a little bit of aluminum antiseize on the plug threads before reinstalling them and start them by hand using the sparkplug socket. They go back pretty much by feel, since they are under the manifold. They tighten to ~15 ft lbs, which is moderately tight with a 3/8" ratchet.
Old October 28th, 2008, 07:45 PM   #7
04mustang232's Avatar
2004 Mustang V6
14.4@ 96
04mustang232 is just really nice04mustang232 is just really nice04mustang232 is just really nice04mustang232 is just really nice
Send a message via AIM to 04mustang232
The only one thats hard is the one, when looking at the engine from the front, the far passenger one. Take your intake off your throttlbody and move it to the side. Then using your left arm and putting your right hand atop your intake manifold (make sure its not hot), bend down nice and far and use your fingers. I cannot stress the importance of starting a sparkplug in with your hands. DO NOT use a fucking rachet and extension until you have made sure that the plug is seated and in there snug. You will strip the threads if you dont.
Originally Posted by JBIGBOOTSY View Post
I am currently taking a pro dump as we speak. It also feels like about 3" diameter.
Old October 28th, 2008, 08:15 PM   #8
JASonic's Avatar
iTrader: 20 reviews
Im pretty sure the brand to avoid in our 6ers is Bosch. Let someone here verify that first but Im pretty sure they do not do well in our cars.
Old October 28th, 2008, 09:26 PM   #9
2004 Mustang V6
14.4@ 96
bingo. I ran bosch platinum plus 4s in my car. You kno the ones, 4 prongs, super expensive. I pulled them out after 5k, they were disgusting. My car ran brand new after replacing them.
Basic oems are the best way to go. Lets face it, these arent monster motors, most of us are pretty stock engine wise.
Old October 28th, 2008, 09:56 PM   #10
JASonic's Avatar
iTrader: 20 reviews
I bought those Bosch and brought them home. Before I installed them, I mentioned them here. I was told by HMUSN and a few other I think to take them back. I did. I took them right back to AZ and I think I ended up buying the Autolite. The plugs have been perfect.
Old October 28th, 2008, 10:09 PM   #11
mmvi is on a distinguished road
Send a message via AIM to mmvi
bosch blow. and you can get at the back passenger one without taking the tb off; you will need to take your intake off though, but thats kinda obvious. I had taylor wires on my 3.8, and they worked fine, although summit took their sweet ass time getting them to me, and they were expensive, and i had a screamin demon coil pack, but thats only because my stock one went bad on me. in my opinion, the coil pack isn't worth a damn. the best plug i've used in a 3.8 was autolite.
Old October 28th, 2008, 10:15 PM   #12
2004 Mustang V6
14.4@ 96
i accidentally said tb instead of intake. Good looking out man.
Old October 28th, 2008, 11:01 PM   #13
MM's Resident Ricer
2006 Scion tC
13.001@113
avoid bosch in any car, they make some great products spark plugs they screwed up on lol
NCMM #9
Old October 28th, 2008, 11:02 PM   #14
ItaliStang's Avatar
01 V6 convertible
too slow to try
ItaliStang is just really niceItaliStang is just really niceItaliStang is just really niceItaliStang is just really nice
autolite coppers (part #765)
gap them to .054
Eagle Scouts or GTFO!
#8 in MM's coolest members
Originally Posted by 93hatch View Post
I voted for 93Snatch, because I don't even know what the fuck that thing on his avie is. Is it a Thunder Chicken?
its fucking zapdos show some goddam respect!!!!!
Old October 29th, 2008, 12:09 AM   #15
2004 Mustang V6
14.4@ 96
great wiper blades
Old October 29th, 2008, 01:25 AM   #16
2004 Mustang V6
14.4@ 96
Originally Posted by 6er_w/a_Vengance View Post
...how often should u replace spark plugs if at all...any reason to upgrade wires w/ a basically stock motor...
since its so cheap, i would do it every 20k. You have to watch the spark plug wires though, they get super brittle from heating/cooling so many times. They will come apart. Id do sparkplug wires after 50k.
Old October 29th, 2008, 03:00 AM   #17
2004 mustang v6
n/a
ok well i went to auto zone and got my oil and filter for 29 something and also got me a set of new autolite double platinum .....i also replaced fuel filter and cai filter .what else can i do to make my car run smooth??
Old October 29th, 2008, 09:14 AM   #18
Prankster's Avatar
2003 Yellow V6 Coupe
Bone Stock just tires
Prankster has a little shameless behaviour in the past
pluging it right.
When I bought mine, it came with a set of Bosch Platinums, and the tips had been burnt down to almost nothing.
The engine had a strange skip in one cylinder, and it bothers me when my engine doesn't sound right.
I installed a set of NGK Iridium just like the ones I had in my Motorcycle.
I really didn't see any improvement to speak of, and the engine still had that Annoying skip.
Monday I poured a pint of SeaFoam into the fuel tank, and that skip is now gone.
I have always liked Autolites.
They seem to last forever, and many times I have just cleaned them, and put them back into the motor.
Loki
Old October 29th, 2008, 12:16 PM   #19
2004 Mustang V6
14.4@ 96
take those back. Didnt you listen to the comments above? our cars are not designed to run on a platinum. They are designed to run on a basic copper plug. They are a dollar a peice, basic, and work the BEST.
Old October 29th, 2008, 12:49 PM   #20
I believe the original equipment plugs are Autolite platinum and they are supposed to last as much as 100K miles.
I believe you are supposed to replace the plugs and wires at 100K intervals.
In my experience the plugs last more like 70K miles.
Threads Similar to: sparkplug help and question?/
New Sparkplug Wires - What should i get? The Novice 5.0 Mustangs 15 September 11th, 2008 11:08 AM
Chucked a sparkplug. jivepepper 99-04 19 August 10th, 2008 04:39 PM
what sparkplug to use? VinceSVT 99-04 1 July 10th, 2008 01:46 AM
Sparkplug advice stangstrip 99-04 6 June 10th, 2008 01:23 AM
Sparkplug regapping?? Dallas01GT 99-04 7 October 20th, 2007 10:05 PM
