Acceleration Issues - P0171
Old November 16th, 2008, 05:48 PM   #1
cgyarring is on a distinguished road
So about 6-7 months ago I blew a header and had the engine worked on to get her running again. Ever since I got it back, it's never been the same as it was before.
I had the Check engine light turn on, took it in and it popped code P0171 System Too Lean Bank 1. I've cleaned the MAF, and am still having these acceleration problems. I can peel out just fine, plenty of immediate power, but then right after words, in middle/low RPMs she gets pretty sluggish and them starts roaring again at the higher RPMs. I'm not really sure where to go from here, any advice would be appreciated. She's almost all stock 95 v6 with true dual straight pipes and flowmaster 40's. Any and all help will be appreciated.
Old November 16th, 2008, 06:14 PM   #2
Cleaning the MAF got rid of the Check Engine, but I'm still experiencing the acceleration issue.
It should be noted, the only time there is an issue is in first gear. But perhaps that's because it's the only time my RPMs are low? Dropping from 3rd to 2nd to get a boost works exceptionally well, but off the line it's dragging.
Old November 16th, 2008, 06:44 PM   #3
MM's Database Error
WLJohnson05's Avatar
2004 Mustang V6
322.8 rwhp
WLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud of
iTrader: 9 reviews
well considering its a 95 v6 its not gonna be pullin too hard off the line anyway, but once u get up in ur powerband more u will feel more power
SCT Mass Air Flow Sensor $200
Old November 16th, 2008, 06:54 PM   #4
It used to be faster off the line if I remember correctly. I just find it odd that it's got a bit of pep, then bogs down, and then starts ripping again.
Threads Similar to: Acceleration Issues - P0171
Acceleration HEMENWAY89GT 5.0 Mustangs 4 December 5th, 2007 07:39 AM
Acceleration HEMENWAY89GT 5.0 Mustangs 4 December 3rd, 2007 10:21 PM
code P0171 bbrewer03 96-98 6 December 2nd, 2007 06:52 PM
P0171,P0174 Clay 99-04 4 October 2nd, 2007 05:58 PM
p0171 code 96gtponyred 96-98 7 August 24th, 2007 12:03 AM
