Bad miss, Undrivable
Old November 25th, 2008, 03:04 PM   #1
gdcpony's Avatar
gdcpony is on a distinguished road
The miss started last night on the way home. I have looked at spark and found it good at all cylinders. I just changed the fuel filter 6 months ago. I get a spray of fuel from the Shrader valve, but I don't have a gauge to check pressure. The inlet track is modified by a "PowerAid" TB spacer (was on the car when I bought it), and the air filter housing has been opened some (again before I bought it). The exhaust is a Mac 2.5 all the way back with cats and shorties (I would trade this for a GT set up in a second). Other than that it is stock. Tune up done 6 months ago and it had Seafoam through it a month ago. There is no code being thrown by the ECU.
I take good care of my cars so this is really bugging me. It feels like a constant thing until I rev it up high enough to hide it (3k). I get jerked down the road as the exhaust pops. It is BAD! Please help as this is my work car.
I have to get to work now (thank God I have a truck), but will check back at midnight. Thanks in advance.
Marines: Giving the enemy the opportunity to die for their cause since 1775.
Guns: Giving us freedom since we learned how to shoot
Mustangs: Giving gearheads a reason to exist since 1964
Turbos: Giving me a reason to appreciate all the above.
Old November 25th, 2008, 09:01 PM   #2
04mustang232's Avatar
2004 Mustang V6
14.4@ 96
04mustang232 is just really nice04mustang232 is just really nice04mustang232 is just really nice04mustang232 is just really nice
Send a message via AIM to 04mustang232
"misses" are such a pain in the ass. Youll drive yourself crazy trying to find it.
Start your car in the dark and check and see if your spark is arcing somewhere, like on your manifolds.
Clean fuel injectors with seafoam.
Clean MAF sensor.
Check vacuum lines.
My car would miss to the point it was undrivable as well. Turned out it was a bad fuel injector. Thank god it was under warranty.
Is it throwing any engine codes?
Originally Posted by JBIGBOOTSY View Post
I am currently taking a pro dump as we speak. It also feels like about 3" diameter.
Old November 26th, 2008, 12:50 AM   #3
gdcpony's Avatar
A friend who fills up his car at the same place I do says he had this problem last week and it was the gas. We filled up within a couple hours of each other. I added some drier and cleaner and drove it to work (I am suffering from whiplash!). No change yet.
I did notice it subsides- not quite completely- under heavy throttle. Not a good thing to use in the snow. It also is at its worst at 1200-1700 and operating temp.
There are no codes. I see no sparks unless I unplug something. I just Seafoam'd it a little while ago. I will clean the MAF and TB tomorrow after work (working days for the holiday shutdown).
Old November 26th, 2008, 01:11 PM   #4
stephen has a spectacular aura aboutstephen has a spectacular aura about
If you suspect water in the gas use up all of the gas and refill and also change the fuel filter. If it started suddenly bad gas is likely.
Also take the plugs out and take a look at them. I had a misfire at high speed that was due to heavy deposits on one plug. This is especially likely in the back cylinders (#3 and #6).
Old November 27th, 2008, 02:55 PM   #5
JTS
JTS's Avatar
2000v6/soon 5.0=]
15.45@88.37mph
JTS is on a distinguished road
Send a message via AIM to JTS
Clean MAF sensor.
Check vacuum lines.
+1.... I had the same problem i couldnt go past 20mph mine kept miss firing and I ended up taking out all my plugs one by one and i found that one of them was cracked so i put a new one in and it ran perfectly fine
99 svt cobra rims/cai/autolite plugs.
Soon to have a 1990 mustang gt fox
Originally Posted by graystang01 View Post
the smell fuckin exploded out of the box...
Originally Posted by Arsenal View Post
I'm sorry that you haven't evolved past the point of knock knock jokes, but maybe now is the time to learn.
Old November 30th, 2008, 10:31 AM   #6
gdcpony's Avatar
Thanks guys still driving out the bad crap. Decided to add some fuel system cleaner, and fill the tank at 1/2 tank. Seemed to help a little. I'll pull the plugs as soon as I run this out.
