2008 GT
How to: blackout rear quarter lenses for $10 on S197
Here's my latest project on doing a little blackout job on my '08. I know you can buy these from a vendor, or use Niteshades, but I was bored and wanted to do this myself. So keep the comments about "But it's easier if you..." to yourself. I get satisfaction from doing things right and doing them myself. Anyway, hope this helps:
First, pop the rear quarter lens out using a screwdriver and rag. Pry on the end towards the front of the car - they pop right out. Unscrew the bulb socket and take it to the bench. ![]() Before you can lay down the tint, you have to remove the embossed Ford emblem and part number. I used a razor blade and 600 grit sandpaper to knock it down, then hit it with the buffer wheel. ![]() Cut out a piece of tint with about a 1/2" margin (I used 35% - anything darker did not let any light through at night), peel the backing off, spray the lens and tint with a water/soap solution, and lay it down. ![]() Use a heat gun to shrink the tint to the lens. I used a microfiber towel and my thumb to help the process. ![]() Turn it over, and use a razor knife to carefully trace the outline. If you're good, it will come out perfect. ![]() I chucked the lens up in the bench vice and continued to use heat and pressure to make the tint conform to the bends. Patience is a virtue at this point. You will pay special attention to the perimeter of the lens. ![]() This is what you will end up with: ![]() And this is how it will look on the car. Notice my other mod? Blacked-out trunk emblem - sweeeeeet! ![]() Goes well with the front signal lenses and blackout out pony/grill, doesn't it?
Fuel Altereds Rule The Earth
Rebel Of The Sacred Heart
'02 GT
Your car looks great!
You did a good job on the lenses. Its always nice to do something to your car yourself, I always get more satisfaction if i do it myself.
Travis Billings May 6, 1982 - July 5, 2011 Rest In Peace brother, you will be missed.
2008 Hammock Rodeo Champ
wow. that looks awesome. great job.
i have no mustang. so don't listen to anything i say. |
Threads Similar to: How to: blackout rear quarter lenses for $10 on S197
| Clear Front Signal and Rear Side Marker Lenses - Bulbs | Geezer | 2005 - 2010 | 6 | July 6th, 2010 02:16 AM |
| rear blackout | 07pw | 2005 - 2010 | 25 | March 20th, 2008 11:42 PM |
| I Want To Blackout The Rear N Hood | XPLICITSTANG | V6 Mustangs | 9 | December 14th, 2007 04:33 PM |
| Rear Blackout panel | 06GTMustang89 | 2005 - 2010 | 17 | October 24th, 2007 08:09 PM |
| Rear blackout panel | Grabber427 | 2005 - 2010 | 7 | May 21st, 2007 11:21 PM |
