9k to spend - Page 6
Old December 19th, 2006, 08:26 PM   #101
Sa-WaitNoMustang900Turbo is on a distinguished road
Originally Posted by Blackstang_04
maybe i miss understand the whole stroker idea, but stroker kits still involve boring out (stroking) the motor to make it have more cubic in thus the 4.0 but I could be totally off.
but as far as I know, no you cant
stroking is different from boring, instead of making the diameter of the cyl. bigger, the actual stoke of the piston is increased, this is done by swapping out to a different crankshaft to determine the increase in displacement and then also swapping out connecting rods and pistons to yield the desired compression ratio.
Boring does increase power, but it is done by literally reboring the cyl. in the block to increase it's diameter. Most of the time this is done when building a high performance engine from an already used one. By boring the block out it is made to act like it is "new," but with a bit of increased displacement. Im willing to bet that most of the "stroker" engines you can by have also been bored since most, like th 4.3L ssm stroker, are made from used street engines.
God... That Euro import guy is really starting to get on my nerves... my car can only beat his in a strait line(maybe)
Old December 19th, 2006, 09:54 PM   #102
¡ʇsnq ɹo uʍop ǝpısdn
... okay and any idea what the compression ratio might be... and if it will work for a super charger or will the compression have to be re figured
Threads Similar to: 9k to spend
$1,500 to spend Jucostud 96-98 8 June 6th, 2010 07:07 PM
If you had $10,000 to spend 96gtstang&V6 2005 - 2010 66 October 16th, 2007 12:28 PM
10k to spend... jat 2005 - 2010 53 September 22nd, 2007 12:48 PM
$500 to spend |TH|BLaCkStAnG 99-04 47 April 10th, 2007 07:55 AM
600 to spend need help trebel14 Modular Mustangs 30 February 10th, 2007 09:39 PM
