1992 Mustang Lx 331 Stroker/ Built (25k invested)
Go Back   Forums at Modded Mustangs > The Marketplace > Classifieds > Vehicles For Sale
LinkBack (1) Thread Tools
Old May 23rd, 2011, 11:03 PM   1 links from elsewhere to this Post. Click to view. #1
Fijistudios's Avatar
Cobra soon?
Fijistudios will become famous soon enough
FS or Trade. This is a highly modified, street oriented car w Original Paint Made to be as reliable as possible and can be driven in any season. It isn’t a show car but as the pictures show, it can be dressed up. Runs on 93 octane and weighs 2830lbs. Runs 11.8 at 119 N/A on pump two years ago. I wax it weekly and drive cross-country with the car and really do not want to part with it. This is a clean car done right and will keep its value if treated properly for years to come.
Clean survivor of the Fox era
Model: Ford Mustang Lx Hatchback
Engine: Fuel Injected Built 5.5L
Trans: Built AOD w/ Custom Valve Body
Miles: Body--44,xxx (could mean 144,xxx with rollover)
Trans--3,xxx
Motor--35,xxx
Owners Before Me: 2
Vin: 1FACP41E4NF141707
Weight: 2920lb (no driver or audio)
Dyno-Tuned: Big 3 Racing---2 tunes
(race gas/ conservative daily driver) 420whp and 390whp respectively
Engine Built: K&B Racing (Ohio)
Trans Built: Jesse Lewis Transmission
Extra Mods: Hiren Auto installation (ft. Wayne)
Engine:
Production "xxx" Roller Block
331ci Probe “Street Fighter” Stroker kit
Forged 4340 H Beam Rods
Forged Pistons (11.1/1)
Forged “SF” Crank
CL77 Engine Bearings
Block is cyro Frozen for strength
AFR Heads 185cc Flow
High Pressure Oil Pump
High Volume Water Pump
Eiddlebrock performer RPM II Intake Manifold
BBK 70mm BBK Throttle Body
70mm Mass Air Conversion Kit
MSD 6A Kit
MSD Blaster coil w/ Harness (full ignition)
MSD Racing Spark Plug Wires
BBK Cold Air Fender Intake System
Brand New A/C Delete Pulley
Heater works great
New Balanced Pullies
New OEM Belt Tensioner
K&N Air Filter
Custom Ground Cam by “Comp Cams”
New FelPro Gaskets with Build
New Rockers (Builder Preference)
FRPP 30# Injectors
190 l/h upgraded Fuel Pump
Electric Fan
(temp at 150F during dd status)
Fan runs all the time
Smog is removed
High torque Starter
Ford Cobra Valve Covers
Stock Radiator
11.1/1 compression
New Rings
Oil Dress-up Kit
Radiator chrome cover
All New Radiator Hoses
New OEM Starter Solonoid
New OEM Block mounted Starter
Radiator Chrome Cap
Ford Racing Oil Cap
All New support and bolts for radiator
Brand New Red-Top Duralast Battery (Deep Cell)
Motor Broken in with Brad Penn Racing Oil
Motorcraft Oil Filter changed every 5,000 miles
Mobil One 5w 30 Changed every 2,000 miles
Peak Antifreeze 50/50 Blend
Trans:
Stock Aod shell: (Cyro Frozen)
'A" Servo (racing built)
Contains overdrive (OD)
New custom torque converter (Nitrous in mind)
Moser 33 Spline Axel
Kevlar Gears (even O/D)
All Cyro-Frozen
New Trans Synchronizers
Ford Motorsport Wide Ratio Upgrade Kit
ReCal-Pro™ AOD valve body recalibration
B&M handle/Shifter
Rated at 600 ft/lbs Torque
3500 Stall (Street Friendly, keep traction)
Suspension:
Rebuilt/Strengthened Ford 8.8 Rear End
Custom Length Driveshaft
4.10 FRRP Gears
Steeda Drag Racing Springs
Stock Brakes (plan on new pads soon (Hawks))
(Front Disc and Rear Drums)
Poly Engine Mounts
Lower control arms
BMR Sub frame Connectors
Heavy-duty Rear Antiroll Bar
Rear Control Arms
Front Antiroll bar removed
Koni Shocks
Wheels:
Weld racing Rims
Mickey T Drag Radials
(275 D/R Rear/116 Skinnies Front)
Front are brand new all season Tires
Rear have 70% Life Left
Exhaust:
Long Tube Headers (BBK)
Aftermarket H Pipe
Dumped Flomaster 40’s (before axel)
Body:
93 Cobra Wing
2 inch Cowl Hood w/ rear vents
Tinted rear headlights
OEM Front Headlights
Front Cobra Horse air inlet
Original Paint (waxed almost weekly)
Interior:
Autometer for Oil/water temp
Pillar mount for above gauges
Autometer Monster Tach w/ Memory
Autometer Shift Light (6400rpm)
Switch in glovebox for tunes
93 cobra door panels (leather)
Some very nice Fox Seats (Leather Siding, good condition)
Electric locks
Cruise Control Works
Automatic windows (Not Stock)
Bellatronics Radar B155 detector
Alpine Headunit w/ Ipod connect Cable
0-140mph Ford Gauges
Garmin GPS (comes if I get asking price)
2 10 inch Road thunder MTX Subs w/ Tweekers
Vented box with amp mounted on back
1000 Watt Crunch Amp
Monster Wiring (8 gauge) all hidden
The car is a clean daily driver. It is made for every season except winter and has been generally babied. The paint is original and shows you a view of it’s past care. It is not perfect but again we are talking about a car that is 19 years old. So this is just rare. There are two small spots of rust, one on the passenger kicker panel that is sealed, and one on the back hatch that is small enough you can barely see it in the pictures. Both are contained and combined with storage, are not an immediate problem.
