speedo jacked up
LinkBack (1) Thread Tools
Old October 28th, 2008, 09:11 PM   1 links from elsewhere to this Post. Click to view. #1
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
speedo jacked up
01 3.6 5 speed.
4:10's and a speedcal installed.
recently had a spec stage 2 dropped in. by recent I mean 2 days ago.
Can't get the car past second gear because the speedo is hitting 120 mph causing the rev limiter to kick in.
Revs normally as well. is normal at idle.
this used to be my v6 mustang but it's in Wisconsin so I can't diagnose it properly.
I say VSS but my cousin ( new owner) says the mechanic at ford checked it and it's good.
The mechanic blames it on the speedcal but I call on that and think it's the vss because even without the speedcal it wouldn't be off by that much.
I think something happened to the vss when they did the clutch and don't want to own up and replace the part.
what do you think?
Old October 28th, 2008, 09:17 PM   #2
MM's Resident Ricer
GreenFaleen's Avatar
2006 Scion tC
13.001@113
speed sensor in the tranny id put money on it
NCMM #9
Old October 28th, 2008, 09:18 PM   #3
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
i would bypass speedcal to see if any difference.
Old October 28th, 2008, 09:18 PM   #4
MM's nicest mod, :)
White99stang's Avatar
White99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to all
actually think if something is shorted in the speed cal box that it can cause that. The easiest way i would think is to take off the speed cal and see if it still does it
06 Dodge MegaCab Diesel 455rwhp/815rwtq
REAL TRUCKS DON'T USE SPARK PLUGS
Old October 28th, 2008, 09:19 PM   #5
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
^ I thought of that as well.
Old October 28th, 2008, 09:19 PM   #6
MM's Database Error
WLJohnson05's Avatar
2004 Mustang V6
322.8 rwhp
WLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud of
iTrader: 9 reviews
+1
SCT Mass Air Flow Sensor $200
Old October 28th, 2008, 09:25 PM   #7
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
He is reading this right now.
Old October 28th, 2008, 09:31 PM   #8
The Hammer
G.T. Rags's Avatar
Millenium Falcon
G.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant future
disconnect the speedo sensor plug from the transmission..... if the car goes then it has something to do with the speed sensor
I would eat the peanuts out of her shit
Car Salesman Club - The Hammer
ModdedMustangs Conspiracy Group: President
LinkBack to this Thread: http://www.moddedmustangs.com/forums/v6-mustangs/95138-speedo-jacked-up.html
speedo jacked up This thread Refback October 28th, 2008 09:25 PM
Threads Similar to: speedo jacked up
I think my fox is jacked up blakehunter316 5.0 Mustangs 23 September 25th, 2008 12:15 AM
another jacked up school story stangfreak The Clubhouse 42 February 28th, 2008 12:08 PM
speedo bigdaddy09 5.0 Mustangs 10 September 19th, 2007 01:00 AM
Speedo guesswatidrive V6 Mustangs 3 April 16th, 2007 01:55 PM
So I jacked my car up both sides today 00SoSlow General Tech 1 July 30th, 2006 08:11 AM