Old November 30th, 2008, 01:50 PM   #7
Hourofpain's Avatar
2005 Torrid Red GTO m6
Hourofpain will become famous soon enough
is it shaking?
can you hear it in your exhaust?
might be your coil pack
1996 Cobra
To be sold...
2005 M6 Twin Turbo GTO Torrid Red
Fully Forged LS2 Block Built to handle 1000RWHP. Fully ported Dart Heads. Edelbrock Jr Intake. Custom cut upper intake plenum. APS twin Turbo System with APS twin Fuel pumps.
Old November 30th, 2008, 06:31 PM   #8
Dragonhunt is on a distinguished road
My car is a 2000 Mustang and it does the same thing as your exactly same RPM range also. Mine is drivable, it just sputters/surges/misses at that range.
I put in plugs, wires (Durlalast) which I think are crap and I am going to change them this week, new plugs, PCV, Fuel Filter, Good 93 octane gas, cleaned air temp sensor.
I am going to test every sensor on the engine this week to find out what is causing this.
When you find out what caused you, please let me know and I will do the same.
Thanks
Old November 30th, 2008, 07:04 PM   #9
Originally Posted by Hourofpain View Post
is it shaking?
Do these go bad often? My car has 86,000
Have you had one go bad?
Old November 30th, 2008, 07:07 PM   #10
The soul stealing Ginger
dgt_mustang's Avatar
2001 Mustang 3.8l
dgt_mustang is a jewel in the roughdgt_mustang is a jewel in the roughdgt_mustang is a jewel in the rough
Send a message via AIM to dgt_mustang Send a message via Skype™ to dgt_mustang
read the first paragraph fully, maybe this is your problem?
99-00 3.8L Mustang Driver's Side Valve Cover Fix
Get another job, get 2 more jobs, get your own place, work, live, fuck, eat, life, happy.
Old November 30th, 2008, 07:17 PM   #11
Thanks, I will look into it
Old November 30th, 2008, 07:19 PM   #12
This only happens (at least it feels this way between 1200-1700 prm's)
You think it could really be cause by oil in the cylinders?
Old November 30th, 2008, 08:58 PM   #13
2001 Mustang 3.8l
possibly, seems alot of people had problems with that.
Old November 30th, 2008, 09:00 PM   #14
MM's Database Error
WLJohnson05's Avatar
2004 Mustang V6
322.8 rwhp
WLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud of
iTrader: 9 reviews
hell i think ima be building a catch can type thing for mine when i get the chance instead
SCT Mass Air Flow Sensor $200
Old November 30th, 2008, 10:01 PM   #15
Look at this:
Old November 30th, 2008, 10:09 PM   #16
MM's Database Error
2004 Mustang V6
322.8 rwhp
iTrader: 9 reviews
Originally Posted by Dragonhunt View Post
Look at this:
yea i looked at it, my problem is im turbo'd so i cant have that boost going down in the crankcase so it would be easier for me to run a catch can somewhere with a line coming from each pcv hole and have it run to a central location where a breather is and have it vent there that way the can will catch the oil and still vent the pressure without boost going down thru the pcv valves
Old December 18th, 2008, 08:42 PM   #17
Well, I am going to do a compression test, I think I have a burnt valve.....
We will see soon
Threads Similar to: Bad miss, Undrivable
running bad...small miss GT87Stang 5.0 Mustangs 4 September 13th, 2008 09:09 AM
IAC BAD??? OR throttle body bad? Rico-mofos 99-04 10 March 12th, 2008 06:32 PM
Bad miss at WOT, Need Help!!!!! kilby91 5.0 Mustangs 13 January 19th, 2008 06:46 PM
Miss Me Yet? TheUNZippee! The Clubhouse 18 January 6th, 2008 06:29 PM
Bad Bad Bad situation mustangmanic The Clubhouse 32 October 26th, 2007 10:55 PM