The car runs slightly rich to safely tune it for daily drivability. This is only realized when it is very cold and the computer pulls the timing. It was tuned with daily driving in mind and I drive it every clear day I get and never been stranded or had a problem. Heat works great and overdrive allows you to be at 2400RPM at 75mph. It pulls hard and even has a race gas tune available on tap in the glove box (switch with numbered tunes). Combine a small shot of nitrous and you can drive to the track, pull a 10 second mile on race gas, then cruise home to the tune of 24mpg in overdrive. It is not an immaculate show car nor a race/track car. It is a little of both. The time spent completing this car are huge and the money is nearing $25,000.
$7900 Firm
SEX!
It Revs..
Some underbody pictures
ddd
---2003 Ford Focus- VF Engineering Vortech kit, Tein suspension, etc. Fun DD
---2.1 Kenne Bell 1987 Mustang Lx-465rwhp/520rwtq SOLD
you both launched like you were chloroformed by a potential rapist
Originally Posted by FluffyTheRhino View Post
Cliffnotes: I just took a dump.
Old May 25th, 2011, 12:07 AM   #2
2vPOWA is on a distinguished road
Interested in Trades?
93 LX Hatchback H/C/I Full Suspension
06 Ford Explorer Limited
Old May 25th, 2011, 06:43 PM   #3
Cobra soon?
Feel free to let me know what you got
Old May 25th, 2011, 11:55 PM   #4
In my signature is the short version but I am sure you get the feel of it. I can send pics to your email or you can pm me you number.. I know you already had one but I have been looking for a clean fox. I DD mine and have had it for four years. Just looking into getting a fox like my two previous ones. Let me know. I am located in Albany,GA, which is about 3 hours south of atlanta.
Old May 26th, 2011, 12:58 AM   #5
Cobra soon?
Sounds like a clean ride. I would love pics or a link if you have any
email- travsimp@gmail.iu.edu
Old May 26th, 2011, 03:53 PM   #6
Do you have a more updated email address. I got an error when i tried sending you a description and pics.
Old May 26th, 2011, 04:08 PM   #7
is it @gmail.com?
Old May 27th, 2011, 10:32 PM   #8
Cobra soon?
is it @gmail.com?
sorry it is umail.iu.edu or indiana.edu they both will work
Old May 27th, 2011, 11:09 PM   #9
9k All Day.
VinceS2K's Avatar
MY00 s2000.
VinceS2K is a glorious beacon of lightVinceS2K is a glorious beacon of lightVinceS2K is a glorious beacon of lightVinceS2K is a glorious beacon of lightVinceS2K is a glorious beacon of light
dear god..... so much want.
Now, I'm fucking terrified of beetles. I mean, what of it had worked its way into my butthole or something?? They creep me the fuck out.
Old May 31st, 2011, 09:20 AM   #10
Emails don't work.
Old June 1st, 2011, 08:07 PM   #11
Cobra soon?
Emails don't work.
well my IU email is travsimp at indiana.edu but an old alternative is indyboy1990 at juno.com
Old June 6th, 2011, 09:49 PM   #12
Cobra soon?
Emails don't work.
Did the email work?
Old June 8th, 2011, 04:48 PM   #13
No offense but i decided to keep my car. if I get a fox it will be to add to the corral. sorry
Old June 8th, 2011, 10:43 PM   #14
slowcoupe is on a distinguished road
Pretty clean car. The second picture is cool where it looks like you can see the engine through the cowl. Good luck with sale.
Old June 9th, 2011, 02:35 PM   #15
Cobra soon?
thanks, appreciate it
Car may be spoken for, nothing concrete so jump on it now if you are interested because it seems that it will be sold soon
Old June 14th, 2011, 02:48 PM   #16
Cobra soon?
Deposit given, car is being delivered this weekend
Old June 19th, 2011, 07:14 PM   #17
Look Ma! My First Post!
5.0Noobshow is on a distinguished road
Any chance this car is still up for sale?
LinkBack to this Thread: http://www.moddedmustangs.com/forums/vehicle-classifieds/219693-1992-mustang-lx-331-stroker-built-25k-invested.html
Thread 1992 Mustang Lx 331 Stroker/ Built (25k invested) | Forums at Modded Mustangs | BoardReader This thread Refback January 17th, 2012 01:55 AM
Threads Similar to: 1992 Mustang Lx 331 Stroker/ Built (25k invested)
Having 3Valve stroker built by L&M Engines need installer in Dallas & Ft Worth zachman 2005 - 2010 2 October 19th, 2010 11:01 PM
This may be the best six minutes invested in your future WAR-PARTY The Clubhouse 55 July 21st, 2009 08:14 PM
Evo VIII (2.4L stroker/63mm) VS. 2003 Cobra (built/Whippled) drwprtcht Videos 4 May 2nd, 2009 01:24 AM
