Discussing These dang headlights in the Visual Forum. How do I keep them clear? The set i installed last year are messing up ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
13.86@100.3
How do I keep them clear? The set i installed last year are messing up and i polished them once a month!
2000 GT SOLD! 13.96 at 97.49 STOCK AUTO 13.84 at 100.3 (spinning) ![]() W/3.73s SOLD: 88 GT Roller 2004 40th Anniversary GT Pro 5.0 Shifter Lowered Summit Hpipe w Dynomax weldin mufflers |
MM's Most Laid Back
'01 Cobra Vert.
Are they fogging up or getting like little scratches and what not in them?
![]() MM Cobra Club Co-Founder |
Too Legit to Quit
05 Saleen #824
did you seal it?
2008 GCSRT8, 1965 Coupe;
they are almost impossible... i didnt have a problem with mine... where did you get them from?
MM's Most Laid Back
'01 Cobra Vert.
You really need to make sure you seal them correctly or else they're gonna give you a s%#t load of problems...
13.86@100.3
They are sealed but it looks like clear coat coming off of them
03 mach 1
13.2@109
maybe your polishing them to hard and wearing them down ha
either that or you think there sealed right and they arent?? all good possibilities I supposse
2003 Mach 1, 5 speed ![]() "Dont worry ive locked horns with this fucker before"- TasteMyThunder "More like my gameplay will break there will"-TasteMyThunder www.myspace.com/mustangracr94 |
13.86@100.3
Ok ask lookin at they arent sealed but my new ones (2004) messing up to and its ford and sealed. Ima replace it but wat do u guys do to keep yours clear? Im selling other one so idc bout them anymore.
13.58 @ 102.31
are you talking about the black around the blinkers? i know its notorious for it to look liek its peeling or flaking off
13.86@100.3
No the clear were the headlight turns
13.58 @ 102.31
wow i have never had that problem, i would say that maybe it was from extreme heat or something but i see that your in AL not like nevada
2003 GT
Do you have the correct bulbs for it? If you have high intesity bulbs the heat may be affecting your lights.
John
'03 GT, Max Moto Max Grip Box, Wilwood SL 6 front/DL4 rear Big Brake Kit, Corbeau Seats, MGW Short Shifter, MAC Long Tube Headers/Prochamber mid/ Flowmaster 40, FRPP 4.10, TrickFlow Diff Cover/75mm TB/Plenum, Eaton Posi, Moser 31 spline Axles, UDP |
Blown 03 GT
I have that problem with my stock lights. It looks like clear coat peeling.
Well Hellerrr..
2001 Bullitt
N/A
wet sand them and then polish them out, and then put a good coat of sealer on top of that, then wax them every time you wax your car.
13.58 @ 102.31
+1 my hids have made small haze marks on my headlights
13.86@100.3
wat kinda of sealer?
13.86@100.3
Y was this moved it was 99-04 lights only?
\____________/
'02 GT
My headlights were doing the exact same thing as yours, looked like "clearcoat" was peeling off. They looked horrible!
Mine now look like glass. I used this kit on her, and i have also used it on many other cars as well and the results are always flawless. I just had to sand enough plastic off to get rid of all the "peeling" plastic. ![]() 3M Headlight Lens Restoration System US Here is a good video about it, it is exactly how i do it except i add a coat of Wizards Shine Master as the last step. 3m headlight
BBK CAI, 75mm BBK TB, Trick Flow plenum, U/DP, spec clutch, short throw shifter, adj. upper cntrl arms, lower cntrl arms, 50/50 shocks, MAC exhaust, 4.10s, SCT flip switch
MM's Most Laid Back
'01 Cobra Vert.
^ you and your damn wizards
\____________/
'02 GT
Threads Similar to: These dang headlights
| Dang that joker... | mustangjeff1997 | The Clubhouse | 5 | July 19th, 2008 01:27 AM |
| Dang.. | mustangjeff1997 | The Clubhouse | 17 | June 14th, 2008 01:42 AM |
| dang. | B0B | The Clubhouse | 9 | January 30th, 2008 01:48 AM |
| Dang,he almost made it | Fryrice | Videos | 23 | January 17th, 2008 01:59 AM |
| Dang Clutch,,, | 2000BLK | V6 Mustangs | 3 | December 10th, 2007 09:43 PM |
