Windo louver adhesive problem
Old December 18th, 2008, 07:09 PM   #1
Dr BlackStang's Avatar
2007 Mustang GT
Dr BlackStang is on a distinguished road
Send a message via AIM to Dr BlackStang Send a message via Yahoo to Dr BlackStang
Hey guys I got a pair of window louvers cheap and I used some automotive molding adhesive however since the louver has to curve slightly, it doesnt wanna stay stuck to the glass. So help me please, what should i use to ensure they stay on and look professional (sorta lol) thanks
C&L CAI
XCAL 3/Brenspeed Tuned
Cervini Ram Air Hood
Hooker LTs/ or Xpipe
Borla Stingers
Hurst Competition Plus short throw
Steeda UD pulley
Ford Racing 4:10s
Old December 18th, 2008, 07:27 PM   #2
Rebel Of The Sacred Heart
travis_afx's Avatar
'02 GT
travis_afx is a glorious beacon of lighttravis_afx is a glorious beacon of lighttravis_afx is a glorious beacon of lighttravis_afx is a glorious beacon of lighttravis_afx is a glorious beacon of lighttravis_afx is a glorious beacon of light
you should use 3m double sided tape, and clean the part and the glass with rubbing alcohol before you apply the tape. Put the tape on the louver, then peel the other side off and put it on the glass. Make sure you use good pressure on it, becuase the tape will get a better hold if it gets a fair amount of pressure.
Or if you know someone that works at a body shop, they might be able to get you some adhesive promoter for it. I use "Pro-Bond", and since i started using that, I havent had any adhesion problems.
Travis Billings
May 6, 1982 - July 5, 2011
Rest In Peace brother, you will be missed.
Threads Similar to: Windo louver adhesive problem
help removing adhesive 06RedfireGT 2005 - 2010 43 May 19th, 2008 12:52 AM
help removing adhesive 06RedfireGT The Clubhouse 47 May 16th, 2008 11:14 PM
rear louver??????????? armymike63b 99-04 2 March 16th, 2008 04:19 PM
louver c-pillars? yes no? energiesource 99-04 1 February 4th, 2007 09:49 PM
What'z the best solvent to use to remove tint adhesive? WilltheThrill Modular Mustangs 5 January 11th, 2007 02:04 AM
