Fiberglass Body Kits: Are they worth it?
Old December 4th, 2008, 08:36 PM   #1
mattcrid89's Avatar
mattcrid89 is on a distinguished road
I'm thinking about buying a fiberglass body kit. What are some opinions you guys have about these? Are they reliable and sturdy? Are they hard to install?
Old December 6th, 2008, 05:44 PM   #2
Rollin' 18/ pushin' 2
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
From personal experience, I would not use them. My wife had a 98 vert and loved my saleen. She now has one of her own but before we got it I bought and installed a fiberglass saleen kit on her car. It requires alot more prep work. There were fine lines and you could not even see them until it was being painted. I had to pick it up, fill it ( just glazed the whole thing ) and resand and prime it. The install is not as easy as urethane or rubber either. The fiberglass kit did not have all the same mounting tabs as the stock bumpers did. There were no tabs for the side braces on the front or rear bumpers. The rear bumper did have the upper center support for the center section, but that and two screws in each fenderwell were all that I had to hold it on with. The front was held on with the two rivets in the center section and two screws in each fender well.
They were on there about six months before someone rear ended her. MAJOR damage to the fiberglass. I had to patch it from the back as it cracked pretty hard from the impact. then I had to constantly fill and sand to get it back into shape. Then pay for paint again.
I hit a trash can with the front bumper about a year later and it shattered the front bumper pretty well. I considered fixing it again, but as she was preparing to sell it to get her own saleen, I just replaced the body kit with the factory bumpers and side pieces.
It lasted and performed well on the car. I always felt the install was kind of half assed due to the kit not having the proper tabs to properly secure and align it on the car, everything had to be eyeballed on the install to get it to look right.
In all I probably spent as much in labor and time, as well as painting it twice (due to the rear ending) as I would have to get a quality urethane kit.
I would not buy another one if given the chance.
This was just my personal experience with a fiberglass body kit. To each his own.
MODS IN GARAGE
NCMM ORIGINAL
BLOWN 96-98 CREW MEMBER # 1
Old December 6th, 2008, 10:31 PM   #3
Prankster's Avatar
2003 Yellow V6 Coupe
Bone Stock just tires
Prankster has a little shameless behaviour in the past
Question
adding some layers
Do you think adding layers of extra fiborglass to the back side would make these cheap kits any better?
Can it be cheaply done with carbon fiber?
I am not anywhere gifted at getting things to be smooth, or flat so I would need to work the backside.
I could rubber coat the backside.
I already bought the fiborglass stalker kit so I'm stuck with it.
How do I make what I already have much better than it already is?
Loki
Old December 13th, 2008, 02:54 AM   #4
exoskeleton is on a distinguished road
you could strengthen them considerably by adding fiberglass cloth/resin layers to the backsides, but there's still a lot of smoothing on the outside, alignment issues, etc, and it'll still be much more susceptible to damage..plus, the added weight of the extra fiberglass will put more strain on the already borderline mounting points.
my advice- sell the kit if you can and get a urethane kit, it will be cheaper in the long run.
barring that, reinforce it where you can, especially around any mounting tabs, and look for any ways to make it stronger (large washers on the mounting bolts/screws, adding an adhesive at the mating surfaces, fabbing some brackets if you have to....and ask your insurance agent if you're covered if they get damaged, body and paintwork costs can get big quick, especially if your car is a tri-coat color....hope this helps.
Old December 18th, 2008, 07:40 PM   #5
Rebel Of The Sacred Heart
travis_afx's Avatar
'02 GT
travis_afx is a glorious beacon of lighttravis_afx is a glorious beacon of lighttravis_afx is a glorious beacon of lighttravis_afx is a glorious beacon of lighttravis_afx is a glorious beacon of lighttravis_afx is a glorious beacon of light
Well said.
Any fiberglass part you get will require alot of sanding and priming and sanding and priming and sanding,........ Usually alingment is bad as well. All the fiberglass kits I have worked with requiered alot of modification and fabricating to get them to fit the car just right.
Travis Billings
May 6, 1982 - July 5, 2011
Rest In Peace brother, you will be missed.
Old December 18th, 2008, 07:46 PM   #6
One Man Wolf Pack
06RedfireGT's Avatar
2006 Mustang GT
13ish....maybe
Fiberglass kits require a lot more prep work than a urethane kit, plus if you hit a parking curb for example, the fiberglass kit will just crack because there is no give in it, a urethane kit will have some flex, so there is less chance for damage.
ΜΟΛΩΝ ΛΑΒΕ
Old December 19th, 2008, 10:57 PM   #7
06z28eaTer's Avatar
2006 GT / 1999 Cobra
06z28eaTer is on a distinguished road
Send a message via AIM to 06z28eaTer
spend the extra cash for urethane, you will be happy in the end
-2000 GT Vert-
Grabber Blue Paint, Cervini Stalker Hood, Xenon Front/Saleen Rear Bumpers, Bullitt Side Scoops, 18"FR500 Wheels, CDC Bar And Much More!
Old December 23rd, 2008, 01:45 PM   #8
texas_mustang has a spectacular aura abouttexas_mustang has a spectacular aura about
fiberglass is cheap until you nudge a curb.
Threads Similar to: Fiberglass Body Kits: Are they worth it?
Looking at body kits ArmyStang07 2005 - 2010 10 March 8th, 2008 03:10 PM
body kits for a 82 grey pony Visual 7 August 20th, 2007 12:23 AM
Inexpensive eBay CAI Kits. Are They Worth It? GT 2002 99-04 33 January 7th, 2007 05:55 AM
Body Kits maverick 96-98 14 October 29th, 2006 12:56 AM
Body Kits Skullman 96-98 2 July 4th, 2006 02:24 PM
