2000 SIXXER
broken lug?
Friend of mine has a 99 v6 and caught a flat on the way to work... when he was pulling off his tire he broke one of the lugs so now it only has 4. he put his spare on anyway and has been driving fine like this. is it safe? and how/where can he get it fixed? since it was made with 5 i would assume it isn't that safe to ride with 4.
TRUE DUALS, CUSTOM H, 40 SERIES FLOWS, CAI
COMING SOON!!! LT's, SPRINGS |
#2 | |
2006 Mustang GT
Probably not the smartest to try 3 but 4 will be fine. Just get it fixed when he mounts the new tire.
![]() 1967 Styled G.T. 350 S197 tribute - see garage for list of mods. Last edited by coolhandluke; November 20th, 2008 at 02:14 PM. |
MM's Resident Ricer
2006 Scion tC
13.001@113
did he just break the nut or did he damage the stud?
he will be ok for a little but he need to get it fixed or the tire will wobble
2000 SIXXER
the actual stud that the tire sits on is broken... about how much does it cost to get this fixed?
MM's Resident Ricer
2006 Scion tC
13.001@113
buy a new stud at autozone, drill the old one out and remove it screw in the new one
The stud isn't threaded in, it's pressed in. Take the hub off and have a machine shop press in a new one. Or you might be able to do it yourself with a vise and some sockets.
MM's Resident Ricer
2006 Scion tC
13.001@113
you sure on that?? I could have sworn the 99-04 had threaded studs
2006 Mustang GT
Pretty sure that they are pressed in as well. If you're going to do it yourself, you might need to heat them up or it will be a pita pressing it in.
![]() 1967 Styled G.T. 350 S197 tribute - see garage for list of mods. |
MM's Resident Ricer
2006 Scion tC
13.001@113
oh my bad, then yeah if you want to do it your self buy the stud, take off the wheel hub put the stud in and place a brick or something hard and flat on top of the stud your pressing in then lower a car down on the brick and that will press it in, or have a shop do it
2000 SIXXER
don't plan on doing it cuz its not my car and he's too lazy to do it himself... what kind of shop should he go to? rim shop? or jus a mechanic?
MM's Resident Ricer
2006 Scion tC
13.001@113
machine shop anywhere that has a press most mechanics should have a way to get it done
1999 Ford Mustang V6
14.79 @ 92.15
you can actually hammer it out and hammer the new one in a tad then put the nut on, tighten, and you have installed your new stud
![]() if not, a shop shouldnt charge but a few bucks to do it. takes all of 5 minutes to fix
2005 Torrid Red GTO m6
its easy and its a threaded stud im almost sure. mine was
heres what you need to do (i had to do it on the gt i bought broken stud) jack her up (i had the luxury of a lift) remove the caliper and the bracket next youll need to remove the rotor the rotor has these thin metal lock rings on each stud cut them and toss em, ya dont need them anymore and dont even worry about it take a hammer preferably a heavy flat one hit it real hard and it will pop out next sit the new stud in where the old one was it wont go in youll need to pull it in an impact wrench works the best by far but if you want to do it by hand or you have an electric one itll just be harder anyways slide the lug nut on the new stud and hand turn it till its snug now use whatever wrench your using and just keep twisting it and eventually it will pull the stud through and sit it in notes: dont go to napa. i made that msitake and got a stud that destoyed two lug nuts and itself go to advance buy an extra lug nut just in case nows a great time to change brake pads you can get a cheap impact wrench at walmart buy some brake parts cleaner and make sure you clean off the calipers and the hole for the stud you dont need any sealant itll take a bit especially by hand and it wont look like its going in but it is just keep working at it the stud isnt even 2 bucks its not worth it going to a shop any questions just pm me
1996 Cobra To be sold... 2005 M6 Twin Turbo GTO Torrid Red Fully Forged LS2 Block Built to handle 1000RWHP. Fully ported Dart Heads. Edelbrock Jr Intake. Custom cut upper intake plenum. APS twin Turbo System with APS twin Fuel pumps. |
The shop manual for a 99 says it's pressed in. For the front it recommends removing the hub and using a hydraulic press. For the rear it recommends using a ball joint press. Either front or rear it can be pulled back in with a lug nut and some washers.
I would think the ball joint press would be a good tool for removal if you want to do it yourself. |
2000 SIXXER
thanks for the info guys
Threads Similar to: broken lug?
| Broken T-5................. | MOTOIMPAIRED | 5.0 Mustangs | 3 | October 6th, 2008 03:39 PM |
| Broken again | 69fastback | Classic Mustangs | 15 | April 29th, 2008 11:05 AM |
| 4 Lug vs. 5 Lug Wheels | rocket | 5.0 Mustangs | 13 | October 17th, 2006 03:50 AM |
| 4 lug to 5 lug conversion questions | jharp59 | Classic Mustangs | 0 | June 10th, 2006 11:44 PM |
| it's broken...... | Twist 2 Go | The Clubhouse | 15 | October 17th, 2005 01:02 AM |
